AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Sep 11, 2012 at 6:59 PM
    #2641
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Should not have to do that.
    Did you use the proper pin and spring?
  2. Sep 11, 2012 at 7:06 PM
    #2642
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Pointy end up, and I always add a tiny bit of quality grease. I like copper anti-sieze (Loctite C5-A). I've never had to cut a coil, but as long as the safety isn't loose you should be OK.
  3. Sep 11, 2012 at 8:00 PM
    #2643
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    You didn't use a takedown pin spring on accident did you?
  4. Sep 11, 2012 at 8:04 PM
    #2644
    Rich91710
    Rich
    Los Angeles
    08 Base
    Or the BHO release pin and spring.
    Those are commonly confused.
  5. Sep 11, 2012 at 9:16 PM
    #2645
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    No they were all separated in the colored bags and I didn't mix them up. The pin was facing the correct way. I just removed the pin and added a toothpick drop of gun oil on the track of the safety pin and it moves flawless now
  6. Sep 12, 2012 at 2:55 PM
    #2646
    rondog
    Ronnie
    Escondido/San Diego
    Just ordered a couple mags and still need a pair of sights
  7. Sep 12, 2012 at 3:12 PM
    #2647
    kinetik873
    kinetik873 Well-Known Member
    Josh
    Springfield, Va.
    '08 TRD
    OME 3" lift, ARB bumper,DTRL, CB radio in console, 5lb fire extinguisher in bed. SockMonkey decals, Allpro rear bumper, UWS 42" bed box, Wet Okoles all around, snorkel, Pioneer Av3200, ..yadda yadda yadda
    Just got in my LPK, buffer tube and associated parts, MOE stock, BAD Lever, and extended trigger guard, I am thinking of a 14.5" afghan with a 1.5 Battlecomp. Rob_S, any input on the muzzle device?
  8. Sep 12, 2012 at 3:25 PM
    #2648
    2004tacoprerunner
    2004tacoprerunner Well-Known Member
    byron, mn
    2004tacoprerunner
    The hole that holds the safety/select lever spring in Hogue grips weren't drilled down deep enough and gave me the same problem. Rather than cut springs I just drilled the hole a little deeper.
  9. Sep 12, 2012 at 9:48 PM
    #2649
    rondog
    Ronnie
    Escondido/San Diego
    I guess either would have worked..anyway, I have it working great now
  10. Sep 13, 2012 at 6:58 AM
    #2650
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I havent watched these yet but Ive seen a lot of their other videos and figured it would be a good place to start.
    http://www.youtube.com/watch?v=ZtVB4IubWyc
    unrelated to your post but I will post this for everyone else bc it really helped me with my stance and grip and I could tell imidiate improvements on recoil and follow up shots.
    http://www.youtube.com/watch?v=FbhmDOY4BeE&list=PL7E3338D8B676DBDA&index=10&feature=plpp_video
  11. Sep 13, 2012 at 12:14 PM
    #2651
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Gotta love bcm, ordered some stuff on the 11th and it showed at my house just now. They know how to get items to you in a timely fashion unlike some companies out there.
  12. Sep 13, 2012 at 2:47 PM
    #2652
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    I have been reading reviews on both of these 16" uppers. The Stag looks to be a better deal since I am getting the charging handle, hand guard, and bolt carrier assembly with it for just a little more than the BCM. The reviews on both are really good it seems like so I am wondering if there is a reason I should opt for the BCM over Stag?
    Stag:
    http://www.stagarms.com/product_info.php?cPath=14_24&products_id=244
    BCM
    http://www.bravocompanyusa.com/BCM-16-Mid-Length-Upper-Receiver-Group-p/bcm-urg-mid-16.htm
  13. Sep 13, 2012 at 5:12 PM
    #2653
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
  14. Sep 13, 2012 at 5:14 PM
    #2654
    Leoffensive
    Leo
    San Diego, CA
    heres a video of me bumpfiring.
    outside of CA(30 round mag)
    before i put all the magpul stuff and eotech on my ar.
    cant do this anymore cause i have the rainier arms xtc comp.
    http://www.youtube.com/watch?v=rYSq9b5Ox0U
  15. Sep 13, 2012 at 7:23 PM
    #2655
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
    I dont think you could go wrong with either. I have the bcm bcg, charging handle and now their 18 barrel of which I just put on. But I'm sure stag is just as good for the price, I just chose bcm cause they had stuff in stock at the time.
  16. Sep 13, 2012 at 7:33 PM
    #2656
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    well, i can tell immediately some differences between the two... the question is, which aligns w/ your desires?
    - the stag is 1:9 twist, the BCM is 1:7
    - the stag has a railed gas block, no front sight, the BCM appears to have a standard front sight base...
    ...so, do you have a preferences on these things?
  17. Sep 13, 2012 at 7:49 PM
    #2657
    SFSMedic
    SFSMedic Well-Known Member
    Brett C
    Corona, CA
    12 4-door 4x4 TRD Offroad
    Stags can be had with 1:7 twist you just pay a fee for that option.
    http://www.stagarms.com/information.php?info_id=13
    Personally I ran a 1:9 with no issues with the 62gr speer ammo I used majority of the time. I went to a 1:8 when I just changed barrels.
  18. Sep 14, 2012 at 5:48 AM
    #2658
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    lol this is the AR BS thread :cool:
  19. Sep 14, 2012 at 6:03 AM
    #2659
    mntbiker2008
    Aaron
    Cincinnati, OH
    I like the railed gas block on the stag because i can put a flip up front sight on it instead. Otherwise, i dont have any preference on the other stuff. I guess i need to read up on the twist differences. I do see that the more common twist is 1:7 though.
  20. Sep 14, 2012 at 6:07 AM
    #2660
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    I love the "outside of CA" comment.
    Are you triing to hide something?!?
