AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Mar 31, 2024 at 2:44 PM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    H3 in my 11.5 H2 equivalent in my 13.7 that runs a vltor buffer system. Heck even running h2 in my 20. All cycle fine with our without the can if anything the 11.5 and 13.7 still a tad gassy with the can but not overgassed enough to impact reliability
    TRD-Troll[QUOTED] likes this.
  2. Mar 31, 2024 at 5:24 PM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    yep, probably need to tune it for your can. I think I'm running H3 and Sprinco spring. Sounds like your over gassed with the can. Same thing happened to me with a 12.5".
    Casper66 and TRD-Troll[QUOTED] like this.
  3. Mar 31, 2024 at 6:36 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Does the bolt hold open on an empty mag? Where does the brass eject? If the barrel is a Colt, I would send it back. I have 8 different DI AR calibers, the only thing that solves overgas is an adjustable block. But then a new barrel is usually cheaper than an adjustable gas block, and less Rube Goldbergish....
  4. Mar 31, 2024 at 7:01 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Locks back on empty mag. Only issue is bolt over base when suppressed. Runs without issue when not suppressed.
    Don’t know the exact ejection pattern since it wasn’t in an area I could locate the brass vs brass already there.
  5. Mar 31, 2024 at 7:16 PM
    golfindia
    Yes.
    pickup truck
    GoPro works great to see what's happening with ejection. 95% of what you need to know will come from where the brass goes. The weight difference between H2 and H3 is only about 0.5 oz. Unless You're on the jagged edge, it won't make a difference.
  6. Mar 31, 2024 at 8:15 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    You might consider replacing the gas block with an adjustable block like this one from Superlative Arms.
    https://www.brownells.com/gun-parts...-parts/ar-15-adjustable-gas-block-.750-solid/
  7. Apr 15, 2024 at 2:12 PM
    N64_Wallmaster
    N64_Wallmaster Carolina Cajun
    Raleigh, NC
    2017 LTD 4WD
    - Bilstein 5100 Shocks - Icon AAL - Old Man Emu 2885 Springs - 16" TRD Bead lock style alloys - bronze - Falken Wildpeak AT3W 285/75 r16 - IFS Skid Plate; Bare Aluminum - Body Armor 4x4 Revo Rock Sliders - Diode Dynamics SS3 Fog Lights w/ Amber Accent Lights - Tacoma Lifestyle Side View Mirror Sequential Turn Signals - Cali Raised LED Bed Channel Supports; added self-adhesive rubber edge trim - AFE Magnum Pro Dry S Filter - LEER 100R Camper Top - Weathertech Window Deflectors - Bulletpoint Mounting Solutions Dash Mount - TRD Pro Grille with Raptor Lights - Headlight H11 to H9 DIY bulb conversion - Diode Dynamics interior and license plate LED bulbs - FBC license plate light DIR - Replaced chrome LTD mirror covers with oe black - Replaced chrome LTD fog light bezel with oe black trim - Meso Customs map and dome lights - Hot Shot Offroad All Lights On - Metal replacement Toyota oil filter housing - VIOFO A119 Mini 2 dash cam
    And it’s finally built. My first AR.
  8. Apr 15, 2024 at 4:42 PM
    Doc Samson
    Doc Samson Well-Known Member
    Almost NoVA
    2009 Tacoma TRD Sport
    None... yet.
    Nice! What type of trigger? Looks like a hybrid between regular and straight...
    N64_Wallmaster likes this.
  9. Apr 15, 2024 at 4:47 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    "First" implies more forthcoming. It sounds like you know how this works. :thumbsup:
  10. Apr 15, 2024 at 5:46 PM
    N64_Wallmaster
    Raleigh, NC
    2017 LTD 4WD
    Thank you! Trigger is a LaRue Tactical MBT-2S. 2-stage trigger that breaks at 4.5 lbs (2.5 lb first stage, 2 lb second stage).
    Casper66 and Doc Samson[QUOTED] like this.
  11. Apr 15, 2024 at 5:46 PM
    N64_Wallmaster
    Raleigh, NC
    2017 LTD 4WD
    Thank you! And absolutely.
    wilcam47 likes this.
  12. Apr 22, 2024 at 6:14 PM
    szidls
    szidls Well-Known Member
    Scott
    Prescott Valley, AZ
    2014 MGM AC TRD OR
    School me on AR mags. I have some Magpul designated for .223/5.56. Also Magpul .762x39 for .300BO. And some Surefeed aluminum mags designated .223,5.56,.300BO. I thought the Surefeed were .300/.762x39 specific when I ordered them. Can or should I run all 3 cartridges out of the Surefeed? Trying to keep my mags caliber specific.
  13. Apr 22, 2024 at 6:16 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    X39 needs different mags
    Some mags may feed 300 or 5.56 but some may not be as reliable hence why magpul has a specific 300blk mag
  14. Apr 22, 2024 at 6:18 PM
    szidls
    Scott
    Prescott Valley, AZ
    2014 MGM AC TRD OR
    The magpul .300 packaging says that. The mag is stamped .762x39
  15. Apr 22, 2024 at 6:27 PM
    szidls
    Scott
    Prescott Valley, AZ
    2014 MGM AC TRD OR
    Actually it’s stamped for both.
    The Surefeed may run all 3 caliber’s?
    montijo505 likes this.
  16. Apr 22, 2024 at 6:27 PM
    JimBeam
    JB
    2015 Tundra
    Re-read it
    300blk has an official 7.62x designation but it's not x39
    X39 requires a much different curve in the shape of the mag body to run
    Chew and szidls[QUOTED] like this.
  17. Apr 22, 2024 at 6:28 PM
    JimBeam
    JB
    2015 Tundra
    Surefeed will probably run 5.56 and 300 fine
    Magpul may or may not
    Neither is going to run x39
    szidls likes this.
  18. Apr 22, 2024 at 6:32 PM
    golfindia
    Yes.
    pickup truck
    762x39 mags will not work with 300blk. Slanted 762x39 cases need the curved mag. 556/223/300blk dont. It says 762x35. Which is 300blk
  19. Apr 22, 2024 at 9:20 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    300 AAC Blackout is also known as 7.62×35mm, which is what is stamped on the mag. Not 7.62x39 the AK round.
    szidls[QUOTED], strider98 and JimBeam like this.
  20. Apr 23, 2024 at 6:04 AM
    JimboJones
    JimboJones A tradition since last week.
    Jim
    Apex NC
    2019 Offroad Magnetic Gray
    Is there any real diff between 300 BLK and 5.56 mags other than possibly the spring strength (300 BLK being stronger)?
