AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Nov 16, 2012 at 4:44 PM
    #3521
    SFSMedic
    SFSMedic Well-Known Member
    Brett C
    Corona, CA
    12 4-door 4x4 TRD Offroad
    The 6.8 with the 140 Berger VLDs with .487 BC is still supersonic at 1K. Pretty much answering anything the Grendel has.
  2. Nov 16, 2012 at 6:44 PM
    #3522
    fjfar80
    fjfar80 Well-Known Member
    Mark
    Fairfax, Virginia
    '09 TRD OR DC
    Total Chaos UCA's, King Coilover Front Suspension w/ Remote Reservoir Shocks, King / OME Dakar Rear Suspension with Remote Reservoir Shocks, DO Front Bumper, BruteForce Custom Rear Bumper, Slee Offroad Sliders, Warn w/synthetic line, Softopper, etc.
    Check out Savvy Sniper...
    - Mark
  3. Nov 17, 2012 at 10:06 AM
    #3523
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I read that the 6.5 does have better bc at longer ranges as well
  4. Nov 17, 2012 at 10:26 AM
    #3524
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    I'm looking to move my scope forward a bit. I'm trying to decide which is the "best" scope mount to get. I've seen the Burris P.E.P.R. mounts, but I've also seen similar designs from Leupold and Nikon.
    Burris: http://www.amazon.com/Burris-410343...e=UTF8&qid=1353172658&sr=1-2&keywords=p.e.p.r.
    Leupold: http://www.amazon.com/LEUPOLD-MARK-IMS-INTEGRAL-RING/dp/B004UMAEXM/ref=pd_sbs_sg_5
    Nikon: http://www.amazon.com/Nikon-827-M-223-Mount/dp/B007PXVQN0/ref=pd_sbs_sg_8
    Any of these better than the others? Any others that you would suggest?
    My current configuration is a PITA to pull the charging handle.
  5. Nov 17, 2012 at 12:43 PM
    #3525
    SFSMedic
    Brett C
    Corona, CA
  6. Nov 17, 2012 at 1:08 PM
    #3526
    CowboyTaco
    North Georgia
    11 TRD Sport
    yeah, but aren't those ridiculously expensive? I'd like to keep it under $100.
  7. Nov 17, 2012 at 1:17 PM
    #3527
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    Buy a BCM charging handle. Instead of buy a $200 mount. And I got to kill a deer with the little 223 ImageUploadedByTapatalk1353187015.564681.jpg
  8. Nov 17, 2012 at 1:17 PM
    #3528
    SFSMedic
    Brett C
    Corona, CA
    Oh, well yeah, if your on a budget then the Burris is my suggestion.
  9. Nov 17, 2012 at 1:25 PM
    #3529
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
  10. Nov 17, 2012 at 1:44 PM
    #3530
    CowboyTaco
    North Georgia
    11 TRD Sport
    over the Leupold? any particular reason why?
    for what its worth, the score is a Redfield.
  11. Nov 17, 2012 at 1:58 PM
    #3531
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    From what I've read on 6.5 vs 6.8 is that 6.8 was a better in a battle rifle while 6.5 had a flatter traj. and better for competition. But I honestly haven't researched too much, I'm in the "5.56 works just fine" camp.
  12. Nov 17, 2012 at 2:27 PM
    #3532
    SFSMedic
    Brett C
    Corona, CA
    No personal experience with the leupold so can't comment.
    The 6.5 better trajectory was true until the recent introduction of the 140 Berger for the 6.8. However that's only one bullet where the 6.5 has several to choose from but does deal with over pressure issues where to hot can and do break bolts.
  13. Nov 17, 2012 at 5:31 PM
    #3533
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Just out of curosity, what is so great about a bcm charging handle?
  14. Nov 17, 2012 at 5:56 PM
    #3534
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    If you click the link there's a lot of info on that page about the theory behind the design if you scroll down. I use the BCM because I like the larger latch design better than other enlarged latches (like the Badger latch, for instance) and the latch also has a "gas buster" effect because of the ridge at the back. Helps keep the blowback out of my face. A true Gas Buster vented latch is closer to $100 though.
    I like the medium BCM Gunfighter. It comes in 3 latch lengths.
  15. Nov 17, 2012 at 6:13 PM
    #3535
    Hunter.V.White
    Hunter.V.White Well-Known Member
    Hunter
    Fairbanks, AK
    2013 DC 4WD TRD-Off Road
    Pelfreybilt Steel Armor, Famous Fabrication Sliders, OME 3" Lift, 886x coils, Dakar Leaf Packs, TC UCA's, Fuel D551 Wheels, 285/70/R17 Toyo Tech RTs, Warn Zeon 10s Winch, Rigid Industries 20" E2 Flood, RI 20" SR Spot/flood, RI Duallys, SwitchPro SP8100, Uniden Bearcat 680 CB Radio.
    I finished building the lower to my AR-15 today. The notable parts are:
    Lower:
    Noveske Gen II Lower
    Noveske H-buffer
    Magpul Ambidextrous Sling Adaptor
    Magpul STR Mil-Spec Carbine Stock
    CMMG AR-15 Lower Parts Kit
    Troy Industries Ambidextrous Safety
    Geissele SSA-E Two Stage Trigger
    Magpul MIAD Mission Adaptable Grip
    Magpul B.A.D. Lever
    Magpul 30 Round PMag with Ranger Plate
    I also have a Vultor MUR-1 Upper and BCM Gunfighter Charging Handle shown in the pictures below
    Now All I have left is to finish the upper and add-on's...
    Upper:
    Vultor MUR-1 Upper
    Noveske N4 Light 5.56MM Barrel - 16"
    SureFire SF3P-556-1/2-28 Flash Hider / Suppressor Adapter
    Adams Arms Mid-Length Piston Conversion Kit
    Samson 9 inch quad rail
    FailZero 5.56MM Bolt
    Add-on's:
    Troy Folding Battle Sight Set
    Magpul AFG2 - Angled Fore Grip
    EOTech 553
    SureFire X300 LED WeaponLight
    SureFire XT07 Remote Dual Switch for WeaponLights
    Cobra Adjustable One Point Sling
    SureFire SOCOM556-SB Sound Suppressor (eventually)
  16. Nov 17, 2012 at 9:10 PM
    #3536
    SFSMedic
    Brett C
    Corona, CA
    Nice list. Spared no expense. I have 2 questions.
    1st for the young bolt are you going phosphate or chrome, standard M16 or NM and I assume you meant BCG or if you only meant bolt whose carrier and internals are you going to use?
    2nd: why the surefire flash hider over the break? This one is just a curiosity thing.
  17. Nov 17, 2012 at 10:07 PM
    #3537
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Like the vltor. Thanks for supporting a tucson company.
  18. Nov 18, 2012 at 5:13 AM
    #3538
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    ImageUploadedByTapatalk1353244335.372005.jpgImageUploadedByTapatalk1353244348.870071.jpg
    With a low mount optic it makes the charging handle usable in my case. This is the Large handle
  19. Nov 18, 2012 at 8:27 AM
    #3539
    Hunter.V.White
    Hunter
    Fairbanks, AK
    Yea, this build is really expensive :) but I wanted to do if for myself (present to me!) I've wanted an AR-15 since I knew they existed. When I finally started getting serious about buying one, and I started doing research into what "built" rifle I wanted, I realized that I wanted so many different things I just figured it would be better [and cheaper] to build one from scratch. Needless to say, it will be an awesome rifle when I finish it.
    Answer 1: I am going to try and get a chrome bolt. I've heard that they resist carbon build-up a lot better than standard bolts. As far as the phosphate coating, I don't have too much experience with them so I don't know how it would do with carbon and normal wear. I will be getting a standard M16 bolt, but I don't know what you mean by "NM". The Adams Arms piston conversion kit comes with a one piece bolt carrier group, so I only need to buy a bolt in addition. I'm not stuck on Young manufacturing, but I wanted a chrome bolt - even though I know it won't see much carbon with the piston system.
    Answer 2: Thinking long term, I would like to eventually add a SureFire SOCOM556-SB Sound Suppressor, so getting a surefire flash hider / break will be the perfect interface to attach the suppressor. I chose the flash hider instead of the break because it will probably be a while before I could get the suppressor (conceals flash) and I wanted something to conceal flash (SHTF scenario). When I finally get a suppressor, I will probably move to the break because if I want flash suppression, I can put the suppressor on. If I get into 3 gun competitions like I want to, I will probably end up buying both to be honest.
  20. Nov 18, 2012 at 11:45 AM
    #3540
    Polymerhead
    Missouri
    You might consider a 16" barrel then. If you go 14.5", you have to pin & weld the flash hider on. Switching it out for a brake would mean grinding off the weld, getting the pin out, repinning and rewelding. You'd definitely have a messed up flash hider and would need to be careful not to damage the barrel.
