AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Feb 17, 2013 at 8:33 PM
    #6061
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    Pretty sure that's at every Walmart... Shelves have been empty everywhere for a while. Can't even go shooting without buying range ammo at 400% markup
  2. Feb 17, 2013 at 9:14 PM
    #6062
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    Nice ;)
  3. Feb 17, 2013 at 9:17 PM
    #6063
    double dee
    double dee Well-Known Member
    Arizona
    Tell me about it! 9mm target ammo is at least $15 a box now. I've even seen it for $20! I'm glad I bought 1000 rounds for $10.50 a box in December but I'm hoarding the stuff now. lol
  4. Feb 17, 2013 at 9:18 PM
    #6064
    RevAdam
    Adam
    Upstate SC
    11 TRD OR 4x4
    Please don't contribute to the problem...
  5. Feb 17, 2013 at 9:21 PM
    #6065
    TJBJ11
    TJBJ11 Town Drunk
    Tim
    Northern VA
    '12 AC Offroad Barcelona Red
    black TRD OR bedside decals, trd exhaust, tailgate clamped, CB
    I have a smith and Wesson m&p 15. Input it after Election Day. Everyone thought it was a crazy thing to do and all I said was "I better get one before Inauguration Day. Now who's crazy?
  6. Feb 17, 2013 at 9:25 PM
    #6066
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Thanks
  7. Feb 18, 2013 at 9:14 AM
    #6067
    98ToyWheeler
    98ToyWheeler Well-Known Member
    Tyler
    98 SR5 4x4
    JVC head unit, Polk audio Speakers (front), Pioneer (rear), FLI Trap Passive 12 Sub, Fixed Window strip,Tool box, Plasti Dipped Grille, emblems, bumpers, and fender pieces, python keyless entry and alarm
    Hey guys! I know for some of you magazines are a bit hard to find!
    I ordered from a site called shop.awbprepper.com last week.
    They were very professional, had fast shipping, and the products were as described.
    They have better pricing than all of the gun shops around me right now.
    Hope this can help some of you out!
  8. Feb 18, 2013 at 9:34 AM
    #6068
    double dee
    Arizona
    I think you misunderstood that. I just meant I don't want to shoot the ammo I already have since its so expensive to replace.
  9. Feb 18, 2013 at 9:42 AM
    #6069
    RevAdam
    Adam
    Upstate SC
    11 TRD OR 4x4
    I don't think "I'm hoarding the stuff now." is easy to misunderstand...
  10. Feb 18, 2013 at 9:45 AM
    #6070
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    Pros and cons of Magpul VS Promag? Anyone?
  11. Feb 18, 2013 at 10:06 AM
    #6071
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Got to finally shoot my AR. started off a little rough. The BCG is quite snug so I am having issues with feeding. It won't go into battery so I have to use the forward assist to engage it. Than from there everything fires great. Zeroed the iron sights at 50 yards and was stacking bullets and groupings were smaller than a quarter. So I am extremely happy with how accurate it is. Now just need to break it and and the the BCG moving skittle better.
  12. Feb 18, 2013 at 10:49 AM
    #6072
    RevAdam
    Adam
    Upstate SC
    11 TRD OR 4x4
    Your BCG should slide freely in the upper, and go into battery without using the FA. Make sure you're not getting gas tube contact....
    Remove the bolt, and see if the carrier is free in the upper. If your gas tube is blocking the smooth action of the carrier, you may need to adjust it. If it is a bolt lock up problem, you may have something wrong with the bolt or barrel extension.
  13. Feb 18, 2013 at 11:04 AM
    #6073
    rmb_crew
    Everything is correct as far as the gas tube. i took a different BCG and slid it in and it is completely smooth and fine. The BCG that i have the bolt and gas rings are very tight and takes some force to move the bolt in and out of the carrier. Also the firing pin cam was lop sided when i got it and i had to remove some metal off one side if it to allow it to slide back and forth. And the more and more it has been moved in and out and fired the easier it is getting. So i am just going to keep running rounds through it and might take a file to some of the edges tonight. there are a couple small wear spots on it already so i am figuring that could be a cause also. So everything is pointing to a fitment issue with the BCG and the upper and gas tube are good.
  14. Feb 18, 2013 at 11:22 AM
    #6074
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Did you buy it new or used? Id send it in for warranty.
  15. Feb 18, 2013 at 11:26 AM
    #6075
    rmb_crew
    New but it was built by me.
  16. Feb 18, 2013 at 11:35 AM
    #6076
    rmb_crew
    And the carrier by itself is completely smooth. i add just the bolt, no cam or firing pin and its still fine than than with the cam in it starts to get alittle snug. i am gonna go pick up another cam and see if that helps.
  17. Feb 18, 2013 at 11:39 AM
    #6077
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    Ya there is a fault somewhere in there. It shouldn't ever feel snug and like something is rubbing. It should feel smooth no matter what. Even after shooting 500 rounds through mine it still feels smooth
  18. Feb 18, 2013 at 12:13 PM
    #6078
    rmb_crew
    Yeah i am gonna see what i can find by changing out a few things.
    On a side note i did get to shoot a SCAR with a can on it. it was pretty sweet. kinda heavy and it was more difficult to shoulder it and stay accurate. I would never buy one but it was pretty cool to shoot.
  19. Feb 18, 2013 at 1:04 PM
    #6079
    rmb_crew
    All better now. Smoothed out the firing pin cam and found a small spot on the carrier key that had a lot of wear so obviously making contact so i shaved it down a touch and smoothed it all out and now the BCG is completely smooth and doesnt hang at all.
  20. Feb 18, 2013 at 2:49 PM
    #6080
    RevAdam
    Adam
    Upstate SC
    11 TRD OR 4x4
    Is the carrier key on straight?
