AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. May 28, 2013 at 9:46 AM
    #7021
    TruckyTruck
    TruckyTruck Well-Known Member
    Tundra Crewmax TSS Off-Road 4x4, sr5/leather
    Thank you, sir!
  2. May 28, 2013 at 10:09 AM
    #7022
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
  3. May 28, 2013 at 10:15 AM
    #7023
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  4. May 28, 2013 at 10:37 AM
    #7024
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    From the research I did c-products and ASC mags seem to work the best.
  5. May 28, 2013 at 1:32 PM
    #7025
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I went to a "Military Surplus" store today. I asked the guy what he had for AR's
    he showed me some no name aluminum mags for $27 each or the military issue pmags for $65. I didn't know magpul was military issue, And honestly I haven't checked but I was floored when I saw the prices he was asking. Carry on.....
  6. May 28, 2013 at 7:06 PM
    #7026
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    Is it safe to put a couple drops of oil into the gas tube while it is on the rifle? I mean, will it go :boom: when it is shot? I was cleaning, and thought it would be a good idea..
  7. May 28, 2013 at 7:10 PM
    #7027
    95 taco
    95 taco Battle Born
    I don't know.
    I'd blow out the gas tube with a air hose just to be safe.
  8. May 28, 2013 at 7:20 PM
    #7028
    mjm540ii
    Oxford, PA
    ive never taken out the gas tube, and unsure how :notsure:
  9. May 28, 2013 at 7:33 PM
    #7029
    95 taco
    95 taco Battle Born
    i dunno either, you could pull the BCG and Just blow it that way :notsure:
  10. May 28, 2013 at 7:42 PM
    #7030
    quantum
    quantum Well-Known Member
    no need to unless there is a problem, its one roll pin on the gb/fsb
  11. May 28, 2013 at 7:43 PM
    #7031
    quantum
    don't blow it back into the barrel, if anything, tape off one end of the barrel (either crown or breach) and blow it out towards the upper receiver
  12. May 29, 2013 at 4:35 AM
    #7032
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Curious why? I'd rather have that crap in the barrel where a quick run of a cleaning patch would run it out the muzzle, than up in my upper receiver.
    MJM - no real need to lube your gas tube. If you're set on cleaning it, use a thick pipe cleaner.
  13. May 29, 2013 at 4:39 AM
    #7033
    mjm540ii
    Oxford, PA
    Thanks guys, I should've asked before I did that. But with only 2small drops, I should be ok. I will hit it with a pipe cleaner tho, and should be good after that.
  14. May 29, 2013 at 5:41 AM
    #7034
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    wow! Yea Pmags have national stock numbers for .mil ordering now. Pretty cool.
    We dont have any here at Sheppard yet but we are in the process of phasing out old mags with the green followers and replacing them with the tan follower mags.
  15. May 29, 2013 at 7:00 AM
    #7035
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    Why are you sticking pipe cleaners in your gas tube? The 55,000 PSI of superheated air that is blown down that tube every time you pull the bang switch is more than enough to keep it clean.
  16. May 29, 2013 at 8:02 AM
    #7036
    quantum
    i just have a "policy" of never introducing anything into the barrel unless i have to. i'd rather blow crap into the upper receiver and wipe it out than down the barrel. not claiming any "logic" there, just my personal preference.
  17. May 29, 2013 at 5:32 PM
    #7037
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    my paper weights came in today:
  18. May 29, 2013 at 5:35 PM
    #7038
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    :cheers:
  19. May 29, 2013 at 8:46 PM
    #7039
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    How much if your don't mind me asking?
  20. May 29, 2013 at 8:56 PM
    #7040
    Sintoy
    Sintoy Member
    Las Vegas
    2018 TRD
    None Yet
    DPMS LR 308b. Magpul stock, timney match trigger, harris bipod. Leupold VX1.
    This is my 1000yd rifle. Handloads 168 SMK 44.3gr Varget.
