AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Jun 7, 2013 at 3:30 PM
    #7101
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    If you aren't happy with them you can send them to me for "permanent testing" :D
  2. Jun 10, 2013 at 9:10 AM
    #7102
    akcaliswag
    akcaliswag Member
    Cole
    Oak Harbor
    DCSB
    BHLM
    Shit happens man. I'd save up and snag a set of Troy Battle Sights but thats just my $0.02. Nice looking gun, dig the BCM BCG. Seeing as how you are in Hampton Roads though if you have a buddy in the service you can snag a set at MCX Camp Allen for around $130. They have great prices on black rifle accesories but their guns & ammo prices are ridiculous.
  3. Jun 10, 2013 at 9:27 AM
    #7103
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    My most recent 7.62x39 Adams Arms Piston AR with new furniture. Still have mag problems, double feeding and stuff, gotta find me some quality mags for the russian ammo.
    8F2AE51F-9B8B-4533-AD79-49EB6BA859FE-182_9df86883e78b650f1cfb433780dcfebb9ec6fa52.jpg
  4. Jun 10, 2013 at 2:30 PM
    #7104
    akcaliswag
    akcaliswag Member
    Cole
    Oak Harbor
    DCSB
    BHLM
    If you're there for a while just keep your eyes open MCX Camp Allen has good prices on Accesories but that's it. The guys over at Bob's Gun Shop in downtown Norfolk are always great for help and I have heard really good things about the guys at The Armory.
  5. Jun 10, 2013 at 6:26 PM
    #7105
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    Marine PX in Norfolk has some in stock! Was there yesterday
  6. Jun 11, 2013 at 3:02 PM
    #7106
    blackhawke88
    SGV, CA
    07 TRD Offroad
    whats the most common cause for these kinds of FTFs?
    I think i fixed my short stroking problems with the lighter spring but i get these FTFs quite a bit or double feeds.
  7. Jun 11, 2013 at 3:10 PM
    #7107
    SFSMedic
    SFSMedic Well-Known Member
    Brett C
    Corona, CA
    12 4-door 4x4 TRD Offroad
    Dirty guns, bad mags. Those are the easy ones.
    You put a lighter spring but let me ask you what buffer you were/are using.
  8. Jun 11, 2013 at 3:12 PM
    #7108
    blackhawke88
    SGV, CA
    07 TRD Offroad
    it is the non-marked standard carbine buffer. I did notice the wolf reduced power spring was a lot longer than the spring that came in my LPK. Brownells didnt specify whether the wolf spring was for a carbine buffer or rifle length buffer. It was just really really long. I have a rifle buffer I might try with the wolf spring to see if it works differently, but it definitely doesnt short stroke anymore, at least as far as i can tell.
  9. Jun 11, 2013 at 3:16 PM
    #7109
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    N-fabs, BakFlip VP, power tailgate lock, bed lights, "raptor" grill lights. Standard mall crawler stuff.
    I took some 400 grit sandpaper to my feed ramps just to clean up the edges when mine was new, worked great after that.
  10. Jun 12, 2013 at 6:11 AM
    #7110
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Mags would be the first thing I would look at. try several different ones including pmags.
    clean the bcg realy good and lube her up while your at it.
    also you shouldnt have to run different springs or buffers on a factory rifle. If different mags dont fix it I would send her in to manufacture and have them fix it.
  11. Jun 12, 2013 at 6:21 AM
    #7111
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    Looks like a bad mag spring. You might try a heavier buffer to increase carrier dwell, but that's a bad mag spring.
  12. Jun 12, 2013 at 7:07 AM
    #7112
    LaRue Shooter
    LaRue Shooter "Keep your dick in a vise."
    Southern Cal
    Built up, locked 06 Sport Access Cab
    Trijicon sticker on rear window.
    First pic was a short stroke.
    Other questions are, how old is the gun? Is it broken in? Did you give the surfaces a chance to wear in before you started swapping out parts? What kind of lube are you using? Gun lube, I mean.
  13. Jun 12, 2013 at 9:24 AM
    #7113
    blackhawke88
    SGV, CA
    07 TRD Offroad
    It's not really a factory rifle. The upper is an Adams Arms 7.62x39 piston, and the lower is just a poly lower that I built from a stripped lower and PSA parts kit. I knew from the get go that there was going to be some fine tuning to get the set up to work properly. I've read on some forums that piston kits require less buffer and spring resistance because there is a lot more weight and resistance in the action.
    The gun is pretty new, probably less than 600 rounds through it. Right off the bat, with the lower i built, it was short stroking every round, so I read up on it and swapped to a wolf reduced power spring, which cured the short stroke problem. I've been using Break Free CLP for all my guns. The AR has been staying really really clean after each outing, but I still clean it out. Most if not all the fowling inside the upper after shooting is just little shards of metal from the casing when they are being cycled i guess.
  14. Jun 12, 2013 at 9:43 AM
    #7114
    SFSMedic
    Brett C
    Corona, CA
    Humor me. Try a different carrier. I saw this behavior happen due to a carrier bing machines wrong where the key mounted. It only happened once and you asked for common but it never hurts to try.
    On another note got out to the rockpile in corona to test some new load work ups for an upcoming Texas pig hunt.
    6.8x43 SSA case, CCI41, AA2200 27.2 Hornady 120SST. 100yards. 5 rounds.
    Good improvement over this target which was .2 grains less of AA2200.
    Headed back out this weekend to adjust zero and chrono as well as get drops from 50 to 300 with a 200 yard zero.
    A pic of the rifle I hunt with.
  15. Jun 12, 2013 at 11:18 AM
    #7115
    SFSMedic
    Brett C
    Corona, CA
    See the difference? Real vs not so real?
  16. Jun 12, 2013 at 11:25 AM
    #7116
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    comparison
  17. Jun 12, 2013 at 11:54 AM
    #7117
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    The tan one is definitely fake. The edges around the magpul logo looks too rounded and most of the fake ones don't have thread locker on the bolt
  18. Jun 12, 2013 at 12:00 PM
    #7118
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
  19. Jun 12, 2013 at 12:44 PM
    #7119
    SFSMedic
    Brett C
    Corona, CA
  20. Jun 12, 2013 at 1:11 PM
    #7120
    RevAdam
    Adam
    Upstate SC
    11 TRD OR 4x4
    Well, THERE'S your problem...
