AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Aug 18, 2013 at 11:40 PM
    #7421
    SGT Taco
    SGT Taco It all fun and games till its not.
    Scott
    Spring Hill TN.
    R.I.P. 2007 TRD, Land Rover Disco II, F250.
    Wife rolled it 3x mod...
    Have green and brown.
  2. Aug 19, 2013 at 7:24 AM
    #7422
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    green followers should be a little less. they are being cycled out of stock from .mil and being replaced with the tan follower mags
  3. Aug 19, 2013 at 3:40 PM
    #7423
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    sweet, with the new ASC mags, my 7.62x39 piston AR finally works. Now my only problem is light primer strikes with the russian ammo. Probably need to pick up a wolff heavy hammer spring somwhere.
  4. Aug 19, 2013 at 4:02 PM
    #7424
    quantum
    quantum Well-Known Member
    i don't know if it would help, but for AR uppers chambered in 5.45, alot of guys swear by Geissele triggers for surplus ammo
    in case you were wanting the $200 solution :|
  5. Aug 19, 2013 at 4:09 PM
    #7425
    Anteupp
    Anteupp Mega Member
    got bored and ripped off all the old magpul FDE funiture and put the my old stuff back on to make it an evil black rifle again. YHM free float, OE gip, and stock. Not sure which look I like better...All black is just sooper tacticool :p
  6. Aug 19, 2013 at 4:55 PM
    #7426
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Random photo - the long & short of it. 11.5" SBR & 16" cheapo build for a truck/coyote gun.
    5C5B6661-6287-4829-B096-6B26F5F28234-138_1e1f6578255add2c74fd241300b52bd861d91d00.jpg
  7. Aug 19, 2013 at 7:35 PM
    #7427
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    Ordered the parts for me to put together my lower this morning, should only need a complete upper and charging handle once the stuff I ordered comes in. Building my first AR...I think this may end up addictive
  8. Aug 20, 2013 at 10:21 AM
    #7428
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    I just bought a lower, time to start making a parts list.
    Any recommendations are welcomed.
    I am going to build the lower first and then do a free float upper.
  9. Aug 20, 2013 at 11:51 AM
    #7429
    SFSMedic
    SFSMedic Well-Known Member
    Brett C
    Corona, CA
    12 4-door 4x4 TRD Offroad
    I have An Enhanced Lower Parts Kit I sell that uses a Battle Arms Development ambi safety and ALG QMS trigger with options to upgrade to Geissele triggers.
    http://shop.ironworkstactical.com/ProductDetails.asp?ProductCode=AOI-LPK-E
    Or a bare bones kit without trigger set and grip so you can choose your own parts.
    http://shop.ironworkstactical.com/ProductDetails.asp?ProductCode=AOI-LPK-BB
    Amongst many other parts to choose from.
  10. Aug 20, 2013 at 12:48 PM
    #7430
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    +1billion for brett at ironworks!
  11. Aug 20, 2013 at 1:23 PM
    #7431
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    Which geissele trigger do you reccomend?
  12. Aug 20, 2013 at 1:54 PM
    #7432
    SFSMedic
    Brett C
    Corona, CA
    Depends on what you're doing really. I use a SSA-E for my hunting rifle as it has a nice light break. I use a SSA for a carbine of mine but I'm also very used to light triggers on my run and gun firearms. I also run the ALG QMS on a carbine of mine which is tuned by Geissele but more of a clean heavier trigger 4.5-5.5 lb pull. I really like this trigger a lot for the price and slightly heavier pull weight for a combat or duty type rifle as its not as light or sensitive as the two previously mentioned.
    The SSA and SSA-E have definite breaking points as does the G2S (a less expensive SSA basically). The S3G does not and is very hair triggerfish feel, I do not recommend it unless you have tons of training under your belt (I don't even personally like it). My buddy runs it and loves it but it definitely takes some getting used to.
    I hope that info helped. If not ill try again.
  13. Aug 20, 2013 at 6:00 PM
    #7433
    Polymerhead
    Missouri
    Last iteration for a while. Goal is a truck gun that will ring a 3 MOA gong out to 300 yds. The 1-4x Vortex should be enough magnification and the chrome lined barrel is far more accurate than it should be for the brand it was sold under. It's got a suppressor mount on it but it'll be zeroed for use without. I'll make a note of comeups for use with a can, at least on the vertical. A Geissele SSA keeps the groups tight with 62 gr OTMs loaded over TAC.
    318DD773-D980-4DBC-AF79-1928B828FE02-150_27cbeeb0642959d7a2de29cc7cb7413bffecc3a4.jpg
  14. Aug 21, 2013 at 6:35 AM
    #7434
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Nice. Info on the barrel you mentioned?
  15. Aug 21, 2013 at 6:50 AM
    #7435
    Ragin Devildoc
    Ragin Devildoc MOLON LABE
    Doc
    Grunt Life
    12 Prerunner DCSB SR5
    16x8.5 level 8 guardian w/ hankook dynapro atm rf10, aFe pro dry s, flowmaster dbx exhaust, debadged, 2nd air filter removal
    First builds I normally recommend people use PSA since they are quality parts and customer service is reasonable. No offense to Brett and Ironworks since I do not know the products so I can't saying pro/con about him. I have finished a total of 9 ARs in the past year and can say without a doubt that my PSA experience has been awesome. Normally I can finish a quality rifle for under $700. Any extras get added on later, though lately I have been selling them to friends and family for at cost or a little more. Building your AR will become addictive as anyone who has finished one will tell you and your not going to settle for that 1. Good luck on it. I have just finished my first SBR and can't wait for the next one to be done; damn ATF takes their time on the stamps! lol
  16. Aug 21, 2013 at 6:52 AM
    #7436
    fjfar80
    fjfar80 Well-Known Member
    Mark
    Fairfax, Virginia
    '09 TRD OR DC
    Total Chaos UCA's, King Coilover Front Suspension w/ Remote Reservoir Shocks, King / OME Dakar Rear Suspension with Remote Reservoir Shocks, DO Front Bumper, BruteForce Custom Rear Bumper, Slee Offroad Sliders, Warn w/synthetic line, Softopper, etc.
    I'll hop on this one - Geissele triggers are great...but, I highly recommend shooting a few different ones to get the feel that you are most comfortable with.
    I personally shoot the SD3G, SDE, and SDC on all of my guns. I find the straight triggers allow a better precision shot (straight and light trigger pull) at long distances and the short reset and crisp / light break allow me to shoot very quickly and accurately at short distances.
    The SSA is a good all around trigger and has a heavier feel / break than the SD series. As Brett said...training and your skill with the AR platform should absolutely play into your trigger decision.
    The great thing about triggers is you can always upgrade / change them out when you feel you've reached a different level or want to go for a different setup.
    - Mark
  17. Aug 21, 2013 at 12:14 PM
    #7437
    Whitster
    Whitster Well-Known Member
    Whit
    Golden, CO
    '09 AC w/SR5 & TRD, 6' bed
    A few weeks ago I bought a pair of new 'Double D' AR-15 Lowers, at introductory price, thinking I was going to build up a .22 and .308 AR.
    Decided not to. Haven't tried to build them up, still in wrappers. I've got $370 in them and will sell them for $350 for the pair if interested. They are consecutively numbered. Buyer responsible for transfer and fee in Denver area.
    There was a bunch of chatter and development pics on the CO-AR-15 forum:
    http://www.ar-15.co/threads/101901-U...UPDATE!!/page6
  18. Aug 21, 2013 at 4:03 PM
    #7438
    Polymerhead
    Missouri
    It's a chrome lined Del Ton, 1:7", M4 contour.
  19. Aug 21, 2013 at 7:25 PM
    #7439
    SFSMedic
    Brett C
    Corona, CA
    None taken sir. I value others opinion and recommend people go where they are happy and comfortable as well.
  20. Aug 22, 2013 at 10:11 PM
    #7440
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    I can vouch for Brett, totally stand up guy and an asset to the AR community. If you decide on a caliber other than 5.56, he's who you want to talk to, and an expert on the Republic of California's archaic law system.
    I too would recommend PSA, I use them for all my vanilla builds these days and have even SBR'd a few of them. Great spec lowers.
    If you want something exotic, go with the Noveske. That way if you want to sell it, that name makes it worth more than most.
