AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Oct 16, 2013 at 2:30 AM
    #7601
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    He had to hit my charging handle on my ak with my mosin too.
    Second use for a mosin. Clear stuck casing in ak...
    Third use. Leverage tool to lift the bolt on another mosin.
  2. Oct 16, 2013 at 3:26 AM
    #7602
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
  3. Oct 16, 2013 at 6:57 AM
    #7603
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
  4. Oct 17, 2013 at 6:17 AM
    #7604
    hillbillytoyo
    hillbillytoyo Well-Known Member
    Daniel
    WV
    17 Tundra Crewmax SR5 TRD Off Road.
    G2 bed cover
    I'm looking for a good pistol caliber carbine, any suggestions? What about the conversion kit for the glock?
  5. Oct 17, 2013 at 7:19 AM
    #7605
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    MP 15-22 :cool:
  6. Oct 17, 2013 at 8:57 AM
    #7606
    hillbillytoyo
    Daniel
    WV
    G2 bed cover
    I was thinking more like 9mm or .40
  7. Oct 17, 2013 at 9:03 AM
    #7607
    quantum
    quantum Well-Known Member
    are you wanting to buy a whole, complete rifle or are you open to building one?
  8. Oct 17, 2013 at 9:28 AM
    #7608
    hillbillytoyo
    Daniel
    WV
    G2 bed cover
    Either way.
  9. Oct 17, 2013 at 9:43 AM
    #7609
    quantum
    personally, i'd get a stripped lower, 9mm parts kit and slap something like this on it
  10. Oct 17, 2013 at 10:33 AM
    #7610
    hillbillytoyo
    Daniel
    WV
    G2 bed cover
    I'll check into it.
  11. Oct 17, 2013 at 10:54 AM
    #7611
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    i think id pick up a sub2k in 9mm and a glock in 9mm then you can use the same mags for both
  12. Oct 17, 2013 at 1:26 PM
    #7612
    hillbillytoyo
    Daniel
    WV
    G2 bed cover
    I already have several Glocks and that is kinda the ideal. Has anyone tried the Mechtech upper that you just match with a Glock lower?
  13. Oct 17, 2013 at 3:06 PM
    #7613
    Eternal24k
    Eternal24k Well-Known Member
    Vermont
    2009 SR5 V6 4x4
    I have a good amount of experience with building 9mm ARs, if i were to do it again or make a recommendation it would be to buy a 9mm AR and then adjust as you see fit. Then if the damn thing doesnt run right you can send it back to the company rather than spends months and dollars tweaking the combination of parts. It is nothing like the .223/5.56, there really isnt any standard.
  14. Oct 19, 2013 at 8:38 AM
    #7614
    Whitster
    Whitster Well-Known Member
    Whit
    Golden, CO
    '09 AC w/SR5 & TRD, 6' bed
    I've just received a PSA Lower Build Kit for my first build. I acquired an 'AR Complete Assembly Guide' by Kuleck and McKee. In it they stress using roll pin starter punches, particularly for Bolt Catch roll pin insertion, etc. I didn't have a set of these but do have a 36-piece set of Harbor Freight's Security Bit Set, HF still has them for about $6. Radio Shack (you have questions?...we have blank stares) used to carry them too, dunno if they still do or not.
    These have a number of bits that seem to accept the roll pins quite readily and excellent for 'starting' these in the holes, then I use my assortment of punches to seat the pin.
  15. Oct 19, 2013 at 9:46 AM
    #7615
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Make sure you at least consider the 300 BLK. More energy than a pistol, more versatile, and plays nicer in the AR platform. The only specialized part is the barrel. Everything else is off-the-shelf AR15. You can run 220 gr subs and emulate pistol performance or upload it to AK-type ballistics. About the only thing it can't do yet that a pistol carbine can do is deliver a cheap, expanding bullet designed to work at subsonic velocities. 90 gr XTP might be the closest at this point.
  16. Oct 19, 2013 at 1:33 PM
    #7616
    hillbillytoyo
    Daniel
    WV
    G2 bed cover
    I have an AR in 223/5.56 the whole reason for wanting a 9mm or .40 is so I can buy bulk ammo for both my rifle and my sidearm. I would prefer a rifle that tanks Glock mags because yes I'm a "Glock Guy".
  17. Oct 19, 2013 at 1:43 PM
    #7617
    Polymerhead
    Missouri
    Makes sense. I considered a pistol carbine for a long time but I came to the conclusion that it was a lot of expense to build a gun that shoots the same thing as my much smaller/lighter pistol. I couldn't justify it, even as an SBR.
    You might consider SBRing a Glock & running one of the conversions. Nothing is going to be more reliable with a Glock mag than a Glock.
  18. Oct 19, 2013 at 1:53 PM
    #7618
    hillbillytoyo
    Daniel
    WV
    G2 bed cover
    I have been thinking about that but I don't know anyone who has experience with a conversion. Kinda scares me.
  19. Oct 20, 2013 at 7:49 AM
    #7619
    quantum
    not mine, from another forum:
    483F2E6C-3201-4063-ADD0-CDDB67527D5E-152_3cca66036e67c17f12018467fbb9bb21080eee94.jpg
    6B427C71-9B32-4DC1-9ABB-9D28496F3CBE-104_680b5ce9e70cbbeb394ef5d0ac222d32ff27f9ea.jpg
  20. Oct 21, 2013 at 5:22 AM
    #7620
    Eternal24k
    Vermont
    2009 SR5 V6 4x4
    From what I hear the DDLES Glock lowers can be problematic with the bolt catch. The plastic follower design and sprig strength has a hard time engaging the bolt stop. My buddy just sold his to go back to Colt pattern mags
