AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Feb 10, 2014 at 1:13 PM
    #8481
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'll take a look at those for next time, thanks!
    Yeah, and nothing worse than thinking you're finished but still have parts left over :laugh:
    What I still don't quite understand is, even without the disconnect spring, everything still functioned. Safety worked, trigger worked (trigger was actually softer). Still researching what actually happened, good info on other forums about it.
  2. Feb 10, 2014 at 1:18 PM
    #8482
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    IIRC, disconnect should keep your AR in single shot mode. If you forget to put it in, you might end up with uncontrollable fire since it doesnt keep the trigger locked back after each shot.
  3. Feb 10, 2014 at 1:22 PM
    #8483
    Pugga
    Massachusetts
    That's pretty much what I'm finding. There seems to be some debate as to whether or not it could create an unsafe condition also. Something about the hammer following the bolt and creating a light primer strike. Oh well, definitely want it done right so everything is installed as it should be.
  4. Feb 10, 2014 at 4:56 PM
    #8484
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    Just got my new timney trigger installed. It is awesome, much better than my PSA trigger group, I got the single stage 4 lb trigger (may be 4.5), it is awesome!
  5. Feb 10, 2014 at 5:10 PM
    #8485
    DougDeBonet
    DougDeBonet Well-Known Member
    Doug
    Long Island, NY
    2014 TRD Off Road
    Too expensive haha. I'm gonna get a CMC flat trigger when I have the money 3.5# break and $120
    Timney is hella nice though, just wouldn't use it in a SHTF gun since it's a comp trigger.
  6. Feb 10, 2014 at 5:36 PM
    #8486
    crazyengineer
    patrick
    Bristol, TN
    It's in my pet build, and besides, I had a 50$ gift card and an NRA instructor discount from brownells
  7. Feb 10, 2014 at 6:46 PM
    #8487
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    A better trigger is the #1 modification I recommend to friends when they want to build an AR. I use the Geissele SSA on all my builds, but the Timney, CMC, etc are all great options.
  8. Feb 10, 2014 at 6:58 PM
    #8488
    crazyengineer
    patrick
    Bristol, TN
    I almost got the geissele flat trigger over the timney but the price was a little more than I had
  9. Feb 10, 2014 at 11:40 PM
    #8489
    DougDeBonet
    Doug
    Long Island, NY
    2014 TRD Off Road
    Welp can't go wrong with $50 off haha.
  10. Feb 11, 2014 at 1:08 AM
    #8490
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I used the parts sheet thingy to make sure i had all the right parts, watched a youtube video, then face timed with my cousin while i did it so he had a better idea when he helped his brother build his.
  11. Feb 11, 2014 at 8:52 AM
    #8491
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    what yard-age do you all have your AR's sighted in at? mine is currently sighted at 100yds, but i'm contemplating re-sighting it at 50yds. that way i can aim slightly low at shorter distances, and aim slightly higher for longer range.
    this is with a sightmark ultrashot holographic sight
  12. Feb 11, 2014 at 8:53 AM
    #8492
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Mine are at 50 yards
  13. Feb 11, 2014 at 8:59 AM
    #8493
    Detective_Dan
    Colorado Springs
    thats what im thinking would be best
  14. Feb 11, 2014 at 11:48 AM
    #8494
    DougDeBonet
    Doug
    Long Island, NY
    2014 TRD Off Road
    Mine are at 50/200 (same bullet trajectory), and you'll be aiming low for 100 because of the trajectory path, bullet rises after 50, then drops somewhere past around 125. As shown in the green path below. 50 is a combat sight in because of the range it covers. :)
  15. Feb 11, 2014 at 12:13 PM
    #8495
    blackhawke88
    SGV, CA
    07 TRD Offroad
    nvm found it
  16. Feb 11, 2014 at 12:35 PM
    #8496
    Detective_Dan
    Colorado Springs
    i actually never knew that, good to know info.
    so if i sight in @50yds, the bullet will impact where my dot is at 50 and 200 yds, but slightly high at 100?
    just making sure i understand this properly lol
  17. Feb 11, 2014 at 12:51 PM
    #8497
    DougDeBonet
    Doug
    Long Island, NY
    2014 TRD Off Road
    Yes :)
  18. Feb 11, 2014 at 12:52 PM
    #8498
    Detective_Dan
    Colorado Springs
    cool. thanks for the info doug
  19. Feb 11, 2014 at 1:28 PM
    #8499
    DougDeBonet
    Doug
    Long Island, NY
    2014 TRD Off Road
    Glad I could help!
  20. Feb 11, 2014 at 2:08 PM
    #8500
    blackhawke88
    SGV, CA
    07 TRD Offroad
    I found this trajectory chart for the 5.45x39 on the internet:
    I plotted it and graphed the 100m to 500m range:
    Ran regressions on each of the zeros, and determined that if I zero in at 300 meters, I will also zero in at 15 meters, and my max rise will be less than 20cm or 7.8 inches.
