AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. May 25, 2014 at 6:55 AM
    #9281
    TRD Auddie
    TRD Auddie NOT A FLAKE
    Austin
    Conyers, Ga
    03 TRD EC
    You should check out the B5 Systems SOPMOD Bravo. Similar cheek weld to the Magpul but cheaper and lighter (iirc)
  2. May 25, 2014 at 7:27 AM
    #9282
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    Yea the magpul acs is slightly on the beefy side, but I wanted the storage options. Plus from my own personal preference, I like a rifle to be slightly rear heavy. Helps me with follow up shots because it isn't a feather and doesn't jump around the shoulder when doing double or triple taps
    I think it weighs .88lbs. Someone correct me if I'm wrong
  3. May 25, 2014 at 12:13 PM
    #9283
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    Thanks for the feedback. I've had an AK for years and never experienced any problems with the piston system. I wasn't hesitant to get the Adams piston rifle because it was a piston gun but just wanted to understand the differences between carbine, mid and rifle length operating systems. I have zero experience with AR's so was looking for advice from those in the know.
  4. May 25, 2014 at 3:34 PM
    #9284
    TRD Auddie
    Austin
    Conyers, Ga
    03 TRD EC
    Roger that! Good to know! :thumbsup:
  5. May 25, 2014 at 3:55 PM
    #9285
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    It really isn't.
  6. May 25, 2014 at 5:08 PM
    #9286
    DougDeBonet
    DougDeBonet Well-Known Member
    Doug
    Long Island, NY
    2014 TRD Off Road
    Too bad the last two LWRC piston guns I shot were unreliable as F. They both started out factory new and had FTF and FTE issues and and in one of them the piston system even failed after about 100 rounds. Based on my experience and other with LWRC, I would never buy one.
    Probably the reason Paul Leitner-Wise moved on and started Leitner-Wise manufacturing last year.
    IMO PWS has a superior piston platform and they never cease to amaze me. Even their DI bcg is amazing.
  7. May 25, 2014 at 5:13 PM
    #9287
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    No it doesn't. You moved the location of the heat and dirt from the bolt carrier group to the piston assembly. Moving it doesn't make it any more reliable or create any less heat buildup. Actually it does the opposite since the piston is closer to the gas port. Also consider that you've added more weight, more moving parts and more barrel harmonics. I have yet to hear a sound arguement for the piston driven AR.
    To add a degree of irony all ARs are truly a gas piston design. Look at the bolt on a standard gas impingement AR. The piston is the bolt with gas rings to create a seal against the cylinder which is the bolt carrier.
    There is a reason 3-gunners all run gas impingement ARs. If there was an advantage to a piston driven AR believe me they would be the first to exploit it.
  8. May 26, 2014 at 5:35 PM
    #9288
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Sorry for the poor photo, but here's my carbine with the Stoner 16" fluted barrel on it. 8.5" SBR next to it for size reference.
    680B431D-A797-4A69-A87A-4B24B2F8CCF0_zps_d60dc40a5a530bed384534b24f9bfac8a9eab54b.jpg
  9. May 26, 2014 at 8:01 PM
    #9289
    Sleeper362
    Sleeper362 One Convenient Locations ......In Africa
    Corporal
    K-Vegas NC
    06 SR5 4X4 DC Shortbed
    Leitner Wise was the problem. Last I checked colt wasn't trying to buy PWS or Leitner Wise for their patents. If its reliable enough for 7th and 3rd group I will just trust their word over yours.
    It moves the carbon and heat from the action and moves it to under your handguards. Which place is more important to the operation of the rifle? I measured the gas block of an LWRC plus its piston components including the BCG compared to a DI gun and guess what, two ounce difference, and if you include the gas key and the two screws the parts count on the non adjustable systems is two more parts for the piston system. Most of the added weight of LWRCIs comes from the heavier contour barrels compared to what most people are shooting. They also exhibit less verticle stringing than even my BCM BFH and even my 8" gun was a fucking sub MOA rifle.
    Again, most people won't see the benefit, but I shoot suppressed heavily and the difference between the two systems is night and day. My BCM BFH is no where near as accurate, clean running, or reliable as my 10.5" A5. Both great guns but if I had to carry one into hell, its the LWRCI. My BCM can go MAYBE 100-150 rounds before I have to start being concerned about relubing my gun. Part of the problem with the DI system, when they are over gassed, like they are when they are suppressed, they tend to blow all the lube from between your bolt and BCG into your receiver and out of your reciever in the form of blow back. My piston gun does experience blow back but since it isn't dumping a ton of gas into the actual bolt and BCG it tends to not need much extra attention for keeping it wet and running. Again most people won't see the benefit from a piston gun, but just because YOU don't notice it, doesn't mean there isn't one and its a lot more than a negligible. Both yall need to get off M4C. Those people are biased because DI rifle companies are pulling the strings over there.
    My DI SBR with my Piston SBR
    E583C2EA-2AF3-4568-AD0C-D9F2D6CDCE69_zps_1b125523d71758cfa54b6aeb01518ee3d288f211.jpg
  10. May 27, 2014 at 7:09 AM
    #9290
    kinetik873
    kinetik873 Well-Known Member
    Josh
    Springfield, Va.
    '08 TRD
    OME 3" lift, ARB bumper,DTRL, CB radio in console, 5lb fire extinguisher in bed. SockMonkey decals, Allpro rear bumper, UWS 42" bed box, Wet Okoles all around, snorkel, Pioneer Av3200, ..yadda yadda yadda
    Is anyone running a VLTOR A-5 EMOD stock? I put one on my 14.5" alond with a Surefire MB556 brake and it is just about the flattest recoil I've felt save for my 10/22.
  11. May 27, 2014 at 8:26 AM
    #9291
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Isn't the AR Stoner just MidwayUSA whatever they can get brand? How you like it?
  12. May 27, 2014 at 9:52 AM
    #9292
    TRD Auddie
    Austin
    Conyers, Ga
    03 TRD EC
    Haven't ran the EMOD yet, but I love my MB556K. The recoil, or lack thereof, is awesome.
  13. May 27, 2014 at 4:08 PM
    #9293
    Polymerhead
    Missouri
    Dunno - I'll let you know after I shoot it. Installed it on Friday. I'm expecting it to shoot pretty well. I liked the fluting & 5R rifling. Listed weight is about even with an M4 barrel. I don't know if I believe that, but it doesn't seem any more front heavy with the Stoner barrel than it was before.
  14. May 27, 2014 at 6:16 PM
    #9294
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    ..the magpul STR buttstock also has a friction lock, ...I put one on my latest build, and it doesn't have the annoying "rattle" like most collapsible stocks... also had integral QD attachments which is nice...
    http://store.magpul.com/product/MAG470/180
  15. May 28, 2014 at 6:45 AM
    #9295
    fjfar80
    fjfar80 Well-Known Member
    Mark
    Fairfax, Virginia
    '09 TRD OR DC
    Total Chaos UCA's, King Coilover Front Suspension w/ Remote Reservoir Shocks, King / OME Dakar Rear Suspension with Remote Reservoir Shocks, DO Front Bumper, BruteForce Custom Rear Bumper, Slee Offroad Sliders, Warn w/synthetic line, Softopper, etc.
    I ran the A5 on my MSTN SPR before switching out to an A2 with a Magpul PRS. I now run the A5 in my MSTN dedicated suppressed 8" Noveske barreled SBR.
    The recoil with the A5 was pretty smooth when I ran it on my SPR and it's still pretty smooth in the suppressed Noveske; however, the 5.56 is such a light recoil round already...I don't feel too much of a difference.
    - Mark
  16. May 28, 2014 at 7:21 AM
    #9296
    TRD Auddie
    Austin
    Conyers, Ga
    03 TRD EC
    Gonna throw some Dissipator porn in here! :anonymous:
  17. May 29, 2014 at 10:39 AM
    #9297
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    :rofl: Yeah, because 3 gunners are the group of guys that are pushing rifles to the limits in the harshest environments :rofl:
    There are plenty of piston rifles being used overseas by smaller units where guys have the flexibility of running what they want. And although I hated the decision to semi-replace the SAW, the rifle that won the contract was a piston rifle.
    Disclaimer: I absolutely loved my issued M4 and never had a single malfunction with it in country or stateside. But then again, I never ran it suppressed or on full auto (where piston rifles shine).
  18. May 30, 2014 at 4:29 PM
    #9298
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    Got my limited edition Gonzalez Pmags in!
  19. May 30, 2014 at 4:51 PM
    #9299
    DougDeBonet
    Doug
    Long Island, NY
    2014 TRD Off Road
    Oh baby
  20. May 30, 2014 at 6:52 PM
    #9300
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    There's a lot of dirt on those tables that you set up on!
