AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Feb 12, 2015 at 11:39 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Yup - KNS pins. I install them on all my ARs.
  2. Feb 12, 2015 at 12:07 PM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Nice, I'd heard of those before just had never seen them
  3. Feb 12, 2015 at 12:28 PM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    I have Geissele SSA-E triggers in two of my AR's. I read somewhere that it was not recommended to install KNS type anti-rotating pins with that trigger. Any truth to that?
  4. Feb 12, 2015 at 7:50 PM
    Polymerhead
    Missouri
    Not in my experience, but I have heard that. I have KNS pins and Geissele triggers in three ARs and they work great. I guess if Geissele is super concerned about it they can come out with some anti rotation pins of their own. Until then I'll run KNS.
  5. Feb 12, 2015 at 8:05 PM
    Polymerhead
    Missouri
    Did a quick search online and it seems the Hi-Speed trigger has some non-mil-spec clip locations that need a special groove in the pins, so I'd use the Geissele pins if I had that trigger. I have the SSA in three guns and they work fine with KNS pins.
  6. Feb 13, 2015 at 5:22 AM
    SFSMedic
    SFSMedic Well-Known Member
    Brett C
    Corona, CA
    12 4-door 4x4 TRD Offroad
    Geiselle recommends using their pins. They are the ones who advise not using the KNS pins.
  7. Feb 13, 2015 at 5:49 AM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    I don't really see the point in those pins. If you have good parts and it's built right they aren't coming out. The U.S., Israeli, and Canadian militaries don't seem to have an issue with their high round count rifles walking pins out.
    My .02
  8. Feb 13, 2015 at 6:25 AM
    SFSMedic
    Brett C
    Corona, CA
    I completely agree with the exception of drop in triggers. They are a way better alternative to how all the drop in triggers work with mil spec pins.
    Drop in triggers work by applying upward pressure so the holes in the trigger and the receiver don't want to align. This applies pressure on the pins so they can't walk out. Therefore the captured pins on the KNS set work better in my opinion.
  9. Feb 13, 2015 at 6:56 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, and the reason I bought KNS pins. Even if it is overkill, they're not overly expensive so call it cheap insurance.
  10. Feb 13, 2015 at 6:59 AM
    SFSMedic
    Brett C
    Corona, CA
    I will say this about KNS. Their pins as stated above are not expensive. They are precision machined so they are a step up to the pins you get in a mil spec trigger (even though those are most the time perfectly fine) so that's a bonus. All my rifles run Geiselle triggers with Geiselle pins which are good quality or black rain drop in triggers with KNS pins. So either way I'm running quality pins.
    Disclaimer: I've never ever seen mil spec pins wear out or break prematurely. All parts on a firearm are wearable and need servicing and replacing.
  11. Feb 13, 2015 at 7:04 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
  12. Feb 13, 2015 at 8:39 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Personally, I would not get a red dot in a magnification. It works better as 0x. You can look through it with both eyes open. If you want 3x, get a 3x magnifier to work in conjunction with it on a quick flip mount like Larue Tacticals.
    Just MO.
  13. Feb 13, 2015 at 9:27 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    That one is recommended by quite a few people. Check on cheaperthandirt.com for a lower price, i was $620 shipped when i bought mine. I enjoy mine and havent had any issues but 1 misfeed so far.
    Mine also came with a 30rd mag not 10. You should try to find a barrel that is 5.56 NATO which the sport is. This way you can shoot 5.56 and .223. Its also cheaper to shoot than the other chambers available.
  14. Feb 13, 2015 at 9:38 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Correct it can shoot .223
    But if it was a .223 chamber it could NOT shoot 5.56
    look where i said and it should come with a 30rd
    Edit: appears they are out of stock.
  15. Feb 13, 2015 at 9:44 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    :thumbsup: i dont think you would regret the purchase
  16. Feb 13, 2015 at 9:55 AM
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    I never had any issues with my old M&P15. Solid shooter, but not near as fun as my x39 pistola :D
  17. Feb 13, 2015 at 10:13 AM
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    Hey guys! Just wanted to poke in on this subject. As many have stated, Geiselle pins are a high quality piece just like their triggers and are considered to be of higher quality than the KNS pins. Your money though. If you want to spend $200+ on a badass trigger then spend a little more to swap out the pins that were made and designed for that trigger system for KNS pins then try it out.
  18. Feb 13, 2015 at 10:43 AM
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    I can't bring myself to spend 200 on a trigger in the first place lol
  19. Feb 13, 2015 at 10:56 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  20. Feb 13, 2015 at 11:15 AM
    JBecker
    Virginia
    I had a Geissele SD-C in a gun I sold during the great panic of 2013. I want to get another for my LMT. They are worth it.
