AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Feb 21, 2015 at 5:09 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    I added a spec sheet to the post that shows it still retains quite a bit of energy even at 300 yards. I prefer the heavier 300 grain bullets in this rifle but it is good to try new things out in it. We have an Aluminum bullet available too, 100 grains. It hauls butt the first 100 yards but really peters out quickly after that. I like the fact that our industry is changing a bit and new things are coming into use. Poly cases, Poly/Copper bullets, Powder coated bullets, induction annealing, etc. The annealing part for other calibers, the 458 Socom doesn't need annealing, ever. We get 20+ loadings per case. :)
  2. Feb 21, 2015 at 5:12 AM
    45longcolt
    DFW Area
    2020 Off Road
    Brass is made several times a year now. It does run about 80 cents to a dollar a case but when you can get 20+ loadings per case with no annealing whatsoever, it isn't such a bad deal.
  3. Feb 21, 2015 at 5:24 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
  4. Feb 21, 2015 at 8:33 AM
    SFSMedic
    SFSMedic Well-Known Member
    Brett C
    Corona, CA
    12 4-door 4x4 TRD Offroad
    I disagree the hogues are bigger than the magpuls and the magpul moe+ is similar in size to the mil spec grip.
  5. Feb 21, 2015 at 12:49 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    No way - maybe in length but I think he's probably concerned about grip circumference. I run Magpul and Ergogrips because I like the larger grips. Had a Hogue on my first AR - it was almost the exact same size as the mil issue grip except it had finger grooves and was overmolded. Shot a friend's standard issue grip last weekend and I was amazed - I had forgotten how thin a military AR grip is.
    Edited to add - I'm specifically referring to the Moe Plus overmolded grip. I have no experience with their K grips - those look smaller.
    I also have used the Tango Down Battlegrip and it's a slim little grip that some really like. Mine is in the parts drawer. They've since come out with a bigger model I think.
  6. Feb 21, 2015 at 1:01 PM
    Polymerhead
    Missouri
    Packing up for the range right now actually, so I snapped a photo of the Moe+ from the back. It flares out quite a bit.
    86F32F19-7E33-48AD-806A-12AE0E4AF577_zps_12c80d944801cf8cbfb2d454a512c0b319303d0f.jpg
  7. Feb 21, 2015 at 1:23 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    I've narrowed it down....
    Its between the moe plus (rubber) and the k2 (with rubber over mold).
  8. Feb 21, 2015 at 3:07 PM
    SFSMedic
    Brett C
    Corona, CA
    ImageUploadedByTapatalk1424559992.921801.jpgImageUploadedByTapatalk1424560003.325857.jpg
    You're making me open inventory polymer lol. I rest my case
  9. Feb 21, 2015 at 3:11 PM
    SFSMedic
    Brett C
    Corona, CA
    Got some more 6.8 stuff done today. Just uppers as usual. The way I prefer it.
    Something different. 16" Ironworks 6.8 with thread protector.
    Logo'd our complete uppers finally.
    An 18" IronworksTactical 6.8 done in Patriot Brown.
    We sure do use a lot of Troy handguard. We currently offer Troy, Samson and Midwest Industries. The troys are selected over the other 2 probably 10:1. Although we will be expanding the line the new Mega M-LOK stuff this year. Thankfully.
  10. Feb 21, 2015 at 3:16 PM
    AR15xAR10
    I don't care for the finger molds :/
  11. Feb 21, 2015 at 3:25 PM
    SFSMedic
    Brett C
    Corona, CA
    Me either! Doesn't fit my hand. Then again I hate the rubber over mold.
  12. Feb 21, 2015 at 3:32 PM
    Polymerhead
    Missouri
    Wut? They must have added a significant palm swell in the past few years. Fair enough!
  13. Feb 21, 2015 at 3:37 PM
    Polymerhead
    Missouri
    Back from the range. My new BCM worked great and loves my bulk 55 gr reloads. My scoped gun didn't work as well - I assume the match chamber and the suppressor = a dirty gun with tight tolerances. No good. A good cleaning should help.
    LOVE the BCM though - couple hundred rounds of 55 gr softpoint & FMJ downrange without a hiccup.
    D1650635-FCE9-44A1-9308-20FB05DE7A3F_zps_4821969dff697af01d5123377e446132be63be65.jpg
  14. Feb 21, 2015 at 3:43 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Really does look different with just a thread protector. THough I like it and wish more manufacturers would offer it as at least an option. More and more people are getting suppressors :)
    I ended up using Troy handguards on most of my AR's as well. Just seems like the feature to price point is perfect. Especially picking them up during sales.
    Though I might go for something else for a 10.5 (or 11.5) 556 upper and a 10.5 458socom upper. Both have suppressors and I want to do a partially covered suppressor with the rail. But finding something with more than 1.5ID is a bit tricky. So far the Seekins MCSE V2 Keymod is what im leaning towards
  15. Feb 21, 2015 at 3:52 PM
    Polymerhead
    Missouri
    You can see Troy VTACs on both the guns in my post above. I love them and you can directly attach a Magpul MVG if you want.
    I had never seen a mid-length VTAC behind a pinned A2 sight so I was anxious to try it out. It works great and makes for a nice free float setup for an HD gun.
  16. Feb 21, 2015 at 4:08 PM
    SFSMedic
    Brett C
    Corona, CA
    I'm a fan of the Troy too. I have a MRF, TRX and SDMR on my 3 rifles. Since most of my customers are hunters the fact that so many people make after market stuff for the Troy is a big help.
  17. Feb 21, 2015 at 5:49 PM
    Ghost.
    Ghost. TW 1%er
    Raymond
    Anchorage, AK
    4runner, Taco, GX460, Tundy
    I have big skinny hands...why does everyone have a bone for milspec grips. Milspec is uncomfortable.
    I don't care for the fingers eithet
  18. Feb 21, 2015 at 5:59 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Because milspec yo.
    I have a pile of them in a parts bin.
  19. Feb 21, 2015 at 6:11 PM
    SFSMedic
    Brett C
    Corona, CA
    I like the MIAD hard ole plastic grips. Always have. The rubber ones eat holes in my hands when I carry the rifle for 5-7 hours at a time.
  20. Feb 22, 2015 at 7:55 AM
    BostonBilly
    Easton
    I am looking at scopes for the new build and specifically 2x8. What is the general consensus between a Vortex Diamond Back HD (249.99) and a Nikon M223 (349.95) or Nikon Monarch 3 (299.95). All the prices are from Optics Planet without searching for deals
