AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Mar 6, 2015 at 7:02 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Ah, I should pay attention, I was thinking you were on to one of those JP Enterprise assemblies.
    For 6 bucks, yep. I think the Tubbs I got from LaRue were more than that!
  2. Mar 6, 2015 at 7:06 PM
    SFSMedic
    SFSMedic Well-Known Member
    Brett C
    Corona, CA
    12 4-door 4x4 TRD Offroad
    Sprinco buffer springs
  3. Mar 6, 2015 at 8:49 PM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    I just use standard BCM carbine springs and give them a quick wipe down with lube every once in a while.
  4. Mar 7, 2015 at 4:42 AM
    SFSMedic
    Brett C
    Corona, CA
    Pirhett likes this.
  5. Mar 7, 2015 at 12:31 PM
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Is that an ADM mount? I just got one, been running LaRues, but mine one has one bolt/cam lever. It doesn't look like yours
  6. Mar 7, 2015 at 1:35 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Put a PSA lpk and upper together today for a buddy. It is his first gun and he was like a kid on xmas.54c6416328e572c482122cfc0ad3483e_b1b5e2e80d7d991bc219c8b3a632f8acf6455453.jpg
  7. Mar 7, 2015 at 2:10 PM
    Hunter.V.White
    Hunter.V.White Well-Known Member
    Hunter
    Fairbanks, AK
    2013 DC 4WD TRD-Off Road
    Pelfreybilt Steel Armor, Famous Fabrication Sliders, OME 3" Lift, 886x coils, Dakar Leaf Packs, TC UCA's, Fuel D551 Wheels, 285/70/R17 Toyo Tech RTs, Warn Zeon 10s Winch, Rigid Industries 20" E2 Flood, RI 20" SR Spot/flood, RI Duallys, SwitchPro SP8100, Uniden Bearcat 680 CB Radio.
    I just ordered one.
    I've spent quite a lot on one of my builds, and it emits the strangest noise from the buffer tube when fired. I figured the spring/tube just needed to wear in. For $10, it's worth a shot to get rid of that noise lol.
    Thanks for posting!
  8. Mar 7, 2015 at 2:43 PM
    BostonBilly
    Easton
    I am curious to hear if it works.
  9. Mar 7, 2015 at 2:48 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    No problem at all! TW is family :)
    Hopefully that will be its tell ;)
  10. Mar 8, 2015 at 12:10 AM
    PatriotOfAmerica
    PatriotOfAmerica Well-Known Member
    Reed
    Good Ole' Kentucky
    03 Jade Mica DC TRD 4x4
    33'' kanati mud hogz arb front bumper are camper shell 42'' cree light bar color match fender flares
    My Baby: AKA the multi functional grab and go build
    -13'' CMMG Keymod rail system
    -Custom fluted chrome lined 14.5" barrel
    -Battle Comp 2.0 Flash Hider
    -Noveske Lo Pro adjustable gas block /w Noveske gas tube
    -Anderson Lower reciever
    -Daniel Defense Upper reviever
    -Daniel Defense BCG
    -Spikes Tactical LPK
    -Ace SOCOM Adjustable stock w/ internal buffer tube
    -Spikes tactical heavy buffer
    -Spikes tactical buffer spring
    -Magpul Battery assist
    -KNS precision Trigger pin kit
    -Odin works extended mag release
    -Noveske extended drop pins
    -Magpul MOE pistol grip
    -Noveske Keymod panels
    -Surefire X300 weapons light
    -Nikon 1x4 m-223 scope w/ m-223 mounts
    -BCM extended charging handle
    -Magpul 1 point sling adapter
    Dropped a lot of change in er, and there is more to be dropped on er..
    Pirhett likes this.
  11. Mar 8, 2015 at 4:50 AM
    SFSMedic
    Brett C
    Corona, CA
    Why a heavy buffer if you have an adjustable has block?
  12. Mar 8, 2015 at 8:01 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    Finally got to shoot my 6.5 today took about ten rounds to get it dialed in shooting some very good groups IMO with factory 123gr hornadys. Gonna load up some 123 gr. Nosler custom competitions with 26.5 grs of 8208 XBR, and CCI 450 primers. Hoping to get 5 rounds in the same ragged hole at 100 yds. :D
    Very impressed with Bill Alexander's work!
  13. Mar 8, 2015 at 8:33 AM
    BostonBilly
    Easton
    :cheers:
  14. Mar 8, 2015 at 10:57 AM
    PatriotOfAmerica
    Reed
    Good Ole' Kentucky
    Lol funny story on that, ordered heavy buffer not meaning to...
  15. Mar 8, 2015 at 2:12 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Loving this Aimpoint T2 and the new BCM. Took both to the range for a hundred rounds of so. My Surefire spit its lens and o-rings all over the range - not sure what I'm going to replace it with. Got everything back together, just don't trust it now.
    F201347F-1850-47B3-951A-A4CD1D46240C_zps_4bd6280a4a193738c3e9d99bc2a158da70ba65d7.jpg
  16. Mar 8, 2015 at 2:23 PM
    JBecker
    Virginia
    Can't see the pic. What Surefire model?
    I'd say replace it with a Surefire Scout M600 Ultra.
  17. Mar 8, 2015 at 2:34 PM
    Polymerhead
    Missouri
    It's an incandescent G2 with their LED conversion head. I don't think they offer either anymore. Might have to go with a scout. I love the Streamlight TLR series too, and those are a lot cheaper...we'll see. I think I can get a pretty good deal on the scout too.
  18. Mar 8, 2015 at 2:37 PM
    JBecker
    Virginia
    I got my Scout on eBay for $275, it was new. They pop up often on AR15.con equipment exchange as well.
    I've also had the single cell M300 version and that is pretty good too, but the 2 cell 500 lumen version is great.
    You can't go wrong with either.
  19. Mar 8, 2015 at 8:13 PM
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    I'm ordering the INFORCE WML soon. I like my lights at the 12o'clock
  20. Mar 8, 2015 at 8:37 PM
    Idaholandho
    Just ordered the Streamlight for a new weapon after a decision battle. I love the look of the WML and know they are fantastic lights but, had to go with the same that I have been using.
