AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Jul 5, 2015 at 11:04 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Go for it. I never shoot my SBR but at least I can get it out of the safe every once in a while. After I built it up, I realized what a PITA it would be to replace, weighing the chances of it getting stolen vs me actually needing an SBR vs a carbine, so it's not a truck/HD gun for me. Maybe I'll get back around to it at some point. Neat to say you have one though.
  2. Jul 5, 2015 at 2:02 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    If it does get relegated to truck duty i have a secure mount design in mind that I will try.
    Most people don't secure the firearms they have in their vehicle around here for some reason.
  3. Jul 6, 2015 at 12:52 PM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    Hey guys any ideas on the best way to sell my AR, bought it as soon as I turned 18 and haven't even shot 100 rounds through it, its a Smith and wesson M&P15, Has a Red dot with multiple "sights" red and green, Laser, 3x magnifier scope, Front pistol grip, and a bipod, 2 clips. I have everything from the original box and all the little papers.
    My priorities have changed and would rather have a lift for my truck. So any ideas on the fastest yet not get ripped off way of selling this thing? Or even a good starting price for it? I honestly have no idea how much I even have in it.
    Or if anyone has a 6112/5160 lift kit we can just trade!
  4. Jul 6, 2015 at 8:23 PM
    TheStevo
    TheStevo Baja Taco Enthusiast
    Stevo
    Reno, NV
    MAGNETO
    TC +3.5 LT, Fox COs, King Bypasses, DTF SUA w/ 3x18 Quad bypass, Fox Air Bumps, Method 17" NVs, 35s, Relentless Fab custom tube bumper, skids, & sliders, lots of LEDs
    Yes it is. Way easier than I thought.
  5. Jul 7, 2015 at 4:19 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Thanks - did you paint the gun as a whole or remove some components?
  6. Jul 7, 2015 at 8:04 PM
    TheStevo
    Stevo
    Reno, NV
    MAGNETO
    I taped off some things like sights, top rail, ejection port, etc. Didn't take anything apart. Left the mag in. I figure certain parts may wear quickly like the trigger and grip. But I'm not too concerned, I think rifles look kinda cool when they're worn looking. Plus it's easy enough to just repaint or touch it up.
    Sig45[QUOTED] likes this.
  7. Jul 10, 2015 at 12:08 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Your best bet is to find a local gun forum and list it there. It's a pretty basic gun so I doubt anyone would want to deal with shipping and transfer fees. Most states have some sort of forum or you can post it on larger forums like ar15.com and just mention local only.
    As for price I usually look what a new one will cost. Then search used m&p15 and you can usually get a decent idea. Or post it for say 50-100 under new. If you do t get any offers just keep lowering it till you do.
    Just make sure you follow any state laws for private sales
  8. Jul 13, 2015 at 10:41 AM
    djthemac
    djthemac Pee shooter, bandaid applier!
    Dan
    2013 DCSB TRD OR spruce green
    Finished a top shelf build.
    BCM RECCE 16" KMR MK 2
    BCM Gunfighter stock
    BCM Gunfighter charging handle
    BCM Kinesthetic angled hand stop
    BCM MOD 1 Grip
    Magpul PRO offset BUIS
    Haley Strategic/Inforce WML with thorntail mount
    ADM RECON 30 Optic mount
    Geiselle SD3G Trigger
    Vortex Razor HD gen ii 1-6
    AAC muzzle brake (51t suppressor mount)
    WW GUNS - Kryptek Mandrake Water Transfer
    WG GUNS - Cerakote Patriot Brown small parts
    Juxa, travel_taco, Bagman and 2 others like this.
  9. Jul 14, 2015 at 10:42 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    My aimsurplus NiB BCG wasn't cycling in any of my upper and lower combos. It is pretty new too, and did not perform too well in the first few rounds I put in it. I was toying with it yesterday and noticed the bolt has way more resistance rotating and moving inside the carrier compared to my regular/normal BCGs. I took it apart and noticed a ton of fouling at the back of the bolt behind the gas rings, and despite a lot of scrubbing, much of it is still on there. Any reason why a relatively new NiB BCG would have so much fouling in there? (I pretty much only shoot wolf by the way, which I know is dirty) A couple of my other BCGs also had fouling back there but had way less friction/resistance when the bolt rotates in the BCG.
  10. Jul 14, 2015 at 11:09 AM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    I bought one of the AIM NIB BCG's and initially couldn't get my rifle to cycle rounds. After trouble shooting everything I could it turned out that the gas key wasn't staked and was loose. Once tightened down and staked it was GTG. I see more crud on my bolt than I was expecting as well and I shoot steel most of the time. I thought this was normal...as this is my first AR.
    blackhawke88[QUOTED] likes this.
  11. Jul 14, 2015 at 11:11 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    good idea, i should double check it. was your's hand loose? or did you have to apply a bit of force to move it? I notice the front of the gas key is a little marred and it might be making contact with the gas tube.
  12. Jul 14, 2015 at 11:15 AM
    Bagman
    Area 51
    Didn't take much force at all to tighten it down...I was very surprised. I'd double check to make sure yours is tight. If not it might be why its hitting the tube.
  13. Jul 14, 2015 at 9:56 PM
    DougDeBonet
    DougDeBonet Well-Known Member
    Doug
    Long Island, NY
    2014 TRD Off Road
    That's no good at all. 0_p
  14. Jul 14, 2015 at 10:45 PM
    LaRue Shooter
    LaRue Shooter "Keep your dick in a vise."
    Southern Cal
    Built up, locked 06 Sport Access Cab
    Trijicon sticker on rear window.
    Had a gas key work loose through the staking on an LMT carrier. Took a long time to figure out why it was short stroking and not locking back. I just happened to pick the carrier up by the key and felt it move. 15,000 rounds through that gun and that was the first nagging issue it experienced. It happens, I guess. I've added that to the periodic maintenance checklist.
  15. Jul 14, 2015 at 10:48 PM
    LaRue Shooter
    Southern Cal
    Could start with another upper and a couple optics;)
  16. Jul 15, 2015 at 4:08 AM
    DougDeBonet
    Doug
    Long Island, NY
    2014 TRD Off Road
    Well. Most manufacturers do not seal the bottom of the gas key either. It is supposed to be sealed with permatex gasket sealer as per mil specifications, then the bolts torqued to 56 inch pounds. Rarely is that the case. Instead they are torqued, then staked. Or in most cases, improperly torqued and then staked, causing a loose gas key or broken bolt if over torqued and staked.
    When done properly, there shouldn't be a key coming loose but the sealing step is usually skipped.
  17. Jul 15, 2015 at 12:31 PM
    95 taco
    95 taco Battle Born
    What length barrel is your SBR?
  18. Jul 15, 2015 at 3:38 PM
    LaRue Shooter
    Southern Cal
    Hey, I've got one of those. What model are you looking for? The ECOS seems relatively easy to find. This one is old, but I see them pretty regulary online.
  19. Jul 15, 2015 at 4:28 PM
    SFSMedic
    SFSMedic Well-Known Member
    Brett C
    Corona, CA
    12 4-door 4x4 TRD Offroad
    Also a proper staking tool. Not a punch and hammer. This can bend the bolt, stretch the threads or crack the bolt.
  20. Jul 15, 2015 at 4:36 PM
    LaRue Shooter
    Southern Cal
    Try samplelist.com. also, Scott at Liberty Optics usually has some of the best prices on the net.
