AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Dec 6, 2015 at 9:00 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Thanks for the link, I'll check it out.
    Been thinking about a sling, I like them but all my experience is on hunting rifles.
    Should I get a single or dual point sling?
    I think I would like the single point better for mobility, but a lot of people don't like them because they firearm will flop around when moving around and no hands on it.
  2. Dec 6, 2015 at 9:56 AM
    elgringoloco
    elgringoloco Well-Known Member
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    I'll start the bidding at a 30 rack of Keystone light.
  3. Dec 6, 2015 at 10:07 AM
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Drats.
  4. Dec 6, 2015 at 10:12 AM
    95 taco
    95 taco Battle Born
    I think I'll look into the 2 point to keep it universal with my other gear.
  5. Dec 6, 2015 at 10:17 AM
    Neutral
    Neutral Well-Known Member
    Fella
    Alabama
    14 SR5, 25 SR5
    14 4.5" RCD, Pelfreybilt armour, Fox coilovers/shocks, Alcan leaf springs, 4.56 gears, 35's 25 Stock
    If the only thing left to drink was Keystone I wouldn't drink either :laughing:
    :rimshot:
    windsor[QUOTED] and elgringoloco like this.
  6. Dec 6, 2015 at 6:12 PM
    BulletToothTony
    BulletToothTony [OP] You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Ok so I've got a question for you guys, I have a rock river ar with 16 inch heavy barrel, I'm wanting to lose some weight on the gun and was wondering which would be the better option.
    1. Sending the upper off and having the barrel reprofiled to something lighter.
    Or
    2. Buying a new barrel altogether
    Or
    3. Open to suggestions
    I have no complaints with my rifle as far accuracy so I don't have a real need to get a new barrel but I'm not familiar with nor know of any reputable companies to send my upper to and have them reprofile it for me. Any tips or links to help me out?
    Thanks Brett
  7. Dec 6, 2015 at 6:15 PM
    95 taco
    95 taco Battle Born
    I was in the same position with my 18" 556 upper, I ended up just replacing the barrel, really simple to DIY and in you can sell the old barrel to help recoup cost or keep it for a bench/varmint upper build.
  8. Dec 6, 2015 at 9:11 PM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    New free float installed, cut/ground down factory pinned front sight gas block. Went from lower pic to above for 80$ including grip, makes a world of difference in the rifle
  9. Dec 6, 2015 at 9:31 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    there are really no written laws on how to limit magazines. it only has to be permanent.. So a rivet was considered permanent. other people epoxy the base plate or roll pin it as an added measure.
  10. Dec 6, 2015 at 10:16 PM
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    PSA freedom upper, knockoff magpul afg, forget the brand of rail, got it on Amazon for 75$. 15in super slim
  11. Dec 7, 2015 at 5:03 AM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Same as Ryan, tried several single-points and feel that two-points are better all around. I use BFG's Vickers sling on everything now. There's other brands out there too, the quick adjust is the key to look for so you can cinch it up for different shooting positions/modes of carry.
    The last single-point I own was put on my paintball gun and it works there I think because I never really put the gun down. I'd consider a single-point again if the weapon was small like a PDW, or perhaps a home defense shotgun.
  12. Dec 7, 2015 at 5:09 AM
    BadBrains
    AL
    ADCO
    However, it's 80 to contour and 50 for assembly/disassembly, then shipping costs, so you're half way to the cost of a new barrel.
    If you can send just the barrel and do the assembly/disassembly yourself, that would be the cheapest option.
  13. Dec 7, 2015 at 11:01 PM
    DougDeBonet
    DougDeBonet Well-Known Member
    Doug
    Long Island, NY
    2014 TRD Off Road
    I have moved to Way Of The Gun slings. They rule. 2 point, quick adjust, no hassle paracord loop attachment. I run my gun pretty hard most of the time. Throwing it on the ground, or bench when I get to the range. Using the stock as a hammer if someone's castle nut comes loose among other nonsense shit. And I'm OCD with some things so the first WOTG sling I got I threw over a tree branch and dangled from it with no issues. I'm just shy of 160# so I had my friend do the same thing, and he's 215# still no issues. It's pretty solid.
  14. Dec 7, 2015 at 11:08 PM
    DougDeBonet
    Doug
    Long Island, NY
    2014 TRD Off Road
    Keep the upper and build a lightweight one.
    I say this because the Rock river heavy barrel is and absolute tack driver with 62gr rounds. Sub MOA easily is you do your part.
    My dad has an RRA gun with a heavy barrel, he's putting a 3-9x Nikon on it and swapping the aimpoint PRO to the lightweight upper he just finished.
    IMHO it's worth keeping, it's assembled well and it shoots like a champ I'm sure.
  15. Dec 8, 2015 at 12:07 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    lift weights until the gun isnt heavy anymore
    nelson18matt and travel_taco like this.
  16. Dec 8, 2015 at 4:05 AM
    BulletToothTony
    Hadn't thought of doing that <.<
    travel_taco likes this.
  17. Dec 9, 2015 at 2:36 AM
    helimech09
    helimech09 Well-Known Member
    Nick
    South Alabama....or South Louisiana if I'm working
    Black 2016 DCSB and White 1989 Mazda B2600i 4x4
    Gunmetal metallic Tacoma side badges, debadged tailgate, blacked out chrome grill surround, customcargrills.com grill with Toyota badge color matched to other badges, color matched rear bumper covers, Black headlight mod, 30" light bar stealth mounted in front bumper, Bilstein 5100's all around, OME 887's, Icon uniballs UCA's, Wheelers AAL, Spidertrax 1.25" spacers, 17" Gunmetal SCS SR8 wheels, Cooper STT Pro 285/70/17 Tires
  18. Dec 9, 2015 at 9:42 AM
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Bagman likes this.
  19. Dec 9, 2015 at 6:11 PM
    336
    336 Well-Known Member
    Kendrick
    Ashe/Boone
    4x4 6 Speed
    New.
    Dantwenty2 likes this.
  20. Dec 10, 2015 at 12:58 AM
    Dantwenty2
    Dantwenty2 Well-Known Member
    Saugus, CA
    2009 TRD OFF-ROAD DCSB
    Fox 2.0 coilovers, yellow fogs, Peltyfry bed light bar with Rigid Duallys.
    Just grabbed an AR pistol lower. Anyone have experience with them? I wanna go with a 10.5 inch barrel, noveske flaming hog, or other can, and a Sig brace. Anyone have any recommendations?
