AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Sep 19, 2016 at 9:07 AM
    Paleus
    Paleus Well-Known Member
    Arkansas
    '13 DCSB TSS 4x4
    scottalot likes this.
  2. Sep 19, 2016 at 9:18 AM
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    ill have to double check when I get home but that looks about right to what I have. Thanks for the reference image!
  3. Sep 19, 2016 at 9:47 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I'd also check firing pin return, and length (too long).
  4. Sep 19, 2016 at 10:07 AM
    Pirhett
    Rhett
    San Diego
    Stock...
    oh
    yeah? Ill look up normal lengths and check when Im home
  5. Sep 19, 2016 at 10:32 AM
    Arcticelf
    Gladiator
    If it's doubleing either the FP isn't floating correctly (which the light strikes would support) or the disconnect isn't working correctly.
    Check out an animation of how the fire control group works, and strip/clean the BCG.
    Good luck,
    AE
  6. Sep 19, 2016 at 12:22 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Trigger pin could also be loose, seen a few reports of a sloppy trigger pin causing bursts/full auto.
    What ammo are you using? Some ammo is known for hard primers, split neck could be either faulty casing or a bad chamber.
  7. Sep 19, 2016 at 12:25 PM
    Pirhett
    Rhett
    San Diego
    Stock...
    Ammo was wide variety, some xm855, wolf Poly, Colt nickle case, federal 55 grain.
    Ill prolly pick up some anti rotation pins, new disconnect spring, make sure hammer spring is good, re align gas block just to be sure
  8. Sep 19, 2016 at 12:57 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I had an AR do bursts once. Turns out one of the trigger pins was loose and had sunk into the receiver, so the disconnect wasnt correctly latching on to the trigger after each shot. Could also be an out of spec receiver where the hole for the disconnect and trigger pins are a tad too far apart.
    scottalot and Pirhett like this.
  9. Sep 19, 2016 at 2:30 PM
    Pirhett
    Rhett
    San Diego
    Stock...
    Ill fix that with some anti rotation pins :thumbsup:
    3378jakesr5 and scottalot like this.
  10. Sep 19, 2016 at 6:23 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Definitely sounds like hammer follow. On one of my first builds I didn't catch the disconnector with the trigger pin. It was just floating in the trigger slot. Caused similar-sounding issues.
    To check disconnector issues, remove the mag, unload the gun, cycle the charging handle, pull the trigger and keep it pulled, then cycle the handle again with the trigger pulled. You should be able to release the trigger (you'll hear a click as the trigger resets) and then pull it again and dry fire the gun. If that second pull doesn't release the hammer and dry fire the gun, you've probably put something together incorrectly.
    Arcticelf and Pirhett like this.
  11. Sep 19, 2016 at 7:55 PM
    Pirhett
    Rhett
    San Diego
    Stock...
    I did the whole function test before hand with no problems so thats why I was confused on what problems I could be having
  12. Sep 20, 2016 at 7:28 AM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Finally going to start building one
    Of my own since I have larger expenditures left for the truck. So this way I can save up a few hundred bucks and buy some parts a few at a time.
  13. Sep 20, 2016 at 7:30 AM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    lol
  14. Sep 20, 2016 at 7:33 AM
    GARSHA91
    Chicago
    What?
    And I am haha.
    scottalot[QUOTED] likes this.
  15. Sep 20, 2016 at 10:54 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    I was able to replicate my hammer follow by separating the lower from the upper and, while keeping your left thumb on the hammer so it doesnt slam into the bolt catch, pull the trigger and keep the trigger pulled. Using your left thumb, guide the hammer slowly until it contacts the bolt catch, then pull the hammer back with your thumb. Now repeat except instead of keep the trigger pulled all the way back, let it forward a little bit. Keep doing until the trigger is completely depressed before pulling the hammer back. At one of those trigger positions, my disconnect wasn't working.
  16. Sep 20, 2016 at 4:02 PM
    Nightcrawler_22
    Nightcrawler_22 Active Member
    James
    Tellico Plains, TN
    2007 Tacoma, double cab, 4X4, 6 speed, TRD Off Road
    Toytec Boss Suspension, OME Dakars, SPC/LR UCAs, 16x9 XD Addicts, 33x12.5 STT Pro
    One cannot buy only a few parts at time lol. I said I would do the same.. Boy was I wrong :rofl:
    scottalot and 3378jakesr5 like this.
  17. Sep 20, 2016 at 4:15 PM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Allright im itching to build another upper. I have a 223 and 300bo already so i dont think i need another one of those two(yet)
    What ahould be the next upper be chambered in? Down to these three.
    6.5 grendal For long range (have a leupold mark 4 that needs a home)
    458 socom for the fact that i can say i have one and i can use as a bear/dinosaur gun
    22lr for plinking and what not
    I reload so cost of rounds dont really matter to much.
  18. Sep 20, 2016 at 4:19 PM
    Arcticelf
    Gladiator
  19. Sep 20, 2016 at 4:21 PM
    Polymerhead
    Missouri
    What the heck is that??
  20. Sep 20, 2016 at 4:25 PM
    Arcticelf
    Gladiator
    Another long range/precision cartridge that fits an AR15 receiver/mag. Supposed to be a bit better than 6.5
