AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Apr 12, 2017 at 5:13 PM
    44357
    44357 Whithersoever...
    Eric
    Desert RATS
    2017 T4R ORP MF
    Caligula likes this.
  2. Apr 12, 2017 at 5:17 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    I know, LOL. Every thread devolves into commentary on how the Communist Democrats of California are constantly oppressing our liberties and the dire conditions the state is in, usually due to illegals and hate for America. I do agree with them 100%, but its depressing how every thread ends up going in that direction.
    Thanks, im looking at the RBA site, i like it!
    @scottalot What is it that you like? Im dying for input here.
  3. Apr 12, 2017 at 11:33 PM
    Caligula
    Los Angeles, CA
  4. Apr 12, 2017 at 11:37 PM
    Caligula
    Los Angeles, CA
    Im just going to be shooting stuff. It really more for my own personal interest to build it from parts. So really more of the latter if anything. Ive read on Calguns of some open air BLM areas that they have club days at. I just bought 1500 rounds of .223 from one of the guys off there, so ill be set once its built.
    I know buying the Noveske upper is like learning to drive in a Ferrari, but it was such a good deal I got, I didnt want to pass it up.
  5. Apr 12, 2017 at 11:43 PM
    44357
    Eric
    Desert RATS
    2017 T4R ORP MF
    Diamondhead makes this one...It is comfortable. Handguard is heavy compared to my moe SL and not as versatile.
    You will not regret the Ferrarri build. Upper is the area to spend the money on imo...
  6. Apr 12, 2017 at 11:46 PM
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Not sure if posted here yet. But
    www.classicfirearms.com has 20% off all of their barrels right now. Just bought 2 16" 1:9 twist stainless diamond fluted barrels for 87 each. No free shipping, but you can get some really good deals right now
  7. Apr 12, 2017 at 11:49 PM
    Caligula
    Los Angeles, CA
    Thats really low, like too low. Have you used their barrels before?
    Do they have any 14.5" barrels?
    EDIT: Jesus Christ, i understand now those that have said an AR is more expensive than a crack addiction.
  8. Apr 13, 2017 at 12:16 AM
    4x4Taco09
    Dane
    Louisiana
    I have MANY of their barrels. No complaints from me. A lot of their barrels are chambered in .223 WYLDE, which "supposedly" grants better accuracy, it is a tighter chamber, but unlike being chambered in .223 which won't allow you to shoot 5.56, you can shoot both rounds in a WYLDE chamber
  9. Apr 13, 2017 at 12:20 AM
    Caligula
    Los Angeles, CA
    The Noveske barrel is 5.56 iirc. The case of ammo im picking up is .233. Should be good?
    Also its a 1:9 barrel, ive read its supposed to be matched for 62gr rounds. The ammo im buying, plus most of the cheaper ammo ive seen is 55gr. What effect would this have in real life?
  10. Apr 13, 2017 at 12:23 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    223 in 5.56 - ok
    5.56 in 223 - 99% fine but not the best practice.
    1:9 - best with 62gr or less, 55gr is optimal
    1:7 - best with heavier than 62gr.
    scottalot and 4x4Taco09 like this.
  11. Apr 13, 2017 at 12:26 AM
    4x4Taco09
    Dane
    Louisiana
    Yes, a 5.56 chamber will shoot both rounds. (5.56 is loaded hotter than conventional .223)
    Same brass, same length, same bullets.
    Twist rate varies too much to just give a simple answer, you have to account for your barrel length and distance you'll be shooting. 1:7-:9 you'll be fine with 55 or 62 grain
    scottalot likes this.
  12. Apr 13, 2017 at 12:30 AM
    Caligula
    Los Angeles, CA
    The cheaper stuff like PMC, Perfecta, and Wolf Gold are 55gr. Whats the real world difference if im firing 55gr out of my 1:7? Just less less ability to keep tighter grouping compared to a 62gr bullet? After what yardage does it really become evident? Past 50yds, 100yds?
    I imagine it would be wise get at least a box or two of good 62gr when it comes to zeroing my sights?
    EDIT: my barrel is 14.5" + muzzle break
  13. Apr 13, 2017 at 12:42 AM
    4x4Taco09
    Dane
    Louisiana
    I have had 1:7 16" barrels do fine with 55 grain out to 150 before. I have had another 16" 1:7 that was very inaccurate at 150. It honestly depends on your barrel.
    I reload, so I am able to tighten my groups by changing loads. But I still buy Perfecta and every now and then some Wolf (brass). I won't buy 62 grain bullets because they're usually quite a bit more expensive so those I reload. But as far as 55 grain, I buy and shoot whatever is the cheapest.
    If you are looking for strictly accuracy, take your gun out and shoot some groups with different ammo, brands and weight. See what works best for your rifle
    With a lighter grain bullet you will want the bullet to twist more inside your barrel, this is what creates your accuracy. But too much will throw it off, too little the same. Once you start getting keyholes in your target, you're pushing that grain bullet in that barrel to its limit. A heavier bullet doesn't require AS MUCH twist to stabilize in the barrels because it is heavier.
    This is what has worked for me and what I have noticed. Again, I have built many rifles and pistols, and bought complete rifles as well. Best way of you to know your rifle, is sling a bunch lead at some targets
    scottalot and IronPeak like this.
  14. Apr 13, 2017 at 12:47 AM
    4x4Taco09
    Dane
    Louisiana
    Here is what I've been working on recently.
    80%s
  15. Apr 13, 2017 at 1:20 AM
    Caligula
    Los Angeles, CA
    Sweet. All done with a drill press? What do you do about the 'fire' and 'safe' markings? Just leave them off? Ive thought it would be cool if someone made a HK style stamp for those.
    Ever tried anodizing at home?
  16. Apr 13, 2017 at 4:47 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    It's actually the reverse. Heavier (longer) bullets require faster twist to stabilize. 1:7 imparts more spin on a bullet than 1:9. It's one full 360 degree revolution in 7 inches instead of 9. Bolt guns in 223 are often even slower twist - 1:12 is pretty common. One spin in 12 inches, slower twist, is great for 40 & 50 gr bullets like you would use on prairie dogs.
    scottalot and mountainmonkey like this.
  17. Apr 13, 2017 at 5:24 AM
    doghair
    doghair Well-Known Member
    Phoenix
    2013 Single Cab 4x4
    Truth.
  18. Apr 13, 2017 at 7:41 AM
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    Crap
    Now there's math involved? ???
    doghair[QUOTED], scottalot and smugly like this.
  19. Apr 13, 2017 at 9:56 AM
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    I think I am going to build a new upper. Was thinking of either 6.8 SPC II or 6.5 Grendel. I want to do a sbr build on these but does anyone know what a good barrel length is for those?
  20. Apr 13, 2017 at 9:59 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Don't know much about the Grendel other than I usually see it run with 20" barrels. The 6.8 is good to go down to 12.5" reliability and ballistics wise.
    scottalot and Sleipnir[QUOTED] like this.
