AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Apr 25, 2017 at 8:21 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Someone else may be better, but without being able to manipulate the parts myself i can't guide you
    scottalot, wilcam47 and smugly like this.
  2. Apr 25, 2017 at 9:39 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Did you pop a primer that is now lodged in the trigger mechanism?
  3. Apr 25, 2017 at 9:47 PM
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Never saw anything odd when i switched it to the other lower.
  4. Apr 26, 2017 at 6:03 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Like Jim Beam said above, try wiggling it around a bit to find the sweet spot. You may have to tweak the barrel nut a little.
    scottalot likes this.
  5. Apr 26, 2017 at 9:46 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    something is binding or not seated properly...15-20 is way too much for a trigger pull. Have you taken it apart?
  6. Apr 26, 2017 at 11:49 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Is the A post (front sight) set right?
    smugly and scottalot like this.
  7. Apr 26, 2017 at 3:24 PM
    3378jakesr5
    jake
    littleton colorado
    Once so far, its my dads ar pistol so ill have to play around next time i see him and see what is going on
    scottalot and Sleipnir like this.
  8. Apr 26, 2017 at 11:18 PM
    MattB77
    MattB77 Well-Known Member
    OR
    2013 AC TRD Sport
    I would imagine, I haven't touched it it's just how it came from the factory. The gun hasn't even be fired yet
  9. Apr 26, 2017 at 11:46 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    What red dot + 3x setup is that? Vortex?
    This is a video I saw how to install the Magpul SL handrail that many had trouble with. Im not sure if it is anything like the one you have, but it may help as i see others describing the same process to install yours as the Magpul one.
    scottalot and smugly like this.
  10. Apr 27, 2017 at 8:03 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    It's Missing a bunch of states
  11. Apr 27, 2017 at 8:43 AM
    smugly
    Doug
    Those states don't matter, LOL :boink:
    IPNPULZ, Caligula and scottalot like this.
  12. Apr 27, 2017 at 9:09 AM
    wilcam47
    Will
    Bourbon state
    I have had small piece of brass mess up operation of firearms, one of the weirdest was an sks where a piece of brass got stuck under the bolt and it would fire but the second shot wouldnt lock into position. I finally noticed a piece of brass and had to remove it with my knife after that it worked fine.
  13. Apr 27, 2017 at 11:08 PM
    Caligula
    Los Angeles, CA
    Those in CA.... how long has it taken you to get a response when filing a PFEC?
  14. Apr 30, 2017 at 4:01 AM
    smugly
    Doug
    I should be! I'm a lifer. Little to far away this year. I here trump is going to be a speaker. First time since Reagan.
    Caligula and Sleipnir like this.
  15. Apr 30, 2017 at 5:47 AM
    CristiaanC
    CristiaanC Well-Known Member
    Austin, TX
    2017 Inferno 4x4 SR5 DCSB
    King 2.5 Coilovers, SPC UCAs, OME Nitros, Deaver Springs, SCS SR8s. Hercules TerraTrac M/T
    I own an Aero Precision AR in .223 and I'm currently building one in .308.
    Tlook and Sleipnir like this.
  16. Apr 30, 2017 at 6:39 AM
    smugly
    Doug
    Thank you, I was aware of it. It was more making a statement for those that may not have been aware how long it's been
    Tlook[QUOTED] likes this.
  17. Apr 30, 2017 at 2:35 PM
    Caligula
    Los Angeles, CA
    So a little update on Caligula's Obsessive Compulsive AR Build.
    I took it to Addax Tactical in San Fernando. Tiny shop but very nice guys there. Their gunsmith pointed out that this thing was not maintained at all, and probably had over 1000 put through it. The barrel pin holes were not a concern for him as much as the mangled barrel nut, he said it looks like they did not have the right tool, probably hammered it in place. Also he thinks the AAL muzzle device was cracked during pinning and rewelded. @Polymerhead it looks like you called this earlier.
    Their gunsmith said if anything, he could tear down the upper, check and reinstall everything, replace barrel nut and check headspace. They would charge about $80 for this. Im debating whether I should demand reimbursement for that from Choi in lieu of just refunding the upper. I would have no problem finding his address with the crumb trail hes left online, and Im considering small claims court if he continues to refuse to communicate.
    @Sleipnir @Old Marine Cal
    I contacted one of the admins on Calguns, as they advise to do that first when there is a marketplace dispute. I gave him all the info, and he said it was fine to post up the following in his thread.
    http://www.calguns.net/calgunforum/showthread.php?p=20035787#post20035787
    Sleipnir likes this.
  18. Apr 30, 2017 at 2:43 PM
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    Well written thread, responded on caalguns.
    What he doesn't realize , the gun community in California is not that huge.
    He is committing suicide by not making this right.
    smugly and Caligula like this.
  19. Apr 30, 2017 at 2:51 PM
    JimBeam
    JB
    2015 Tundra
    That's how you call a mother fucking scam artist out right there
    Old Marine Cal and Caligula like this.
  20. Apr 30, 2017 at 2:56 PM
    Old Marine Cal
    2015 MGM DBLCAB
    I have bought two guns from there
    Both were straight up guys who let me field strip them.
    My M&P shield, I actually fired.
    Hope this guy makes it right, but I will remember him, never buy anything from him.
    Caligula likes this.
