AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Jun 2, 2011 at 9:24 PM
    #141
    norcal4banger
    norcal4banger 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    Okay thanks for the info. I got more research to do
  2. Jun 3, 2011 at 5:00 AM
    #142
    kinetik873
    kinetik873 Well-Known Member
    Josh
    Springfield, Va.
    '08 TRD
    OME 3" lift, ARB bumper,DTRL, CB radio in console, 5lb fire extinguisher in bed. SockMonkey decals, Allpro rear bumper, UWS 42" bed box, Wet Okoles all around, snorkel, Pioneer Av3200, ..yadda yadda yadda
    I just traded my ACR for cash and an M&P 15. Its a great platform. The GF said she wanted a good zombie gun and the ACR was a bit too heavy for her small frame. I would reccomend it if you cannot afford a top tier system like LWRC or Noveske.
    You can always upgrade the BCG,barrel and compensator/flash hider and have an excellent setup as well.
  3. Jun 3, 2011 at 5:06 AM
    #143
    rob_s
    rob_s Well-Known Member
    SE FL
    White 2010 DC SB Sport
    On the M&P, be wary of the "OR" or "Optics Ready" model. The base gun should be on par with the other models (which is good or bad, depending on your point of view) but the gas block on the front can be problematic down the road depending on your use. If your intent, however, is to mount a conventional optic with no need or desire for a front sight, backup or otherwise, it may be a good value.
  4. Jun 3, 2011 at 5:09 AM
    #144
    rob_s
    SE FL
    I have something with a similar look but a 11.5" barrel and can.
  5. Jun 3, 2011 at 5:25 AM
    #145
    28ØØ3
    28ØØ3 Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    build your own. you can get a high quality, completely customized AR for less than $900. if you want to buy a complete upper and assemble your own lower, its SUPER EASY!
    Example:
    Spike's lower from Aim: $80
    MOE lower build kit from Palmetto State: $140
    BCM Middy Upper: $400
    BCM BCG: $140
    MI drop-in 2 piece Handguard Rail: $140
    Total: $900
    and that's a way better weapon than a $900 level RRA, M&P, Stag, etc.
  6. Jun 3, 2011 at 5:53 AM
    #146
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    still need a charging handle $20-$40
    and a rear sight or optic $50-?
  7. Jun 3, 2011 at 6:54 AM
    #147
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    BAH on you :shakesfist:
    yeah, oops. still the point remains the same
    i went this route:
    spike's lower: $75
    PSA lower kit: $50
    LMT complete upper (F/A bcg, CH, etc.): $565.25 (weaponoutfitters, arfcom code)
    Ergo/Falcon Industries F93 stock: $120
    spike's detachable carry handle (takeoff from new rifle): $65
    Total: $875.25
  8. Jun 3, 2011 at 7:02 AM
    #148
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    mine
    BCM upper - 400
    bcm bolt carrier (already had chrome bolt) - 70
    BCM CH - 45
    magpul kit - 100 (stock, grip, hangaurds, buffer,buffer tube, spring)
    sog lower - 100
    DPMS lpk - 65
    magpul buis 56
    total = 836
    I could have saved 20 bucks by getting just a standard charging handle but I opted for the nicer one. I also have an aimpoint but I dont include that in the price of the rifle ;)
  9. Jun 3, 2011 at 2:42 PM
    #149
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    That looks great. I'd like to get a can too someday. For now I put my 552 back on it until I order a ADh-68 for my Aimpoint to try that out. I'm not liking the GG&G co-witness so it's being sold off.
  10. Jun 3, 2011 at 4:57 PM
    #150
    norcal4banger
    Jack
    Good info.
    Maybe I should tell what I'd be using it for. It'd be mainly a plinker at the range but I would also like to use it for squirrel and rabbit hunting. And now a buddy of mine is talking about coyote hunting. I probably wouldn't being going a whole lot so maybe a top of the line gun wouldn't really be something I need.
    Also, I would like to have to short range scope and something for long range. From what I understand, I can have both mounted and flip one to scope to the side to use the other?
    Here is the one I was looking at and might go for unless more research changes my mind: (The one I was shown looked exactly like this minus the iron sights)
  11. Jun 6, 2011 at 12:37 AM
    #151
    norcal4banger
    Jack
    Getting it tomorrow. Wheres the cheapest website to buy sites/scopes/handguards/ etc? It doesn't come with any sights whatsoever. I'm wanting to get magpul front and rear flip sights
  12. Jun 6, 2011 at 3:44 AM
    #152
    kinetik873
    Josh
    Springfield, Va.
    '08 TRD
    Bravocompany.com or Brownells
  13. Jun 6, 2011 at 4:35 AM
    #153
    rob_s
    SE FL
    So, this then?
  14. Jun 6, 2011 at 4:57 AM
    #154
    28ØØ3
    boss
    08 DCLB SR5 4WD
    VatoZone Especial
    definately Aimsurplus.com :thumbsup: (free shipping on almost everything)
  15. Jun 6, 2011 at 5:16 PM
    #155
    norcal4banger
    Jack
    That'd be the one. Got it today and also had G&G sights put on. Im gonna get my self a red dot when I pick it up in 10 days. About to be the longest 10 days of my life
  16. Jun 7, 2011 at 6:48 PM
    #156
    GP100
    GP100 Well-Known Member
    Paul
    RI
    '06 TRD Offroad
    Check dsgarms.com for the magpul stuff.
  17. Jun 11, 2011 at 11:30 AM
    #157
    Packman73
    2007 TRD Off Road
    Alright, I finally got it the way I want (minus a Magpul BAD lever) AND got to sight it in this morning. Actually I just got it real close @ 50yrds but I still need to fine-tune @ 100yrds.
    I really like the Aimpoint but I didn't really do any quick shooting with it this morning; it was all bench (bed of Taco) shooting. I also like my new ADh-68 mount very much. I was thinking of putting my Eotech back on this rifle but I'm not so sure that now I won't just keep this set up.
  18. Jun 15, 2011 at 9:07 AM
    #158
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I live in California.
    I have a Colt SP1 all original, built in 1971, pre-ban.
  19. Jun 15, 2011 at 10:47 AM
    #159
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Very nice!
    I bet that is worth some money!
  20. Jun 18, 2011 at 11:28 AM
    #160
    norcal4banger
    Jack
    Sorry about lack of updates. I've been shooting. The rifle on the bottom is my M&P 15, top is my buddies Stag. (Yes, I know 30rd clips are illegal in CA, they're his and he goes out of state a lot. Have one in mine for pic purposes only)
    Magpul stock, grip, and foregrip. GG&G back up sights (which I have returned because they don't work on my gun) and some P.O.S IR scope. Just my little toy and coyote gun.
