AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Nov 9, 2017 at 7:15 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    "H-Minus" and "Strike Hold"
    scottalot likes this.
  2. Nov 9, 2017 at 9:02 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Cross posting, looking for recommendations.
    My Aero AR10 started acting up this week. Long story, but I started having failure to eject issues last week when I went out to shoot. Every round would fail to eject and cause a double feed. I traced it back to the extractor on the BCG. It would either disengage the empty cartridge before it cleared the chamber (so it would only pull it half way out), or do the exact opposite and pull it out but not release it. As the bolt moved forward again, the empty casing would stick out of the ejection port at a 45* angle and then make contact with the leading edge of the ejection port and get stuck between the bolt face and cause a jam. Contacted Aero and still going back and forth with them about different things to try before they even mention the word "warranty". Only have about 200-300 rounds through the build.
    Things I've tried:
    • Everything is clean and /or oiled and shows no physical signs of wear or damage.
    • Tried a separate BCG and had no failure with two different types of ammo.
    • After removing the O-rings from the extractor spring, the BCG now will not let go of the casing unless I physically reach in to the ejection port and pull it out. (Takes a little force to get them out). The casings are getting chewed up pretty bad. Two O-rings total and I tried it in several configurations (both rings in, one ring, no rings and just the spring)
    The BCG is the nickel boron coated version from aero and some dude at the range that saw I was having issues mentions that nickel boron makes the surface of the metal harder and in turn makes the tolerances closer so the BCG might be tight and needs to be broken in. That true? I know coatings do take up some tolerance, but I'd imagine a company with the name "Precision" would account for that if necessary.
    Separate issue: Now this week I started having double fire issues. Fire on trigger pull and fire again on slow release to reset. Normally that would be cool (like the echo trigger), but it's not consistent so it's all coming apart this weekend to check for abnormalities. I'm lost.
  3. Nov 9, 2017 at 9:17 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    If I only had the funds. Spent to much last month, have to be good this month.
    On a side note, I got my concealed pistol license in the mail. Took less than two weeks after I put in my paper work. Not really to bad. They told me up to 45 days. Felt weird to carry for the first time yesterday. Just not used to it yet. Of course, I want another carry gun now. CZ P07 has really caught my attention.
  4. Nov 9, 2017 at 10:02 AM
    Extra Hard Taco
    R.J.
    Devil's Island
    I could be missing something in your post but it sounds like the spring on your extractor is bad. You said you tried a new bolt group and it worked fine? If so remove the extractor from the good group, and use it to replace the extractor in question and see if that works.
    scottalot and TomTwo like this.
  5. Nov 9, 2017 at 10:13 AM
    GHOST SHIP
    GHOST
    Built about a year ago. Already in contact with Aero, going back and forth with them currently.
    I though about doing that after I came home from the range the second time and was cleaning everything. Will try that soon. Just trying to get Aero to send me or sell me a new extractor and spring has become a hostage negotiation.
  6. Nov 9, 2017 at 10:16 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Swap the extractor spring but also compare the extractors side by side and see if one is out of shape.
    For the other issue check your trigger pins, see if you can replicate the issue with dry fire (upper removed, using your hand to catch the hammer)
    scottalot, GHOST SHIP and Tlook like this.
  7. Nov 9, 2017 at 10:59 AM
    Extra Hard Taco
    R.J.
    Devil's Island
    Whatever the outcome keep us updated. :thumbsup:
  8. Nov 9, 2017 at 12:47 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  9. Nov 9, 2017 at 12:58 PM
    texasfight
    texasfight Well-Known Member
    Doug
    2009 Super White double cab TRD
    Rigid 32 in light bar, Back Rack, 265/75r16 General Grabber AT2's mounted on FJ Cruiser Trail Team wheels
    Red Falcon!
  10. Nov 9, 2017 at 12:58 PM
    95 taco
    95 taco Battle Born
  11. Nov 9, 2017 at 4:51 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    I love mine! Though mines a 9mm and not a 22lr....but still quite a lot of fun!
  12. Nov 9, 2017 at 5:11 PM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    My AR9 "pistol" is like an SBR with a "hand brace." Haha!
  13. Nov 10, 2017 at 6:35 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Isn’t that awesome!
    Tlook, TomTwo, Key-Rei and 1 other person like this.
  14. Nov 10, 2017 at 7:03 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    What’s happening a lot now is it hat dealers are getting deals like buy 10 AR’s and get 3 free etc from disturbers and cost averaging....my local dealer had Ruger AR’s where he got 4 free when bought 10 which he sold them for $459 each....
    username[QUOTED] and scottalot like this.
  15. Nov 10, 2017 at 7:10 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    I do feel lucky. Most of my buddies waited way longer than I. That's an interesting law. I'm kinda surprised everyone isn't required to get training before they can purchase firearm. We've all seen idiots at the range. Hell, I've even had family members almost be shot by idiots that don't know what they are doing. Still would suck to have to wait that long.
    smugly and scottalot like this.
  16. Nov 10, 2017 at 7:19 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Same in Michigan. Just have to do that background check form, if you have an concealed permit you get to skip that part. So now for me, it's easy peazy. To bad I'm broke.
    smugly and scottalot[QUOTED] like this.
  17. Nov 10, 2017 at 7:23 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    It's pretty much the same in Michigan, but you are required to register your handgun with the police in 10 days from purchase. You just drop your info off to them, nothing special.
  18. Nov 10, 2017 at 1:00 PM
    wilcam47
    Will
    Bourbon state
    Takes me longer to fill out the paperwork and open my wallet;) LOL but same here with a permit no NICS check just pick out your rifle and head to the checkout counter! LOVE IT!
    TomTwo, scottalot[QUOTED] and smugly like this.
  19. Nov 10, 2017 at 1:43 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    So if i wanted to build an AR in 6.5Grendel i can use a regular AR15 lower right? How about the upper?
    I know i need a 6.5 Grendel specific BCG and barrel just not sure what else. Ive got some research to do!
    Holloman likes this.
  20. Nov 10, 2017 at 2:12 PM
    Bullnettles
    Bullnettles Well-Known Member
    Jared
    Houston
    2017 OR DCSB
    Lower will be fine. You need a 6.5 specific bolt, not the whole BCG. You can get a barrel/bolt set and swap into a regular AR-15 and be set.
