AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Nov 24, 2017 at 2:31 PM
    Soflanick
    Soflanick Well-Known Member
    Nick
    FLORIDA
    2001 tacoma prerunner
    5100 front, 5125 rear, 2"all, old ARE topper, 16x8 XD enduro's on 265/75r16 KO2's
    i too have a cv-life bipod, its quality, can't speak for the optic either
    Doughnut Spaghetti likes this.
  2. Nov 24, 2017 at 7:16 PM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    MadDaddy likes this.
  3. Nov 25, 2017 at 8:14 PM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    wilcam47 likes this.
  4. Nov 25, 2017 at 9:15 PM
    MadDaddy
    Many & varied
    How was y'all's Black (gun) Friday? We plinked targets across a peanut field. Younger cousins had a blast getting to shoot ARs for the first time:
  5. Nov 25, 2017 at 10:39 PM
    A Salt Weapon
    A Salt Weapon Well-Known Member
    T
    Southeast Alaska
    2017 Blue DCSB TRD OR
    Mine just showed up today and installed it. No live fire yet but it passes my function checks.
    Trigger feels like crap coming from having an ssa-e on every AR, but hopefully under Fire it won’t be noticed.
    757yotas[QUOTED] and scottalot like this.
  6. Nov 26, 2017 at 9:44 AM
    deog
    deog Well-Known Member
    snicklefritz
    Las Vegas. As far west as you can go.
    work in progress
    gucci interior and chandelier.
    Questions please.
    I bought a M & P 10 sport.
    I want to put a magpul moe fixed stock on it. I know I need a A2 style rifle length buffer tube and spring, my question is can I run the buffer it has now, or do I need a different buffer ?
  7. Nov 26, 2017 at 10:32 AM
    A Salt Weapon
    T
    Southeast Alaska
    Depends on the stock, a rifle stock uses a longer buffer, however you might be able to use your existing buffer. Does it run with the shorter buffer? That would be the test, might even work with your existing spring too, put those in the new stock and see how much tension there is. If it cycles by hand you’re probably gtg. Try some 5.56 and .223 and make sure it cycles both reliably.
    scottalot likes this.
  8. Nov 26, 2017 at 10:35 AM
    A Salt Weapon
    T
    Southeast Alaska
    On another note, why would you want to put a fixed stock on there anyways? Unless required by law (it appears you’re in Vegas, NV so you should be gtg with anything you want) no reason to go fixed. Plenty of options to achieve your desired LOP and cheek weld without the limitations of a fixed stock IMO.
    smugly and scottalot like this.
  9. Nov 26, 2017 at 10:37 AM
    deog
    snicklefritz
    work in progress
    It's a 308. Needs a rifle length buffer tube and spring to work with the stock, just not sure if the buffer needs to change.
    scottalot and TomTwo like this.
  10. Nov 26, 2017 at 10:41 AM
    deog
    snicklefritz
    work in progress
    It is a range toy for bench shooting. Don't care for a collapsible stock. Have a rifle length stock on one of my AR's and find it to be comfortable and perfect length of pull. I live in Nevada, don't have to worry about the compliant nonsense. When I moved from Long Beach, all my bullet buttons fell off at the state line. When I bought the AR10, walked in, said that one, NICS background check on the phone while I was right there, filled out my paperwork, out the door in 10 minutes tops. Free America.
  11. Nov 26, 2017 at 10:47 AM
    A Salt Weapon
    T
    Southeast Alaska
    Ahh missed the .308 part, makes since now with the M&P10 name.
    I’d still try with the shorter buffer, I know the UBR on my .308 uses a carbine buffer/spring.
    Better to try the shorter buffer first, before putting in a longer rifle one and damaging the tube if it needs a short one.
    .308 and buffers are picky though, I’d still start with atleast an H1 carbine buffer, good idea to use a rifle length spring first so there is enough pressure on the buffer.
  12. Nov 26, 2017 at 11:38 AM
    deog
    snicklefritz
    work in progress
    I know it needs a rifle length tube and spring. The buffer is what I am not sure of, and and am not really getting anywhere with that.
  13. Nov 26, 2017 at 12:09 PM
    Texas Taco
    Texas Taco Well-Known Member
    U.S.
    2016 TRD OR DC 4x4 QS
    Icon stage 4 w/RXT leaf pack and shocks, Icon hydraulic bump stops, LT285/75R16 BFG KO2s, 30" Rigid light bar, HIDs, and window tinting. More to come...
    For only $45 I'd try it out. I have an ALG trigger on my Yugo AK (yes I know this is an AR thread). While stock AK triggers are usually garbage to begin with, I was very impressed with the ALG trigger. If I didn't already have an SSA-E on my DD AR, I'd go with ALG without hesitation.
    Please feel free to correct me if I am wrong, but I was told ALG is a "sister company" of Geissele?
  14. Nov 26, 2017 at 12:34 PM
    MadDaddy
    Many & varied
    Yes, run by his wife. Her goal is affordable quality parts, not high-end competition parts. And hey, I'm Pro-AK over here. I'm looking at the PSAK-47 right now but I don't care for the Ferrari Testarossa style front grip.
  15. Nov 26, 2017 at 12:44 PM
    Texas Taco
    U.S.
    Makes sense. I have no experience with ALG's AR products but I'd definitely go with them.
    Not familiar with the PSAK-47. I'd look it up but our bandwidth here is crap. Couldn't you swap the front grip with a different type? Wooden or otherwise?
  16. Nov 26, 2017 at 1:11 PM
    Texas Taco
    U.S.
    In other news, I picked up a new Trijicon TA31RCO-C4MP (USMC version) on Gunbroker the other day for $1100. Hadn't been able to find that particular model anywhere else for less than $1,466. Pretty excited to finally get one.
    Holloman, TomTwo and scottalot like this.
  17. Nov 26, 2017 at 1:25 PM
    A Salt Weapon
    T
    Southeast Alaska
    Run the one you already have, worst case it doesn’t have enough weight to reliably cycle the weapon. The only difference between a rifle buffer and carbine is the length and weight. The weight can be made up with a heavier carbine buffer, the length is irrelevant, to the point a rifle buffer should be obselete.
  18. Nov 26, 2017 at 11:04 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    What kind of hard case are you guy's using to carry your AR in. 16 inch barrel with scope.
  19. Nov 27, 2017 at 5:37 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    The harder the better, “she says”
    :eek::D
    Which do you prefer?
    Plastic case or metal case?
  20. Nov 27, 2017 at 6:50 AM
    smugly
    Doug
