AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Apr 13, 2012 at 7:17 AM
    #1661
    Richard Cranium
    Richard Cranium The lice...they hate the sugar
    Ted
    Omaha, NE
    2013 Raven FR-S
    Forever sideways and smiling :D
    I'd say your best purchasable option, yes.
  2. Apr 13, 2012 at 7:19 AM
    #1662
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    More money into the pit :rolleyes: alright. I think I'm gonna buy better Rings too rather than rely on those shitty BSA rings
  3. Apr 13, 2012 at 7:19 AM
    #1663
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    It's an option, yes. If you're going that route, you might just cut the prongs off your current GB with a dremel. You won't even have to take it off the gun. if you love it, then you can replace the GB if you want a cleaner look.
    You can jump to about the 4:40 mark here and get an idea on what you need to cut if you go that route.
    http://www.youtube.com/watch?v=I5rPPyYdFUs
  4. Apr 13, 2012 at 7:21 AM
    #1664
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    Id rather spend $30 on a new GB than have a cut off piece of metal on there
  5. Apr 13, 2012 at 7:25 AM
    #1665
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  6. Apr 13, 2012 at 7:28 AM
    #1666
    Richard Cranium
    Ted
    Omaha, NE
    2013 Raven FR-S
    x2
  7. Apr 13, 2012 at 7:29 AM
    #1667
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    Any suggestions on halfway decent rings? I want an accessory rail on top. Gonna mount a red dot on it later on
  8. Apr 13, 2012 at 7:30 AM
    #1668
    Polymerhead
    Missouri
    That's gravy too. Only issue is that it might be a little unsightly if your barrel isn't parkerized under the block. At less than an inch long, it's not going to cover the same real estate as the original block so you're probably going to see the front pin hole. Also, I can't guarantee that the lo-pro block will be compatible with the handguard cap, which is needed to keep your handguards on (it's that round piece of metal right behind the front sight). Maybe Richard can chime in on that.
  9. Apr 13, 2012 at 7:33 AM
    #1669
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    X3
  10. Apr 13, 2012 at 7:34 AM
    #1670
    Richard Cranium
    Ted
    Omaha, NE
    2013 Raven FR-S
    No clue...only had free floats :notsure: That's a good point though..I didn't think of that.
  11. Apr 13, 2012 at 7:38 AM
    #1671
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I dont see why it wouldnt work.
  12. Apr 13, 2012 at 7:41 AM
    #1672
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    the flip up sight/ gas block is always an option
  13. Apr 13, 2012 at 7:48 AM
    #1673
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I think most people use some sort of canteliver rings for mounting a scope on their AR. I went with the Nikon ones, they were cheaper than the others but were a pain in the butt to align properly. Its almost a requirement to have it bore sighted with a laser to get the scope centered first prior to shooting. I didnt and it took me forever to get it sighted in.
  14. Apr 13, 2012 at 7:49 AM
    #1674
    burnseason
    burnseason TENNESSEE VOL
    Tucker
    Khost, Afghanistan
    2011 TRD Sport double cab long bed 4x4
    none
    I do. Bushmaster carbon 15. Been a great rifle and I couldn't be happier.
  15. Apr 13, 2012 at 7:55 AM
    #1675
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    Ya I always get it bore sighted after messing with the optics. And I don't want a flip up front sight. With the scope there is no room for a rear sight.
  16. Apr 13, 2012 at 7:56 AM
    #1676
    Polymerhead
    Missouri
    I use the bore-sight method for all my guns. For an AR, take the upper off the lower and take the BCG out. Then put it in your rest, on some bags or prop/squeeze/cram/jury rig it in place with some towels between your rifle bag and range bag - whatever works so it doesn't move. Adjust it so you can see the target at 25 yds through the bore of the barrel. Then without moving it, raise your head up to look through the scope and adjust your crosshairs to match. You'll be on paper at 25 and can make adjustments from there.
    Works every time and keeps me form needing to buy a laser boresighter. Plus it's a cool trick to pull out when you see some poor sap at the range having trouble.
  17. Apr 13, 2012 at 8:05 AM
    #1677
    Richard Cranium
    Ted
    Omaha, NE
    2013 Raven FR-S
    I beg to differ...
    Gen II Magpuls, 1" rings, same scope as yours. Curve of the rear eyepiece fits perfectly flush on top of the front and rear sights.
  18. Apr 13, 2012 at 8:09 AM
    #1678
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    your front ring is also on your handguard. He doenst have FF rails.
  19. Apr 13, 2012 at 8:10 AM
    #1679
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    +1, i never thought of that :thumbsup:
  20. Apr 13, 2012 at 8:14 AM
    #1680
    Richard Cranium
    Ted
    Omaha, NE
    2013 Raven FR-S
    Touche...nothing freefloats on the brain I guess.
