AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Dec 7, 2017 at 8:37 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    That would be a great start.
  2. Dec 7, 2017 at 8:38 AM
    smugly
    Doug
    Nothens FUNNER than an auto RUNNER!!!! (Well semi auto)
    Cr250jumper likes this.
  3. Dec 7, 2017 at 8:50 AM
    BenTheMan
    BenTheMan Well-Known Member
    Ben
    Portland
    2012 TRD Sport 4x4 AC
    Truck Nutz
    Get the 5.56 version. You can pickup on of these to easily convert it to .22 for when you want to plink.
    M&P 15's have popped up a couple times recently for $350. They sell out fast!
    3378jakesr5 likes this.
  4. Dec 7, 2017 at 8:51 AM
    DBTaco
    DBTaco Well-Known Member
    NC
    '08 4x4 TRD off road
    Most AR 15's shoot both .223 and 5.56, correct?
  5. Dec 7, 2017 at 8:53 AM
    BenTheMan
    Ben
    Portland
    Truck Nutz
    Correct for the most part. Ones rated for 5.56 can shoot .223 but not the other way around (although realistically you could shoot either in a .223 rated barrel). 95% of new AR's come in 5.56 for that reason.
    DBTaco[QUOTED] and smugly like this.
  6. Dec 7, 2017 at 9:35 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I did a couple shots in the back yard and it was a little high maybe an inch but nothing I should have missed at that close range. I dunno, maybe I pulled the trigger at the last critical second and sailed over it. also there was a little snow on the ground so any blood would have been easy to see. not a drop or speck of anything..
    scottalot likes this.
  7. Dec 7, 2017 at 10:48 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    I'd build it yourself. It's easy and you'll figure out everything about
    Could also build one if you're up to the task. It's pretty easy really.
    scottalot and BlazingInfernoTaco like this.
  8. Dec 7, 2017 at 10:54 AM
    BlazingInfernoTaco
    BlazingInfernoTaco Well-Known Member
    Fort Worth, TX
    2016 Inferno Tacoma TRD Sport SB/AT "PreRunner"
    I had only been "into" guns about 6-8 months before I built my own AR. There are tons of videos that'll get you through it and you really only need a few tools.
  9. Dec 7, 2017 at 11:33 AM
    smugly
    Doug
    Well if you were pointed down hill, you would’ve had to been already shooting lower because of lack of bullet trap. As they say. Aim down shoot down,. Aim up shoot up! If you thought you pulled up, that would’ve added to your bullet flying higher than it normally would at that distance, and that could account for your miss. I’m sorry to hear that
    scottalot and wilcam47[QUOTED] like this.
  10. Dec 7, 2017 at 6:58 PM
    turbomkt
    turbomkt Well-Known Member
    Santee
    '13 Sport
    CBI Offroad bumper
    scottalot, Sleipnir and teamhypoxia like this.
  11. Dec 7, 2017 at 7:34 PM
    wilcam47
    Will
    Bourbon state
    well I checked it today and theres really no telling what or where the bullet was going...as it turns out the rear sight was almost ready to fall off!! I didnt bother to check it because its brand new!! wth!! both the windage and elevation were literally about to fall off! So I tightened it down and its back to where it should be shooting! Going out the for the last day tomorrow.
  12. Dec 7, 2017 at 7:48 PM
    smugly
    Doug
    Good Luck!
  13. Dec 7, 2017 at 8:58 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Update #2:
    New BCG is on it's way from Aero. They took care of it and I'm grateful for that. Hopefully it solves the issue.
    On a separate note, i figured out my double fire problems. Ordered a new complete trigger from primary arms last week (trigger, hammer, disconnect). It arrived today and as I was disassembling the lower to install the new trigger, I noticed that the hammer spring was on backwards. :facepalm:. Feel like a complete idiot. It's a solution I've suggested to several people that solved the same problem. I didn't think to double check the spring orientation because I purchased the complete lower from a vendor that orders them direct from Aero. Just goes to show, you should always double check even factory builds. Oh well. At least now I have an extra trigger.
    Guess I need to build a new lower.
    :anonymous:
  14. Dec 7, 2017 at 9:08 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    First time ordering tools on Amazon? I was on there today and they have a promotion going on where if it’s your first time ordering tools they give you a percentage off up to $25 off.
  15. Dec 7, 2017 at 9:42 PM
    A Salt Weapon
    A Salt Weapon Well-Known Member
    T
    Southeast Alaska
    2017 Blue DCSB TRD OR
    Probably the first time buying a power tool from there. I’ve picked up some smaller hand tools from there but nothing over $25 or so.
  16. Dec 8, 2017 at 7:00 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    I get my High Velocity Arms extended mag release in the mail. They shipped it really fast. I got it because I like the knurling on it, matches other parts on my AR9 (all about the details). Anyway, the holes for the screws that hold it onto the button where not machined correctly so the screws will not go down far enough to properly secure the release to the button, leaving it to shake around. They also sit probably 3mm over the release. I emailed them, and they sent me another one, no questions asks. I hope it fits. Looks sweet. I think I'm going to try to find shorter screws to see if I can get this one to work and have a spare for another build.
    How mine looks:
    How it's supposed to look like:
    scottalot and TomTwo like this.
  17. Dec 8, 2017 at 8:31 AM
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    I dislike you ALL!
    I bought my AR15 M&P Sport because the new law as of 1/1/2017 here in the state Kommiefornia.
    Then I saw this thread
    go shooting with a buddy
    bought a 300 BO upper, new lower and flip up sights.................................
    I am done I said. No more rifles for me cause I am a handgun guy, I have 10 currently....................
    Then I did a bit of research in this thread...................
    So many pretty rifles
    Some custom
    some off the shelf
    and then it hit me
    I want to build my own AR from start to finish......................................
    I would love to say thank you TW, but once again I feel as though this is all part of a bigger conspiracy.................................
    to keep my wallet thin
    projects stacked everywhere as my wife shakes her head and asks
    "Aren't you trying to retire soon?"
    I simply smile and say this is the last project, I swear, Baby.
    pics as I walk along this journey.
    Shout out to @GHOST SHIP , a great guy
    and a BAD INFLUENCE!
    He has volunteered to be the guy who says as he looks over my shoulder,,,,,,,,,,,,,,,,"Do you really want to do that now"
    Chipskip, smugly, BenTheMan and 5 others like this.
  18. Dec 8, 2017 at 9:22 AM
    GHOST SHIP
    GHOST
    rmepilot, wilcam47, smugly and 5 others like this.
  19. Dec 8, 2017 at 9:48 AM
    BenTheMan
    Ben
    Portland
    Truck Nutz
    My Vortex Strike Eagle 1-8x came in yesterday. Got it for a stupid good price on Black Friday. Gonna get it torqued and leveled tonight then go sight it in tomorrow. Very excite!
  20. Dec 8, 2017 at 12:28 PM
    A Salt Weapon
    T
    Southeast Alaska
    Are those illuminated or just a normal reticle?
    BenTheMan[QUOTED] and scottalot like this.
