AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Apr 13, 2012 at 8:18 AM
    #1681
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Thank for the help guys. Im just gonna get a lo pro GB and lower rings and see if that helps at all
  2. Apr 13, 2012 at 8:27 AM
    #1682
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Get leupold rings if you go with standard rings. Also make sure you get the correct diameter as well, either 30mm or 1"
  3. Apr 13, 2012 at 11:04 AM
    #1683
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not talking about rules.... that's why I mentioned shooting on BLM.
    It's just common sense.
    Steel core ammo starts fires. It's not smart to shoot it when it's dry or "fire season" unless you're in an area where there's nothing to burn.
  4. Apr 14, 2012 at 6:36 PM
    #1684
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    I cut mine off to fit my Spike's SAR rail. Used a ban saw but a 4.5 grinder with a cut off wheel, not a grinding disk like the tard in the video, would work fine. I had to take my rail off today and send it back to Spike's since the lock screw stripped and the rail would walk off of the gun when I would shoot it supported. So I thought I'd take a few pics to show ya what it would look like since the topic was brought up. I think it looks a bit goofy but I'm used to my free float.
  5. Apr 15, 2012 at 7:08 AM
    #1685
    HUNT
    HUNT Well-Known Member
    Tommy
    Wildwood Ga
    2003 Double cab 4x4
    Bilstein 5100 set @ 0, OME 881,Wheelers 5-leaf, OME NitroCharger Sport shocks, 4-RUNNER LIMITED WHEELS, Duratracs, 265/75/16
    Picked this up a couple days ago...Ruger 556
  6. Apr 15, 2012 at 12:38 PM
    #1686
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    added some goodies to the AR.. just wanted to share
    Troy Modular Combat Grip
    K-15 KRYPTONYTE CARBINE GREEN LASER
  7. Apr 15, 2012 at 12:38 PM
    #1687
    hillbillytoyo
    hillbillytoyo Well-Known Member
    Daniel
    WV
    17 Tundra Crewmax SR5 TRD Off Road.
    G2 bed cover
    Painted the lower and added the Magpul handguard yesterday.
  8. Apr 16, 2012 at 11:52 AM
    #1688
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    just picked up a nasty 24'' heavy barrel.... It will be built tomorrow into a full gun
  9. Apr 16, 2012 at 6:12 PM
    #1689
    Rich91710
    Rich
    Los Angeles
    08 Base
    24" heavy?
    Bipod for that somabitch!
  10. Apr 16, 2012 at 7:35 PM
    #1690
    TexasIslandBoy
    Andrew
    South Texas. SPI
    O ya! Ordered about 300$ more shit today... got the bipod and scope mount
    It shouldnt be that heavy its flutted pretty well but It will be pretty long with the A2 stock.
  11. Apr 16, 2012 at 7:52 PM
    #1691
    Rich91710
    Rich
    Los Angeles
    08 Base
    Better than an A1 ;)
    But I'd seriously consider a PRS... that'll get out almost 11 1/2, and the adjustable cheek weld can be handy.
  12. Apr 16, 2012 at 8:19 PM
    #1692
    TexasIslandBoy
    Andrew
    South Texas. SPI
    Ya I plan to upgrade soon I just couldnt find anything local so I got what I could.
  13. Apr 17, 2012 at 9:29 PM
    #1693
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Just started ordering stuff for my first AR build...
    Got a stripped Black Weapons Armory lower and getting my stripped Vltor upper next weekend.
    The only other things I know for sure that I want is the BCM/Vltor charging handle and magpul furniture.
    The lower and receiver are both from companies based out of Tucson, and I want to support Magpul because of the money they raised for Japan after the earthquake/tsunami (My mom is from Tokyo and her good friend lost his wife and daughter that day).
    I think ill just get the rest of the stuff as part of a kit or something from somewhere. Haven't really gotten that far yet. Just kind of started out as wanting to support local businesses; then I decided to slowly put it together.
  14. Apr 17, 2012 at 9:38 PM
    #1694
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    Okay guys I've been toying around with the idea of a roof mounted gun rack. Only twist to it is that I'm gonna use the police style rack. (Locked in place unlocked by a hidden button) any ideas how I could mount something study enough to the roof to support it without drilling through the roof itself?
  15. Apr 18, 2012 at 5:47 AM
    #1695
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    pics or link to stripped upper?
    since your building the upper from scratch the only real "kits" you can get now would be the Lower parts kit and the stock assembly kit.
  16. Apr 18, 2012 at 6:25 AM
    #1696
    Dred777
    Dred777 Well-Known Member
    Ed
    Delaware, OH
    '11 TRD Off Road
    Nerf Bars, Color Matched UndercoverSE Tonneau Cover
    I would suggest getting the factory roof rack and then mounting something to that. :)
  17. Apr 18, 2012 at 6:33 AM
    #1697
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    I mean inside of the cab. Not outside :D
  18. Apr 18, 2012 at 6:39 AM
    #1698
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    You know what the Spikes logo really is, right?
  19. Apr 18, 2012 at 7:24 AM
    #1699
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    is it not a spider?
  20. Apr 18, 2012 at 7:32 AM
    #1700
    xA101x
    xA101x Well-Known Member
    AJ
    Idaho
    2017 TRD PRO MT
    How do you like that laser? I was thinking about getting one of these. Is it bulky, heavy, ect.?
