AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Jan 18, 2018 at 8:41 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    We have a cousin to the ground hog also. Called "rock chucks" they are fun to shoot also.
    scottalot and TomTwo like this.
  2. Jan 18, 2018 at 8:55 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    I here there funnier than ground hogs! lucky you!
    scottalot and wilcam47[QUOTED] like this.
  3. Jan 19, 2018 at 5:09 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    For you AR9 guys. I found a pretty good deal on a mag pouch if you're looking for one.
    eBay $25 shipped
    . Holds 8 stick mags. 2 left.
    Galati Gear GLMP9 Mag Pouch 9mm
    Sleipnir, wilcam47 and TomTwo like this.
  4. Jan 22, 2018 at 9:10 AM
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    I just need some advise probably been mentioned plenty of times but 900+ pages to read is a bit time consuming. i am about to pull the trigger on PA-10 Gen2 Upper and Lower .308 any advise? what to look for any specifics plenty of reviews out there but i trust tacomaworld folks
    scottalot likes this.
  5. Jan 22, 2018 at 9:29 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Avoid carbine length gas AR308 barrels. Absurdly overgassed.
  6. Jan 22, 2018 at 9:38 AM
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    but wouldn't an adjustable gas block fix that quite easy i mean the price allows for alot of play!
  7. Jan 22, 2018 at 9:49 AM
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    i figured for 299-399 range for the 18" i can live with that it wont be no competition but for piggies up to 200 yards max should be quite sufficient plus easier to maneuver in the blind
    TomTwo and scottalot[QUOTED] like this.
  8. Jan 22, 2018 at 10:04 AM
    golfindia
    Yes.
    pickup truck
    Yeah, but adjustable gas blocks are expensive and add complexity and also just more crap to break. i've got one on a 308 that has locked up and can't be adjusted anymore. Rifle only cycles with the suppressor on now.... Another good 308 AR item is a JP ent. enhanced extractor.
  9. Jan 22, 2018 at 11:26 AM
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    so what is exactly the problem with being over gassed im not very familiar with this! is the only negative more recoil and bounce to it? can't a heavier buffer spring and a muzzle break cancel out the effect a bit?
  10. Jan 22, 2018 at 11:38 AM
    golfindia
    Yes.
    pickup truck
    Heavier buffer and stronger spring only go so far. They can't delay the bolt unlocking enough. Overgassing causes cycling problems because case is still bulged from explosion while BCG begins moving back. Cases then don't eject, and the extractor rips off the rim. Mine was so violent that the bolt was pounding back into the receiver extension. If someone didn't notice or correct the issue, you could end up with a cracked lower. Plus..... 308 parts aren't all standard like the smaller AR15s. There are a bunch of different buffer sizes, spring sizes, weights. It will just save work to stick to at least mid length gas. Even in AR15s, rifle length gas is always softer and more pleasant to shoot.
    scottalot and sxe4533 like this.
  11. Jan 23, 2018 at 8:22 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Anybody use the Nordic Components Dedicated 22 upper? It looks pretty sweet and has a stainless barrel.
  12. Jan 23, 2018 at 12:47 PM
    golfindia
    Yes.
    pickup truck
    SLR. I paid extra for a "toolless" version which broke off after 10 rds. SLR said too bad, they don't make parts for It anymore so I converted it to Allen wrench adjuster. It fused in it's current positon and the Allen wrench adjuster is now stripped. junk.
  13. Jan 23, 2018 at 3:08 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    They build some very nice stuff...
  14. Jan 23, 2018 at 3:17 PM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Best upper I've found. They have a short barrel version too which I think I want if I build one.
  15. Jan 23, 2018 at 3:30 PM
    IPNPULZ
    going to be fun!
    I almost went with there AR-9 carbine but went with Sig MPX Carbine
  16. Jan 24, 2018 at 12:25 PM
    Wulf
    rock raisin
  17. Jan 24, 2018 at 4:32 PM
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
  18. Jan 24, 2018 at 7:45 PM
    Wulf
    rock raisin
    well.. I suppose that's better than the "it's protecting your life, don't cheap out on parts" comments I was expecting :luvya:
    Sleipnir likes this.
  19. Jan 24, 2018 at 7:54 PM
    YotalikesTacos
    YotalikesTacos Big Sexy Trail Limo
    Travis
    2017 Big Sexy Trail Limo TRD Offroad 4X4
    Here’s my 6.5 creedmore build. All I need is a new scope for it..
  20. Jan 24, 2018 at 7:56 PM
    YotalikesTacos
    Travis
    Anybody know of a good shop that does cerakoting in Southern California.
