AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Feb 24, 2018 at 10:42 PM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    scottalot and smugly like this.
  2. Feb 25, 2018 at 9:08 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    lol yeah it fucking blows
    scottalot[QUOTED] likes this.
  3. Feb 25, 2018 at 1:05 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Can someone school me on ar10s? I just need a quick dummies guide to choosing parts and building vs buying
    Are parts companies basically the same with ar15s as far as brand x is good brand y is crap? What are good prices/good brands for complete rifles?
    Minus glass, what should I budget and I'm assuming barrels and triggers are the must have quality parts?
    Is building one as easy as an ar15?
    I'm intimately familiar with the 15s but today was my first day behind a 10 and it's now a must have and all I shot was a dpms g2 I think with nothing done
    wilcam47, smugly and scottalot like this.
  4. Feb 25, 2018 at 1:46 PM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    I will make sure I say first and foremost, no! AR 10 are not as easy to marry different manufacturers together as A.R. 15‘s are. (Not exactly plug-and-play per say). As most manufacturers will tell you. You are safer to marry their uppers with their lowers, individual internal parts included. You can mix and match ar10 parts from different manufacturers but they are very specific and not all will work, you can either do it by trial and error or find AR 10 dedicated websites that will give you a heads up which manufactures mate with which manufactures and ones to stay away from. As far as barrels and triggers, yes both being equally as important, and can be greatly improved and you shouldn’t have any problems with aftermarket applications.
  5. Feb 25, 2018 at 1:50 PM
    JimBeam
    JB
    2015 Tundra
    So realistically I'd be better off for my first one to buy a basic model prebuilt and then upgrade parts as needed
    IPNPULZ, 95 taco and scottalot like this.
  6. Feb 25, 2018 at 1:54 PM
    smugly
    Doug
    Yes, I would highly suggest (and I break these items apart because it will save you about $100). Go to Palmetto arms by the A.R. 10 upper and then choose your lower and you can build one for about $570 out the door. If you buy the completed AR 10 from them it will cost about $100 more. In other words you’re paying them $100 to push the two pins in that holds them together. LOL
  7. Feb 25, 2018 at 1:58 PM
    JimBeam
    JB
    2015 Tundra
    of course PSA...they had an assembled one in the 1100 range today but the guy couldn't tell me shit about the parts
  8. Feb 25, 2018 at 2:01 PM
    smugly
    Doug
    The one thing I will add is make sure they’re both Gen2, meaning your upper is a GEN2 and your lower is a GEN2, because they do not mate with Gen1 even from the same manufacture (even though I don’t think they sell Gen1’s anymore anyway). But I would hold off on Palmetto arms for now because with this latest scare everybody has emptied their shelves
    scottalot likes this.
  9. Feb 25, 2018 at 2:02 PM
    smugly
    Doug
    That is definitely a little bit of a red flag, but the guys on here do talk highly of PSA
  10. Feb 25, 2018 at 2:05 PM
    JimBeam
    JB
    2015 Tundra
    I don't haha
    JimboAnz and scottalot like this.
  11. Feb 25, 2018 at 2:07 PM
    smugly
    Doug
    I've only done business with them once my self.
  12. Feb 25, 2018 at 2:25 PM
    smugly
    Doug
    Yeah, for sure! Good luck with that!
    Sounds like you might end up with two AR 10’s! LOL
  13. Feb 25, 2018 at 9:04 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    OD Green upper = cerakote
  14. Feb 26, 2018 at 8:32 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    The standard brand-name quality hierarchy is still there and translates to the AR10 platform as it is in AR15. Like @smugly said, fitment between brands gets a little janky for the bigger components (receivers for the most part, but I would probably stay within brand for barrels as well. Some manufacturers offer matched receiver sets which might be worth looking into but even buying from the same manufacturer should get you to acceptable specs. Building them is the same as AR15s assembly-wise with a couple minor location changes for detents that should be obvious once you look at it. You'll need new vise blocks and such since AR15 blocks won't fit the different geometry so keep that in mind. I actually like my AR10 trigger to be somewhat stock- it's a heavier rifle with heavier recoil and I wanted everything to feel "sturdy". I have an Aero enhanced trigger on one and an Anderson NiB trigger group on another. I have seem some guys run light weight triggers, but not many.
    Built my "nice" AR10 (long range) for about $1200-1500 (I haven't really done the math because I'm stimulating the economy like a true 'Merican) and my beater AR10 for well under a grand.
    Another thing to consider for AR10s is that they tend to be a little pickier on ammo vs AR15s. Some ammo manufacturers will use longer projectiles which makes the entire round ever so slightly longer and causes feeding issues in semi-auto which is not a problem for bolt-actions. My rifles like Fiocchi and Winchester, but hated ArmsCore. Haven't tried many other brands of ammo, but I've been meaning to. Word on the street is that steel ammo is a hard no-go, but that's just what I heard, and has not been tested yet.
    Tlook, smugly and scottalot like this.
  15. Feb 26, 2018 at 8:38 AM
    GHOST SHIP
    GHOST
    Try the Alumahyde, Scott! I used it on my AR9 and it came out amazing! Even painted one of my 15s FDE as well. Holds up great!
  16. Feb 26, 2018 at 8:39 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    PSA is a joke
  17. Feb 26, 2018 at 8:41 AM
    GHOST SHIP
    GHOST
    Matching wood grip is in process.
    Bagman, TomTwo, KRAMERICA and 7 others like this.
  18. Feb 26, 2018 at 8:46 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    GHOST SHIP[QUOTED] and scottalot like this.
  19. Feb 26, 2018 at 9:21 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    AR10 is an Armalite designation and is it's own pattern . It's completly different from the "308 AR" DPMS/SR25 pattern, which is much more common and probably what Everyone is familiar with. We generically call the 308 version an "AR10", but If you're googling around for parts, be sure to pay attention. These two versions aren't compatible, but the Armalite stuff is pretty rare. I ran across this upper/lower 308 combo the other day:
    http://www.chandlerhardwoods.com/product-p/ar10-kit.htm
    No affiliation, but i've bought stuff from them before....
  20. Feb 26, 2018 at 10:02 AM
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    Loving the wood.on that one..
    scottalot and GHOST SHIP[QUOTED] like this.
