AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Apr 28, 2018 at 6:21 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    smugly likes this.
  2. Apr 28, 2018 at 8:16 AM
    Phoosa
    Phoosa I never saw nothing.
    Truck
  3. Apr 28, 2018 at 10:10 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    I think trigger pull weight is important but the number isn't.
    I know if I want a trigger lighter or heavier but don't care what the number is.
    That said, if you know that the trigger you like is "x"lbs, then you go shopping for a trigger that is "x"lbs.
    Seems like a trigger scale would be an excellent thing for your buddy to own :D
    Phoosa[QUOTED] and CurtB like this.
  4. Apr 29, 2018 at 5:29 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I use an old digital fish scale. It is within 1 ounce of a real trigger scale.
    And I can weigh fish with it too. :thumbsup:
  5. Apr 29, 2018 at 5:38 AM
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    :eek: No!.... just no!o_O
  6. Apr 29, 2018 at 7:37 AM
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    I love it
    Bit when you have a FTF, does it seem fishy?
    CurtB[QUOTED] and Phoosa like this.
  7. Apr 29, 2018 at 7:39 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    No why? Please explain.
  8. Apr 30, 2018 at 2:17 AM
    smugly
    Doug
    At the end of the day, you can use whatever you want. But for starters, a fish scale has no built in shock sensor to freeze the numbers when the trigger breaks, to keep it from getting inaccurate readings. #2 although I don’t know the configuration of your particular fish scale. I would be willing to bet that you can not get a true in-line position, to measure the trigger in a straight back configuration in line with the trigger correctly., #3 where a digital trigger gauge usually ends, a fish scale usually starts. They are just two completely different functioning load cells. When was the last time you weighed a 1 lb. 4 oz fish. Fish scales just aren’t accurate enough @ very lowweights to engage correctly because they are designed to go up to number like 25-50 pounds. Remember, just because it’s digital, doesn’t necessarily make it more accurate. (Quality). If a person is measuring a 1.5 pound fish, they might want to re-look at there fishing ability! LOL
    (not to mention, the potential quality difference between the two also )
    45acp likes this.
  9. Apr 30, 2018 at 8:19 AM
    DirtyTerp
    DirtyTerp Well-Known Member
    Randy
    Freeland, MD
    '14 DCSB MGM
    And so It begins..... not to shabby for $51.99 shipped
    45acp, scottalot and smugly like this.
  10. Apr 30, 2018 at 10:33 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Thanks for the reply. I am well aware of all your points.
    1 I watch the numbers and listen for the firing pin.
    2 I made an extension, it will pull straight back.
    3 I have double checked with a 'real' trigger gauge a friend has. As I previously posted, my setting was within 1 ounce of his. I set triggers on my bolt rifles at 32 oz. 31 or 33 is close enough for me.
    4 I bought the scale in the 80s. I have set a lot of triggers, and weighed a few fish. I caught an 8lb 2 oz bass. I filled a jug with water to match that weight on my scales. Certified scale at the grocery store said.... 8lb 2 oz.
    5 No one has died from my method, yet ;) and no fish have died either. I C&R only.
    45acp, smugly[QUOTED] and teamhypoxia like this.
  11. Apr 30, 2018 at 10:40 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I havent used my digital fish scale for this but it does measure accurately in the low ranges it also has a Highest weight held, but I dont know if it would work on the the trigger break... We weigh our bass in the 2-3lb or higher range....that is a decent fish for us. Not a record but still nice to catch;)
  12. Apr 30, 2018 at 10:48 AM
    smugly
    Doug
    And that’s fine, obviously you have got it to work. But it seems for all of that fussing around, you could’ve just bought the right tool for the job for $45.
  13. Apr 30, 2018 at 10:52 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    JimBeam and smugly like this.
  14. Apr 30, 2018 at 10:56 AM
    smugly
    Doug
    Right, I get it. I’m not saying he broke some kind of international maritime law or anything! LOL. It just seems like for $45 it’s not worth the hassle in the times when it needs to matter. If it’s really not that big of a deal and you’re just checking, then obviously it works
    wilcam47[QUOTED] likes this.
  15. Apr 30, 2018 at 11:44 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
  16. Apr 30, 2018 at 12:12 PM
    JJ Customs
    Jay
    NV
    I picked up a couple Pelican 1750's a couple years ago when Costco had them for $199. They normally retail for $240ish now. I actually think the RTIC design is a little better and the wheels look like a much nicer design.
    scottalot likes this.
  17. Apr 30, 2018 at 12:51 PM
    JimBeam
    JB
    2015 Tundra
    They are...I have a pelican im3300 I think...maybe im3200 but either way...I like the rtic wheels better...and the latches are easier to open
    JJ Customs[QUOTED] likes this.
  18. Apr 30, 2018 at 1:00 PM
    Phoosa
    Truck
    Amazon has a bunch of Pelicans marked down at this moment.
  19. Apr 30, 2018 at 6:34 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Not much fussing around, and it saved me $45. I don't recommend anyone else try it. It was sooo difficult. :rolleyes:
  20. Apr 30, 2018 at 7:54 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I’ll never buy another hard case without the Storm push/pull latches. Sometimes it’s hard to tell which latches you’re getting but they’re worth a significant premium to me over the original Pelican style latches.
