AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. May 20, 2019 at 9:51 AM
    austin2009
    austin2009 Well-Known Member
    Austin
    Boise, Idaho
    Lifted and Locked 09 2.7L 2TR 4x4 5 Speed
    DRIVETRAIN- -4.56 Nitro gears -ARB rear locker -SPC UCA's -Fox 2.5" RR fronts/650lb coils -Bilstein 5100's rear -1.5" AAL -285 BFG KO2’s -16x8 MK6’s ARMOR- -ABR bumper -BAMF LCA skids -Cali Raised sliders RECOVERY- -Smittybilt XRC 9.5k synthetic winch -ARB OBA -Factor 55 Pro Link, Expert STEREO- -Pioneer head unit -Rockford T series speakers -Rockford 500 watt amp -Rockford P2D4 8" sub LIGHTING- -Calirasied ditch lights -Caliraised amber fogs -Hella Black Magic’s -Blue Seas fuse panel
    Hey guys, I need some opinions. I’m in the process of building a SBR. Trying to pick out some parts now, and I’m looking for some more knowledge. Ideally, I’d love a Noveske rifle. Noveske is local to me, and as we all know, builds great parts. My question tho, what names are equally as good, without the price for the name? I was considering forking out the money for a Neveske upper, lower and barrel. But I’ve also been really happy with the Aero Precision parts I have on my other guns. For those of you with experience, what do you think?
    rmepilot likes this.
  2. May 20, 2019 at 10:47 AM
    tagaman670
    tagaman670 Hafa Adai!
    joey
    Saipan, CNMI
    White "BAJA" DCSB
    performance shift knob +5hp decal Tint Rockford Fosgate 6x9's JL Audio 8" Sub RockFord Fosgate POWER 550x amp
    Bravo Company Manufacturing (BCM) is just as good if not better IMO
  3. May 20, 2019 at 11:07 AM
    austin2009
    Austin
    Boise, Idaho
    Than Noveske? I’ve heard good things about BCM.
    KY_Rob likes this.
  4. May 20, 2019 at 12:07 PM
    bringenufgun
    bringenufgun Well-Known Member
    Bill
    OFallon Mo.
    14 Tacoma regular cab 4X4
    none
    Spikes, BCM are both good choices.
    top two Spikes, bottom BCM. all run 100%.
    had a bad experience with Noveske. built a 10.5 300blk out and the upper receiver was out of spec, couldn't run the Noveske lower rear pin in the back of the upper. Noveske took forever to respond either by phone or email. finally got hold of the technical department. sent it in on my nickel. weeks went by, no response. got ahold of the tech dept about three weeks into this. long story short(er) after about six weeks i had the new upper.
    incredible weapon, just didn't expect an out of spec upper, nor a hassle getting it replaced.
  5. May 20, 2019 at 12:19 PM
    austin2009
    Austin
    Boise, Idaho
    Dang, that’s quite the hassle with the Noveske upper. I hear a lot about the Noveske uppers and lowers, being extremely tight fitting on those pins.
  6. May 20, 2019 at 1:16 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    There are quite a few great companies. LaRue, Noveske, BCM, PWS, Daniel Defense, Knights Armament, ect.
    Are you wanting to buy a complete SBR or just build it yourself and Form 1 it?
    I went the form 1 route myself. Picked up a nicer lower (a Rainier Arms Ambi lower when Mega was making them), the trigger i wanted, the stock i wanted then built my own upper. Ive built all my uppers minus 2 (a PSA upper and my PRI Mk12 Mod 0 upper) and all work just fine, have been reliable, and accurate. These days its more about just picking a manufacturer who has a good track record and has the features you want. but yo u can easily just do a lower and buy an upper. Just stick to "mil-spec" stuff and not stuff that mates specifically to something (like a brands lower to a brands upper)
    KY_Rob likes this.
  7. May 20, 2019 at 1:22 PM
    austin2009
    Austin
    Boise, Idaho
    Thanks for the response. I’m going to build it myself and form 1 it. I was really just curious if there was an advantage of buying a Neveske or a DD instead over an Aero Precision. In terms of quality. I hadn’t seen any bad reviews on them
  8. May 20, 2019 at 1:31 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Spikes.... They just charge extra money to engrave stuff onto the same lowers everyone else is selling for $39.
    All AR lowers are forged in one or two places. Every CNC machine milling them runs the same exact code. "Mil spec" does not mean quality. It just means it will pass the Mil. shittiness threshold.
    Buy a decent barrel made from a blank of known origin. Green mountain. Lothar walther, Krieger, Mcgowan, etc. Save your money on the rest of the parts and buy whatever is on sale.
    wilcam47 and austin2009 like this.
  9. May 20, 2019 at 1:45 PM
    Phoosa
    Phoosa I never saw nothing.
    Truck
    :drool::drool:
    Sleipnir likes this.
  10. May 20, 2019 at 1:50 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Only advantage would be ease in selling down the road. A person is going to be a lot more likely to buy a DD or Noveske over a home built AR.
    KY_Rob likes this.
  11. May 20, 2019 at 2:36 PM
    austin2009
    Austin
    Boise, Idaho
    Pretty much what I’ve gathered from asking around. I think I’ll just end up building it to my specs and budget, resale isn’t something I’m worried about.
  12. May 20, 2019 at 2:39 PM
    austin2009
    Austin
    Boise, Idaho
    Here’s the one I just finished.
    -Aero Precision lower
    -Odin Works upper
    -Odin Works rail
    -Odin Works BCG
    -Odin Works 16.1 barrel chambered in .223 wylde with a 1/8 twist
    -ALG 4.5lb trigger
    -Seekins Precision safety
    -Geissele maritime bolt release
    NWBoon, scottalot, CoastieRon and 3 others like this.
  13. May 21, 2019 at 8:55 AM
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    My biggest piece of advice. You will have this for the rest of your life (really difficult to sell a home built SBR). Pick the lower you really want, whether its $300 or not. I went cheap on my first SBR, now the lower just gets passed around as I build new stuff as I've never been happy with it (Spikes lower). Sounds like you want a Noveske, I say pick yourself up a Noveske. Small note on Noveske though, the only thing they have ever made themselves is barrels. They've never made any of their own parts, I'm not sure who's making them now, several years ago it was SMOS out of Grants Pass. Other great high-end options are Radian and American Defense Manufacturing. BCM is also great, not the "cool factor" of the others, but all the quality.
    I just submitted my 15th stamp, I know what I would do if I could go back.
    Chew and austin2009[QUOTED] like this.
  14. May 21, 2019 at 9:03 AM
    austin2009
    Austin
    Boise, Idaho
    Hey thanks for the advice! I ended up picking up an Aero lower last night. I’ve been happy with their products so far and haven’t found a bad review yet. I went with their M4E1 enhanced lower. So it’s got the flared mag well and the machined trigger guard on it. I like it. Picked up an upper as well, now trying to figure out what hand guard I want before having the cerakote done.
    CoastieRon likes this.
  15. May 23, 2019 at 12:14 PM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    What are you looking to spend? I personally think you pay for brand recognition when it comes to LMT, DD, KAC, BCM etc. Not saying they dont make good stuff.
    80% lower i picked up. I plan on getting a few more.
    golfindia likes this.
  16. May 26, 2019 at 12:34 AM
    Vabunch
    Vabunch Well-Known Member
    Jeremy
    Capron va
    17 tacoma trd or dcsb & 96 tacoma scsb
    Just finished this the other day
    TacoManOne, austin2009 and PapaBear like this.
  17. May 27, 2019 at 5:45 AM
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Ordered things to make my ar15 sbr shoot 9mm :thumbsup:
    Eventually I'll get a palmetto lower with the SB tactical pdw brace to have a dedicated pistol lower for it and make it a truck gun.
    Spinta 3.1" barrel
    Spinta 4" handguard
    FM Glock BCG
    FM 9mm buffer
    Endo mag
    Gen 3 PMAG
    Just need an optic and I'm thinking sig Romeo 5 when eBay does the 15% coupon to keep the budget build low :D
    This will be my 2nd AR9 I've built but first using a AR15 lower
  18. May 31, 2019 at 12:21 PM
    Sleipnir
    I'm a horse
    Asgard
    This thing is going to be short! 19" collapsed and 21 5/8" fully open!
  19. May 31, 2019 at 2:04 PM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    I love Spinta. They make great parts. Gonna be a bad ass build!
    Sleipnir[QUOTED] likes this.
  20. Jun 5, 2019 at 3:17 PM
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    16 months later the suppressor came in so worth the wait!
