AR-15 BS Thread
Discussion in 'Guns & Hunting' started by BulletToothTony, Feb 21, 2009.
  1. Dec 9, 2019 at 8:37 PM
    StaticOnTheRadio
    StaticOnTheRadio Well-Known Member
    TEXAS
    That lower is sweet!
    w.adventures[QUOTED] likes this.
  2. Dec 10, 2019 at 7:44 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    95 taco and Wixo[QUOTED] like this.
  3. Dec 10, 2019 at 7:55 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    I don't see it happening.
    Without getting political I think a lot of these bills are introduced with no hopes of getting approved, they're just introduced so they can latter say "See I'm a supporter of the 2A we tried but we just didn't have the votes."
    TomTwo, 95 taco, Bagman and 3 others like this.
  4. Dec 10, 2019 at 8:08 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Sad, but true.
    Would be great if it passed though.
    95 taco likes this.
  5. Dec 10, 2019 at 9:13 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    I know, I just said that hopefully they get some common sense laws on suppressors. For example: Its a suppressor why would even regulate them law.
    The_Hodge[QUOTED] likes this.
  6. Dec 10, 2019 at 9:13 AM
    Wixo
    Hank
    Tint, LED interior
    Cowabunga it is!
    Tlook likes this.
  7. Dec 11, 2019 at 11:21 AM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Not enough lol only ordered two when I bought the build kit and upper
    Tlook[QUOTED] likes this.
  8. Dec 11, 2019 at 1:17 PM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    Speaking of lights I got this retro surefire grip light. Light still works but the pressure switch isnt working. Ill have to see if surefire will warranty it.
    wilcam47 likes this.
  9. Dec 11, 2019 at 1:25 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    I got one of them
    I like it but I wanna get an upgraded LED head
  10. Dec 11, 2019 at 1:43 PM
    clc clc
    PA
    What is this some kind of LED?
    Im really digin it so far. Ive also wanted the surefire shotgun forend for my m590 for a while.
  11. Dec 11, 2019 at 1:45 PM
    JimBeam
    JB
    2015 Tundra
    It's a blue navigation light
  12. Dec 11, 2019 at 1:46 PM
    JimBeam
    JB
    2015 Tundra
    Make sure you fiddle with the power switch on the back of the light and the buttons to ensure the tape switch isn't working before sending it off
  13. Dec 11, 2019 at 2:28 PM
    clc clc
    PA
    Def gonna fiddle with it more. I actually broke the 6p by dropping it so i need to fiddle with that more as well.
  14. Dec 11, 2019 at 3:16 PM
    Wixo
    Hank
    Tint, LED interior
    Howdy there guys! I have 3 questions for you today.
    1. If I have a regular AR15 upper, and I have a glock style lower, will they be compatible? (the upper is chambered in 9mm, but is a regular upper in every other sense)
    2. Lets say they arent compatible, can I just buy the matching upper and put my barrel on there and call it a day?
    3. Can I simply add a 300blk barrel to that original upper and it will fire 300blk now?
  15. Dec 11, 2019 at 4:08 PM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    1. I'm assuming you mean an AR lower that takes Glock style magazines? If so, then generally speaking your AR-9 upper should mate up fine with any AR-9 lower. There are also mag well adapters to convert an AR-15 lower to an AR-9.
    3. Would need to change at least barrel and BCG. You'd also need to make sure your stripped upper has a full ejection port. They are shortened on some AR-9s.
    Chew likes this.
  16. Dec 11, 2019 at 4:58 PM
    clc clc
    PA
    You should speak to the manufacture of said upper and lower and ask them.
    Wixo[QUOTED] and Chew like this.
  17. Dec 11, 2019 at 7:47 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    1. You don't have an AR-15 upper or lower, you most likely have AR-9 which isn't mil spec
    2. Not sure what you have, and respectfully, not sure if you know either
    3. No, different ejection port, BCG, etc. Uppers (and AR parts in general) are so cheap right now, there's little point in replacing a barrel, unless you're in to high end stuff
    Wixo[QUOTED] likes this.
  18. Dec 12, 2019 at 6:32 AM
    Wixo
    Hank
    Tint, LED interior
    From what I understand they're regular AR15 parts, but with the right 9mm parts in order to run 9mm. On the lower I had to use a torkmag glock adapter.
  19. Dec 12, 2019 at 6:48 AM
    Wixo
    Hank
    Tint, LED interior
    This is the upper I have from Delta Team Tactical
    "6228-3 Aero Precision 9mm AR-15 Ultimate Pistol Kit 7.5" Nitride Barrel 7" M-Lok Handguard Includes Nitride **BCG** (Everything Except Lower)"
    I cant link to it because it was purchased a long time ago and no longer exists.
    and this is the lower I want to pair it with:
    https://palmettostatearmory.com/psa...brace-lower-uses-glockr-style-5165449975.html
  20. Dec 12, 2019 at 12:50 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    You will have to find someone who's tried to mix brands, call one or both manufacturers, or try it. Again the 9mm is not mil spec, just like the AR10. So unless you're buying the same brand, or whole, you're on your own.
    No, I don't think you can use a 300 blackout rifle barrel in your AR9 pistol upper.
    If I were you, I'd start buy buying a whole rifle, or at least sticking with AR15 platform and sourcing components from same manufacturer, like PSA.
