AR15xAR10’s “If You Squint, She’s Mint” Build thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AR15xAR10, May 22, 2025.
  1. May 31, 2025 at 4:46 AM
    #81
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Lot of 5G there. An eye sore for the great old building and cool truck.
    AR15xAR10[QUOTED][OP] likes this.
  2. May 31, 2025 at 6:21 AM
    #82
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I cant believe they havent torn that building down. Even my old high school in Maryland is long gone :(
  3. Jun 1, 2025 at 7:45 PM
    #83
    AR15xAR10
    Threw in some cheap Amazon LED fog light bulbs just to gain some brightness
    They’re now as bright or brighter than the headlights:
  4. Jun 2, 2025 at 4:31 AM
    #84
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Man you aren’t wasting any time! Lookin’ good :thumbsup:
  5. Jun 2, 2025 at 4:33 AM
    #85
    AR15xAR10
    Thanks dude. There is still so much to do!
    had to put a roof on my brother’s house this weekend or there would have been a lot more done.
    Road_Warrior[QUOTED] likes this.
  6. Jun 2, 2025 at 4:40 AM
    #86
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Oh yeah that sounds like a time consuming project!
  7. Jun 2, 2025 at 6:40 AM
    #87
    ModernSR
    ModernSR Active Member
    2016 Tacoma SR
    Morning all. Do you have any recommendations for reputable body shops/mechanics? I can do a lot of work myself but not so great at diagnostics or paint/dent repair. Don't mind a hike if the shop is good.
  8. Jun 2, 2025 at 6:44 AM
    #88
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I have arrived
    AR15xAR10[OP] likes this.
  9. Jun 2, 2025 at 6:49 AM
    #89
    AR15xAR10
    I need to swap the entire assembled rear end from the blue truck to the red truck so i dont have to disturb anything but the leaf spring bolts and brake lines. I have new stainless braided brake lines for the red truck front and rear.
    The red truck gets the hubs, dust shields, calipers, coilovers, and UCAs swapped over from the blue truck. I also have new sway bar bushings and the sway bar relocate kit to go on.
    I may also need to play around with axle shims and the carrier bearing spacer to see if I can ward off the take off shudder I used to have with the blue truck. So that may require me to get another set of ubolts at some point. Basically i’m going to build the red truck exactly like the blue truck was and then fix the little things.
    I also need to get a hold of @SMKYTXN to get new hardware for my gas tank skid to swap it from the blue truck to the red truck.
    I need to pull my Mobtown front skid, put it in the press and see if i can bend it back into useable shape, the trans skid is still mint.
    I need to buy new front bump stops, going to try to see if they can come off the blue truck and be reused first.
    I have to swap on my redline tuning hood struts.
    I have to swap in my pioneer head unit with all new wiring. Switch the back up camera from the blue truck to a front camera on the red truck.
    I may also swap the hitch from the blue truck to the red truck because its less rusty. Depends on whether i can clean up the one on the red truck or not….
  10. Jun 2, 2025 at 6:49 AM
    #90
    AR15xAR10
    <3
    YotaOverAll[QUOTED] likes this.
  11. Jun 2, 2025 at 6:49 AM
    #91
    AR15xAR10
    What are you looking to have done?
    and did you mean to ask this to me specifically? Or the MD thread? o_O
  12. Jun 2, 2025 at 7:48 AM
    #92
    ModernSR
    2016 Tacoma SR
    You and everyone ha.
    Looking for paint touchup/paintless dent repair/ detailing.
    I've just acquired some pretty nasty paint chips on my hood down to bare metal and freak dent in my passenger door that's making the window rub on the door panel. Trying to spec out if it's cheaper to get the paint repaired or just find a used hood.
  13. Jun 2, 2025 at 7:50 AM
    #93
    AR15xAR10
    search “dent wizard paintless dent repair” best money i ever spent on my last truck. Now i’ll need him again. He is from somewhere in middle PA
    ModernSR[QUOTED] and Steves104x4 like this.
  14. Jun 2, 2025 at 8:22 AM
    #94
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @3pooches does PDR too
  15. Jun 2, 2025 at 10:02 AM
    #95
    AR15xAR10
    WHAT. I may need some services on this red truck :goingcrazy:
  16. Jun 2, 2025 at 10:25 AM
    #96
    fatfurious2
    David
    Ashburn, VA
    He also is closer to you than "somewhere in PA"
  17. Jun 2, 2025 at 10:48 AM
    #97
    AR15xAR10
    The guy in PA came to me lol
    fatfurious2[QUOTED] likes this.
  18. Jun 2, 2025 at 12:14 PM
    #98
    ModernSR
    2016 Tacoma SR
    Oh they come out to you? If I can't find something local-ish I'll reach out. Figured I'd ask since you were building a new truck and your last one looked so clean. I know that doesn't happen by accident so you must know someone or be a pro yourself ha.
  19. Jun 2, 2025 at 1:56 PM
    #99
    AR15xAR10
    At one point in time, the passenger side bed side of my blue truck got totaled by my log splitter backing it up a driveway. PDR guy was an absolute wizard and handled it like a champ.
  20. Jun 2, 2025 at 6:23 PM
    #100
    Kilo Charlie
    Kilo Charlie One flat foot on the Devil's wing
    Iowa
    2017 Inferno Off Road
    Things like that, without any creases can be popped out with a toilet plunger and some soapy water.
    Side note, Dawn dish soap removes wax, so make sure to rewax the area.
