AR15xAR10's 2015 Suzuki DRZ400S "Dirt Scooter" Build
Discussion in 'Other Builds' started by AR15xAR10, Jun 18, 2015.
  1. Aug 23, 2016 at 11:18 PM
    #1581
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Well what's the difference from what he have now lol
  2. Aug 23, 2016 at 11:21 PM
    #1582
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    The s is more "dual sport", just giving him shit cause his parents didn't want him to get the SM like he wanted
  3. Aug 23, 2016 at 11:26 PM
    #1583
    gray223
    SE Missouri
    2014 Tundra Limited
    So his parents just didn't want him to have street tires??? Lol isn't that the only difference?
  4. Aug 24, 2016 at 3:56 AM
    #1584
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Two month wait at the dealer*
    Bought what was in stock*
    Tractorman likes this.
  5. Aug 24, 2016 at 3:57 AM
    #1585
    AR15xAR10
    I really only wanted the SM over the S, because its cheaper to put a set of 21/18s on an SM than it is to put 17s on my bike.
  6. Aug 24, 2016 at 4:01 AM
    #1586
    AR15xAR10
    17s instead of 21/18" wheels, inverted forks, wider swing arm with block adjusters like a sport bike, fat bars from the factory. Better color schemes. Better resale value over time. More demand.
    That being said, if i end up with a good set of 17s for my bike in addition to the dirt wheels that i already have, it will make the bike worth more
    Tractorman and gray223[QUOTED] like this.
  7. Aug 28, 2016 at 1:09 AM
    #1587
    AR15xAR10
    For some strange reason...this thing has lost some gearing.
    It used to run 96-97 a few times all the way to 101. Now it struggles to get past 92-93. I have no idea what happened. I didn't change anything.
    Maybe i got some air filter oil in the carb? Certainly not fucking taking it off to check. What a pain in the ass.
  8. Aug 28, 2016 at 1:09 AM
    #1588
    AR15xAR10
  9. Aug 28, 2016 at 6:13 AM
    #1589
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Uh not sure. Do a compression check? Check valves.
  10. Aug 28, 2016 at 6:36 AM
    #1590
    AR15xAR10
    Valves were good at 7500. We're at 9300 now. Next valve check is like 14000-15000 i think
  11. Aug 28, 2016 at 6:39 AM
    #1591
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Air filter dirty?
    Try running it without it. On the street and with a clean air box of course.
  12. Aug 28, 2016 at 9:33 AM
    #1592
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Or the carb is dirty. Only things I can think that would effect it
  13. Aug 28, 2016 at 11:06 AM
    #1593
    AR15xAR10
    Its a k&n...i'm considering going back to a foam filter. This k&n always seems to be filthy
  14. Aug 28, 2016 at 11:07 AM
    #1594
    AR15xAR10
    Been running seafoam through it every other month
  15. Aug 28, 2016 at 11:08 AM
    #1595
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I hate seafoam. Just saying.
  16. Aug 28, 2016 at 11:10 AM
    #1596
    AR15xAR10
    It helps fight the ethanol. And or keep gas stable.
  17. Aug 28, 2016 at 11:20 AM
    #1597
    Sacrifice
    KS
    DCSB OR 4X4 LT
    If you say so. I'm not having issues :p
  18. Aug 28, 2016 at 11:50 AM
    #1598
    AR15xAR10
    I ride in way more dirt/mud than you do.
  19. Aug 28, 2016 at 7:23 PM
    #1599
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Well start with the basics. Plug, carb, air filter. Then you'll have to check valves and compression
    AR15xAR10[QUOTED][OP] likes this.
  20. Aug 28, 2016 at 7:47 PM
    #1600
    AR15xAR10
    Runs fine other than a little throttle hesitation every once in a blue moon.
    Just did a plug when i checked the valves. Valves weren't even close to needing adjusting.
    Just cleaned the air filter about a month ago and haven't ridden 500 miles since
    Maybe i have a vacuum leak
