AR15xAR10's 2015 Suzuki DRZ400S "Dirt Scooter" Build
Discussion in 'Other Builds' started by AR15xAR10, Jun 18, 2015.
  1. Oct 29, 2015 at 3:03 PM
    #381
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    If you total it, youd get zero doll hairs
    Just do some shopping then
    AR15xAR10[QUOTED][OP] likes this.
  2. Oct 29, 2015 at 4:30 PM
    #382
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Mason go the highest deductible for comp/collision and tell us the price
  3. Oct 29, 2015 at 4:59 PM
    #383
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    I keep liability and comprehensive on my bikes which covers pretty much anything except collision. Mainly theft is what I want coverage for.
    AR15xAR10[OP] likes this.
  4. Oct 29, 2015 at 9:16 PM
    #384
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I get that would lower my monthly payment but i'm not about having deductibles that i could never reach
    Tractorman likes this.
  5. Oct 29, 2015 at 9:20 PM
    #385
    pittim
    Pennsyltucky
    Boujee Prius
    So take the money you spend on the increase in premium, put it in the bank, wait till it reaches the deductible, then everything after that is free money basically
  6. Oct 29, 2015 at 9:23 PM
    #386
    AR15xAR10
    -_-
  7. Oct 29, 2015 at 9:27 PM
    #387
    pittim
    Pennsyltucky
    Boujee Prius
    Humor us. What's the difference with full coverage now vs a higher deductible.
  8. Oct 29, 2015 at 9:38 PM
    #388
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Nice machine. Use to ride an E model with the 39mm carb, that thing helped big time on throttle delivery. You may have done this already, but if you haven't pull out the swing arm pivot bolt and anti seize it while it's still new. Suzuki didn't lube it from the factory and it will seize, making ones life a true pain. Keep an eye out for the water pump bearings and seals, this bike (and Kawasaki 400) share the same pump and prematurely wear out and leak coolant. I rebuilt mine with an all balls kit.
  9. Oct 29, 2015 at 10:32 PM
    #389
    AR15xAR10
    Thank you.
    You're the third person to mention the swingarm bolt. Any recommendations? Should i just walk it out one side, (grease or antiseize?) at least 90% of it and put it back in?
    I have noticed dust tracking around the water pump housing but i'm not exactly worried about it yet. 6200 miles on the machine currently.
  10. Oct 29, 2015 at 11:38 PM
    #390
    BenJammn5
    BenJammn5 RN
    San Jose
    There's a lot of responses, figured somebody perhaps touched on the bolt subject.
    It's been a while, but I recently completed the job again on my CR250R. From what I remember you'll need to unbolt the lower linkage to remove the pivot bolt. Put the bike on a stand, back off the pivot nut on the right side (protect the threads!) place a screw driver through the pivot bolt (it's hollow) and tap with a hammer. Hopefully it will slide out, and it only goes out to the left, physically impossible to slide right. I prefer anti seize, or bel Ray grease. Remove the entire bolt and grease away. Slide back in, ride.
    To put things into perspective, mine was 2002 model. To remove I had to lay the bike on its left side, spray liquid wrench for 3 days, heat the case with the wife's hair blow dryer, slide the screw driver through the bolt and slam on it with a 4lb hammer x 3 days. It was a bit of a ritual after work until the bolt surrendered. There are horror stories of guys taking the bike apart and putting into a machine press, cases splitting etc in the extreme situations. None of this will happen to you :)
  11. Oct 29, 2015 at 11:41 PM
    #391
    AR15xAR10
    Fuck. Well, now i have more of a winter project.
  12. Oct 29, 2015 at 11:44 PM
    #392
    BenJammn5
    BenJammn5 RN
    San Jose
    If the bolt slides out the first time, the job is actually pretty easy
  13. Oct 29, 2015 at 11:50 PM
    #393
    AR15xAR10
    As for now, the winter list is as follows:
    Anti seize swing arm bolt
    Install four new turn signals
    New front tire
    Galfer stainless braided brake lines
    EBC sintered pads front and rear
    More random decals
    Find more weight savings
    Tractorman and BenJammn5[QUOTED] like this.
  14. Oct 30, 2015 at 8:56 PM
    #394
    AR15xAR10
    Update on the DRZ this evening:
    JD jet kit installed
    3x3 air box mod
    K&N air filter installed
    MRD pro comp full exhaust installed
    Bar end mirrors half-ass-ed-ly installed
    Tractorman, teamhypoxia and BenJammn5 like this.
  15. Oct 31, 2015 at 8:19 AM
    #395
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Now go find that Rev limiter you didn't know the drz had.
  16. Oct 31, 2015 at 4:59 PM
    #396
    AR15xAR10
    Haven't opened it up all the way yet. Did a few good pulls and I haven't felt it nose over like it used to. So you are definitely right about that! But i haven't been faster than about 70.
    I want to get about 100 miles on it before i do a full pull with it.
    So far, the exhaust is awesome. The drone might get annoying but it sounds awesome. I've already found rev ranges that i can comfortably cruise at...so its not that bad.
    Its like any exhaust, when you're on the throttle its loud. And when you're riding it or standing next to it, its loud. But when i'm putting through the neighborhood, no one really bats an eye if i'm not trying to get them to ;)
    Tractorman and MQQSE like this.
  17. Nov 1, 2015 at 8:45 AM
    #397
    AR15xAR10
  18. Nov 2, 2015 at 3:36 PM
    #398
    AR15xAR10
    swing arm decals are in, and on
  19. Nov 9, 2015 at 2:25 PM
    #399
    AR15xAR10
  20. Nov 9, 2015 at 2:29 PM
    #400
    AR15xAR10
