AR15xAR10's 2015 Suzuki DRZ400S "Dirt Scooter" Build
Discussion in 'Other Builds' started by AR15xAR10, Jun 18, 2015.
  1. Mar 22, 2016 at 9:04 AM
    #1121
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    What's gonna happen soon in this scooter build?
  2. Mar 22, 2016 at 1:55 PM
    #1122
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    You a member on thumper talk then?
  3. Mar 22, 2016 at 2:15 PM
    #1123
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    New tires, Galfer Gold Stainless braided brake lines, EBC sintered dual sport pads, valve check, new spark plug.
    Then, forward lighting upgradezzz
    Tractorman likes this.
  4. Mar 22, 2016 at 2:16 PM
    #1124
    AR15xAR10
    Nope.
    You get stickers from them every time you order from their store.
  5. Mar 23, 2016 at 12:45 PM
    #1125
    Stockmonester
    Stockmonester Well-Known Member
    Nick
    Rome, Ny
    2019 v6 sr 4x4
    in channel vent visors
    what tires you going with?
  6. Mar 23, 2016 at 12:48 PM
    #1126
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Some one say stickers? I heard de-stickering sheds weight and make you go faster. Add too many stickers and performance takes a dive.
    :D
  7. Mar 23, 2016 at 12:54 PM
    #1127
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    :rofl:
    Adventurer_Alex likes this.
  8. Mar 23, 2016 at 7:51 PM
    #1128
    AR15xAR10
    Stickers make me faster.
    Tractorman, ChadsPride and gray223 like this.
  9. Mar 23, 2016 at 7:51 PM
    #1129
    AR15xAR10
    Kenda K270 50/50
    3.25/21
    5.10/18
  10. Mar 23, 2016 at 8:58 PM
    #1130
    dakotasyota
    Dakota
    Ellensburg, WA
    Didn't realize there was a store, thought it was just a forum.
  11. Mar 24, 2016 at 5:23 PM
    #1131
    AR15xAR10
  12. Apr 4, 2016 at 10:00 PM
    #1132
    AR15xAR10
    Pulled the MCCT and checked for the cause of the leak. Didn't see any issues. Reinstalled it opting not to put a factory gasket on top of the large o-ring that rides in the MCCT. Should be fine. If it leaks, it leaks. Fook et.
    New turn signal on the right rear as well. Been riding without one for almost two weeks.
    Still do not have the tires broken in.
    It should go down for brake lines and valve check soon.
    Tractorman and Adventurer_Alex like this.
  13. Apr 4, 2016 at 10:10 PM
    #1133
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    How big of a job is it to install the MCCT?
  14. Apr 4, 2016 at 10:35 PM
    #1134
    AR15xAR10
    Not bad. Annoying. But not bad.
    Pull the seat, pull the tank. Unbolt the oil air separator box and shove it out of the way. Unbolt the ACCT. (I did it while my oil was draining during an oil change). Back the bolt and jam nut all the way back on the MCCT and instal it on the motor making sure to tighten it down evenly (5mm allen wrench). Then tighten the large bolt down with your fingers until you can't turn it any farther (BY HAND). Put the rest of the bike back together. Start the bike. Let it warm up just off of choke. Back the large bolt out by hand until you hear the cam chain and guide rattle. Turn the large bolt back in until the rattle stops, then turn 1/4-1/2 turn past that. Push the small o-ring down the bolt until it seals the hole. Lock the Jam nut down with a 17mm.
    Hardest part about the whole job is loosening the ACCT and tightening the MCCT (because of the bolt closest to the carb).
  15. Apr 5, 2016 at 5:26 AM
    #1135
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Put the engine TDC so you don't have to worry about cams skipping timing
  16. Apr 5, 2016 at 6:33 AM
    #1136
    AR15xAR10
    Its fine.
  17. Apr 8, 2016 at 8:53 AM
    #1137
    AR15xAR10
    OP updated
    Tractorman and ChadsPride like this.
  18. Apr 17, 2016 at 7:35 PM
    #1138
    AR15xAR10
  19. Apr 17, 2016 at 7:36 PM
    #1139
    AR15xAR10
  20. Apr 17, 2016 at 7:36 PM
    #1140
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Before, or after Green Ridge?
