AR15xAR10's 2015 Suzuki DRZ400S "Dirt Scooter" Build
Discussion in 'Other Builds' started by AR15xAR10, Jun 18, 2015.
  1. May 8, 2016 at 6:45 PM
    #1201
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    see! now thats what i expected
    Tractorman likes this.
  2. May 8, 2016 at 9:25 PM
    #1202
    AR15xAR10
  3. May 9, 2016 at 4:25 PM
    #1203
    AR15xAR10
    TST Industries front flushmount clear lens LED signals with harness connectors are on. LED flasher relay is in and works this time. So stoked to have four working turn signals that all flash at the proper rate and are bright as fuck.
    The harness connectors are worth every penny.
  4. May 21, 2016 at 4:53 PM
    #1204
    AR15xAR10
    Pulled the original spark plug and read it. Seems to be a little rich, might be why the bike falls on its face at the top of 4th. Pulled the 160 main and put in the 155, haven't ridden it yet but it feels essentially the same. I'll have to ride it and read the spark plug again to see if it helped.
  5. May 21, 2016 at 7:00 PM
    #1205
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    You can't "read" a old spark plug. The only way to read it anymore is put in a fresh one, go for a rip and immediately look at it.
  6. May 21, 2016 at 7:17 PM
    #1206
    AR15xAR10
    You don't know about cleaning a spark plug then. I cleaned it about 200 miles ago. Just needed to check it again.
    7500 calls for a new spark plug with the valve check anyway, my valves were perfect and i waited to do the spark plug
  7. May 21, 2016 at 7:33 PM
    #1207
    Sacrifice
    KS
    DCSB OR 4X4 LT
    You can't "clean" a sparkplug to new. And still you can't check it after 200 miles. It literally has to be put it, gone for a rip, and then checked with the fuels put now.
  8. May 21, 2016 at 7:39 PM
    #1208
    AR15xAR10
    I checked it before the valve check. It was still rich. Played with the mixture screw. That barely helped. Cleaned the spark plug. Did a full pull up the interstate and the coasted most of the way back home only using second gear to lug up a few hills. Checked the spark plug. Still rich. Played with the mixture screw some more and just never checked it again. Pulled it today and noticed my half a turn on the mixture screw had only helped a tiny bit, barely at all. That and it falling on its face before top speed, lead me to believe it is pushing too much fuel at WOT and at the top of the gears it could lead to a burnt piston if i would really ring the bike out for a long distance.
    So i swapped in the 155 and left the mixture screw at 2 turns. If its a little bit lean after another pull, i'll put that half turn back in it so that its at 2.5 turns. But now i'm really wishing i had the FCR and someone to tune this thing on a dyno
  9. May 21, 2016 at 9:10 PM
    #1209
    Sacrifice
    KS
    DCSB OR 4X4 LT
    You're still doing it wrong and not understanding. 1st)You can't change the jetting and look at a used spark plug to see if it made a difference. It has to be a BRAND NEW ONE OUT OF THE BOX after the change in jetting and then ran to see how the plug looks.
    2nd). If it's running rich it can't burn a piston. That is by default a result of a lean mixture.
    3rd)the mixture screw only affects idle
  10. May 21, 2016 at 9:18 PM
    #1210
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Reading the plugs on these 4 strokes is alot harder to me than 2 strokes. Theres definitely an art to fine tuning by doing it. Ive had to rejet my bike a few times because i keep modding it and i can get it pretty close just by riding it and seeing how it reacts. I start on the rich side and lean it out from there if needed.
  11. May 21, 2016 at 9:23 PM
    #1211
    AR15xAR10
    Thats basically what i have done. I can't really add any more air to it, so i'm just going to take fuel from it.
  12. May 21, 2016 at 9:24 PM
    #1212
    AR15xAR10
    That half turn in either direction has done absolutely nothing to my throttle. Still requires full choke from stone cold no matter the ambient air temp
  13. May 21, 2016 at 9:32 PM
    #1213
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Because it isn't going to change anything in throttle. It is only an idle adjustment. And even mine needs choke for 30 seconds first start with an fcr. It's the nature of a carb
  14. May 21, 2016 at 9:34 PM
    #1214
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    I think every drz ever always needs the choke for a little bit on a cold start. This discussion just came up on the drz fb page. Great resource there if youre not already on it.
  15. May 21, 2016 at 9:41 PM
    #1215
    AR15xAR10
    Don't have facebook.
  16. May 21, 2016 at 9:42 PM
    #1216
    AR15xAR10
    Some just need a little bit of throttle...its weird
  17. May 21, 2016 at 9:44 PM
    #1217
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Mine starts fine after its ran a minute. But fresh starts 90% of the time need the choke unless I really crank on it to get started. Don't worry about it. Unless you can get a wide band o2 or get it on a dyno to do a couple runs back to back don't worry about it .
  18. May 21, 2016 at 9:48 PM
    #1218
    AR15xAR10
    No idea where i could get it tuned...but i'd fork the money over to have the fcr tuned before this stock carb
  19. May 21, 2016 at 9:49 PM
    #1219
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Fcr or bust :p
    Just run what you have in there and enjoy it till you change carbs
  20. May 21, 2016 at 9:56 PM
    #1220
    AR15xAR10
    So hard saving for wheels and tires. I could afford the carb but then i'd have no wheels lol
