ARB 5mm Push-to-fit fittings sources
Discussion in 'Off-Roading & Trails' started by SMKYTXN, Feb 26, 2014.
  1. Feb 26, 2014 at 7:55 AM
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I'm in the process of completing my diff install and found that finding fittings for the 5mm air line is a pain. I've come across a source for 5mm push-to-fit fittings and figured I'd share.
    Fastenal
    If you want to run an airline right out of the ARB compressor without the solenoid you'll need these.
    5mm Tube x 1/8" Male BSPT 90[DEG] Nickel Plated Brass Push-to-Connect Swivel Elbow
    If you want to make a 90 degree turn and don't have the space required for the large bend in the plastic air line you'll want one of these.
    5mm x 5mm Tube 90[DEG] Nickel Plated Brass Push-to-Connect Union Elbow
    And if you need to make a quick repair to a cut air line you'll definitely want some of these.
    5mm Push-to-Connect union
    If you come across other fittings please post them.
  2. Feb 26, 2014 at 8:27 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    4x4 Connection
    This site has a good selection of fittings as well as replacement parts.
    IPOR-Firewall Connection
  3. Feb 26, 2014 at 8:37 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    Thanks, these should come in handy when swapping from the normal switch to a manual air switch :D
  4. Feb 26, 2014 at 8:40 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    No problem, glad to help.
    On the subject of switching to a full pneumatic system you'll want to check out powertanks website.
    Powertank
    I have a set of these ordered for my setup. I'll post pictures and maybe a video when they show up.
    Air Toggle Vale Kit - Fr + Rr ARBs
  5. Feb 26, 2014 at 9:15 AM
    paranoid56
    San Diego
    14 double cab taco
    yep, already have those :D Steve at powertank is a great guy. Have one of the original power tanks too :D
  6. Mar 5, 2014 at 10:16 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
