ARB Air Locker Solenoid Leaking Gear Oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kmorgan3, Oct 2, 2021.
  1. May 12, 2023 at 5:06 AM
    #61
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    I was told by ARB Support that I should always release the pressure from the system after use. This is especially important in areas with freezing temps as moisture gets trapped in the manifold.
  2. Jun 5, 2024 at 9:14 PM
    #62
    MotorMaus
    MotorMaus New Member
    Sorry for reviving a dead thread, but, if anyone is looking for a potential answer for this I might have a solution.
    Check the bulkhead fitting where the copper airline seals.
    I was having the same issue with my 9.5" rear locker RD152. Turns out either I forgot to tighten, or it came loose, the inner phillips head fitting in the bulkhead fitting that the copper line gets sealed with 2 orings and a spacer.
    I had only noticed it because when I was cleaning the line out again, I decided to swap out to the banjo bolt angled fitting like I have on the front thinking maybe that was the issue, but then it wouldn't thread all the way in.
    Put a Phillips screwdriver in there, and sure enough it was loose.
    I know the RD129 is different the way it seals, but the only thing keeping gear oil out of that line is the rubber oring on that one as well, worth a shot to check it out
    I haven't driven it yet to confirm but I'm pretty confident that may have been the issue. I'll report back if that fixes it after about a week or two of driving.
    elmontemike likes this.
