ARB Air Lockers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 11tacomatxpro, Mar 5, 2011.
  1. Mar 5, 2011 at 5:23 PM
    11tacomatxpro
    11tacomatxpro [OP] New Member
    Tehachapi, CA
    Hey im looking to buy ARB air lockers when i get my new tacoma...any help on what all im gonna need like sizes and everything would be greatly appreciated
    Thanks
  2. Mar 5, 2011 at 9:05 PM
    11tacomatxpro
    Tehachapi, CA
    alright i did my research and found which one i need its 849.99 at 4 wheel parts without the compressor
  3. Mar 5, 2011 at 9:14 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    I heard the ARB Compressors are junk from a friend that rock crawls a Jeep. Is this true? I haven't heard anything else bad about them.
  4. Mar 5, 2011 at 9:16 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    A Jeep owner calling something else junk?
    Pot, meet kettle.
    I've only heard good things about ARB.
  5. Mar 5, 2011 at 9:24 PM
    AzogSS
    Andy
    Soda City, SC
    Neither I, that is why I was skeptical of his opinion. Are the mini compressors pretty easy to mount up?
  6. Apr 15, 2011 at 11:56 PM
    qbert
    qbert Well-Known Member
    Brady
    Huntington Beach, CA
    2008 4x4 DCLB TRD Sport
    Velocity Off-Road 3" front billet coil spacer lift, rear leveling block, aFe Pro Dry S air filter, Weathertech all-weather rubber floor mats, partially debadged/blacked out Tacoma badges, 5% tint all the way around
    Question: If you're going to add lockers, you want to add them to BOTH the front and rear, correct?
  7. Apr 16, 2011 at 1:21 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    Dreaming of the day when I can throw a locker on my rig!
  8. Apr 16, 2011 at 1:42 AM
    qbert
    Brady
    Well not a necessity. I guess I just mean that ideally, you'd want it on both front and rear for optimal performance, right?
  9. Apr 16, 2011 at 2:34 AM
    qbert
    Brady
    Mostly wheeling up in the mountains on fire roads and trails with frequent snow trips in the winter. Mud and Sand will be secondary, but I'd like to do it all really.
  10. Apr 16, 2011 at 9:47 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    The rear locker will get you everywhere you likely want to go... Had a rear locker on 3 Tacomas so far. If you start getting into serious rock climbing... then you can add a front locker. These things are not cheap, afterall.
  11. Apr 16, 2011 at 9:54 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Never had any problem with my ARB H/O compressor (fill up all my tires from 18 to 35psi) and as far as lockers, they're nice to know you have them, but I think it's good to learn to try and get through obstacles without them, then you really appreciate them and understand when you actually need them!...but it in the end they're totally worth it :thumbsup:
  12. Apr 16, 2011 at 10:31 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    You may want to regear the diffs at the same time you install the lockers. Perfect time to do that.
    You can get a pretty good deal from Carl at www.justdifferentials.com and tell him Gadget sent you.
    They can send you complete diffs with lockers and gears installed so all you have to do is drop them in, or they can set you up with the individual parts if you want.
    I ran dual ARBs in my 96 4Runner for a very long time. Never had any problems with of the ARB stuff including the compressor.
    G
  13. Apr 16, 2011 at 12:28 PM
    qbert
    Brady
    I like the sound of this....
  14. Apr 16, 2011 at 12:33 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    X10.
    Don't trust smack talkin friends about the quality of a product that has been tested time and time again.
  15. Apr 16, 2011 at 12:58 PM
    qbert
    Brady
    Yeah, I was thinking I'd need a re-gear. This seems like the easiest way to go. I'll drop them a line this week and get some prices. Thanks for the tip!
