Arb Air Lockers
Discussion in 'New Members' started by SierraTacoma2014, Oct 20, 2022.
  1. Oct 20, 2022 at 11:56 AM
    SierraTacoma2014
    SierraTacoma2014 [OP] New Member
    Alex
    2014 Toyota Tacoma 4x4
    Arb front & Rear lockers King Shocks & Total Chaos uppers and lowers
    Hey guys. I just got front and rear air lockers installed on my Tacoma 4x4 sport. I have a couple questions though. Firstly, whats the top speed I can go with the locker engaged. Secondly when should I change the gear oil for the first time (due to break in period). Lastly after driving for a while I smell this oily smell from the diff area not sure if its residual grease on the diff or just it breaking it. I know have the correct parts and that everything was professionally installed….
  2. Oct 20, 2022 at 12:04 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    I would not engage lockers at in time other than low speed off road use. Certainly never on road. I have had F/R ARB for 2 years now and have never had a single issue. The break in process is very important for new gears so please see link. As long as you follow it you will have no issues. Gear oil is a very distinct odor that doesnt just go away after you wipe it with a rag so that sounds normal to me it will probably take a little bit for the smell to go away.
    Hope this helps.
    https://eastcoastgearsupply.com/ft-1479-new-gear-break-in-procedure.html
  3. Oct 20, 2022 at 12:48 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    buckhuntin-tacoma likes this.
  4. Oct 20, 2022 at 1:19 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  5. Oct 20, 2022 at 3:43 PM
    SierraTacoma2014
    Alex
    Ok. So my initial drive I handled correctly. First time using was only for 15 and at low speeds. I did drive 300 miles back home (Mammoth lakes from socal) and only stopped every 100 miles. Im worried I didnt handle that 50 mile cool down period correctly. Should I change my gear oil asap?
