ARB Bull Bar Bumper
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kolar, Jun 25, 2011.
  1. Jun 25, 2011 at 10:23 AM
    Kolar
    Kolar [OP] Active Member
    Eric
    South Texas
    03 PreRunner stock
    Yesterday I installed a ARB Bull Bar Bumper on my 03' Tacoma. This dropped the front suspension consediberitly, this suspension is stock for the Pre-runner. I want to get an upgraded front spring and shock set. Can any one help me on this cause I am in the dark on this matter. I just want to provide enough lift in the front end to bring it back to factory hight because this is my daily driver. The bumper is ruffly around 150 pounds. I dont know how much added weight this is because i don't know what the stock bumper brackets and plastic weighted. PLEASE HELP!!!
  2. Sep 5, 2011 at 12:22 PM
    BCH
    BCH Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    I can help a bunch. I went to 4wheelparts, Marietta Ga and they installed the OME 881's, 5 leaf Dakars, and the truck is perfectly level, rides great and is exactly what I wished for
  3. Sep 5, 2011 at 12:23 PM
    BCH
    BCH Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    BTW, I have the ARB Bull Bar, Milemarker 10500 winch, and its truly perfect
  4. Sep 5, 2011 at 12:24 PM
    BCH
    BCH Shiester
    Lafayette Ga
    SR5 4x4 4cyl
    Viper, ARE Camper
    pics you see will be before suspension if you look at my photos
  5. Sep 5, 2011 at 12:28 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    I upgraded to OME for a mild lift (springs and Light Racing UCA's) and to support the ARB. I take mine on trips out of state and drive daily.
  6. Sep 5, 2011 at 3:00 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I've got an ARB, Warn M800 (with synthetic line) and am running OME 882 coils with OME Nitrocharger shocks. Dakar leaf springs and OME Nitrocharger's in the rear. Rides great and gives me about 2 3/4" lift.
  7. Sep 5, 2011 at 3:29 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Did you do before and after height measurements to see exactly how much height you lost by adding the bumper? When I took my stock bumper and the mounting brackets off, they weighed 30 lbs.
    edit: Didn't realize how old this thread was. I'm guessing you sorted this out long ago. :eek:
  8. Sep 6, 2011 at 8:20 AM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Funny how this thread got all kinds of attention 3 months later....I remember the OP solved this a while back with 881's and stock shocks.
