ARB Bumper and winch
Discussion in 'Suspension' started by Country, Mar 5, 2010.
  1. Mar 5, 2010 at 10:20 PM
    Country
    Country [OP] Well-Known Member
    Country
    East Texas
    2010 Dbl.-Everyone says it looks like a tank
    Pro Comp 6in lift w/ Icon Coilovers,AllPro UCA's, AllPro Baja Leaf pack, Bilstein 5150's in the rear. Tires Mickey Thompson MTZ 275/70R18 w/ procomp 7089 wheels. ARB front bumper with mile marker winch, Custom made all quarter inch steel rear bumper. Demello rock crusher slider's. CoverKing neoprene seat cover's, AllPro trail armor All-pro U-bolt flip kit with Timbren bump stops and many many many other mods, way to many to list.
    after about 4 months with my ARB bumper and winch on my 2010 Tacoma I have noticed that the front end has settled alot lower than before i put it on, It doesnt suprise me due to the fact it is a stock suspension, hopefully after I get my 6in lift it will level out, any of u guys notice the front end lower on stock supension with this setup
  2. Mar 5, 2010 at 10:24 PM
    godofspeed
    godofspeed Washington State.
    2010 4x4 TRD OR DC
    Body Armor front bumper Body Armor rear bumper 17x8.5 Method Bead Lock 35x12.50 Camburg LT Fox coilover All Pro 11 pack leaf Fox rear shock with DSC Allpro frame slider Smittybuilt 9500 winch Cobra CB w/firestick antenna. Hi-lift Smittybuilt air compressor
    You are basically adding more weight to the front, so its going to sit a little bit lower. I heard its about 100lbs that is added to the front of the truck with ARB bumper. I know guys that run coilovers had to adjust them up to compensate for the extra weight. Sorry I couldn't be too much help for you. GL
  3. Mar 5, 2010 at 10:44 PM
    Country
    Country
    East Texas
    I appreciate the input, u confirmed what I thought, do u think add my 6in lify will level it out
  4. Mar 5, 2010 at 10:48 PM
    godofspeed
    2010 4x4 TRD OR DC
    It depends on the lift. I think with 6 inch lift, they use diffrent springs. You might want to find out what kind of springs they are using and see if you can get some heavier duty springs. Or if it is a coilover setup, then just adjust the coilover. I have seen like 2 kits that uses coilovers with there 6 inch lift, but I think they were upgrade on the kits.
  5. Mar 5, 2010 at 10:49 PM
    godofspeed
    2010 4x4 TRD OR DC
    Do you know what 6 inch lift kit you are getting yet?
  6. Mar 5, 2010 at 10:52 PM
    Country
    Country
    East Texas
    Ya, its the pro comp 6in, stage 1, no ajustable coilovers, cant afford the stage 2 yet
  7. Mar 5, 2010 at 10:55 PM
    godofspeed
    2010 4x4 TRD OR DC
    I think it will sit a little lower, but not by much. You won't be able to tell unless you try it. Maybe someone with the 6 inch procomp and ARB will be able to chime in. GL
  8. Mar 5, 2010 at 10:58 PM
    Country
    Country
    East Texas
    I am sure with the bumper and winch it is close to 200 pounds
  9. Mar 5, 2010 at 11:31 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    with a stage 1 lift, its going to sit with the same stance more than likely. The stock front suspension just cant handle the weight of the bumper and winch.
  10. Mar 5, 2010 at 11:52 PM
    Country
    Country
    East Texas
    sorry if this is a newb question but I thought the Stage 1 lift will replace the stock bilstein shocks therefore giving the front end more beefier front shocks to hold more weight, cuz the stage 1 says it comes with ES9000 series shocks, correct me if I am wrong I am now in a predicament
  11. Mar 10, 2010 at 7:06 PM
    waller24
    waller24 Well-Known Member
    Alabama
    2007 Tacoma DC TRD 4x4 impulse red
    usa spec iphone adapter pa15, 1.5 coil lift, warn transformer, warn 8000 winch, UWS black short bed tool box, Grey weather tech mats, mounted streamlight stinger xt, rbc 4x4 light Alignment cam .15 .16 cast 2.24 2.5
    how much do you think it dropped. Im added a warn transformer and winch so Im debating on what size coil spacer to use...1.5 or 2. I guess im going to have to let it settle first or id be wiping before i crapped.
    Just curious on what to expect
  12. Mar 10, 2010 at 7:25 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    its a coil spacer that goes on top olf you stock shocks/ coil those shockas are for the rear
