Arb bumper/coils
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KILLINTIME, Apr 10, 2016.
  1. Apr 10, 2016 at 9:54 AM
    KILLINTIME
    KILLINTIME [OP] Like a Villain
    I have looked but haven't found quite what I'm looking for.
    I have a 2006 AC 4wd and just installed 4 new 5100's. Now I'm wanting to purchase an ARB bumper. I have the front 5100 set on 1.75 and like that look, also got my alignment where I wanted it to be without uca. Which coils will I need to get in order to stay around the same lift height? OME 885? when I eventually do get a winch it will be one of the lighter ones with synthetic line.
    Thanks for any insight on this.
  2. Apr 10, 2016 at 9:56 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    886's will probably work the best
  3. Apr 10, 2016 at 10:15 AM
    KILLINTIME
    I have heard to were the 886 were still Too stiff with somebody running A Winch and an extra battery and they went to 885. But Everybody is different in their terms of "stiff". I'm concerned with lift height bc I want to keep the 265/75's and keep the height its at now. Would 886 not bring it up to where I would need Ucas
    digitaLbraVo likes this.
  4. Apr 10, 2016 at 10:21 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    With adding all that extra weight I am not sure how much sag will happen. So I don't want to quote the wrong spring. I will bring in our OME expert for you @OZ-T any chance you can help him out???
  5. Apr 10, 2016 at 10:22 AM
    DrFunker
    DrFunker Well-Known Member
    How heavy is the bumper?
  6. Apr 10, 2016 at 10:28 AM
    KILLINTIME
    I've heard all kinds of different numbers but I can pick one up by hand and not struggle. I believe they are 110. The winch I will be getting should be about 45 lbs
  7. Apr 10, 2016 at 10:28 AM
    KILLINTIME
    But a winch will come later.
  8. Apr 10, 2016 at 10:29 AM
    DrFunker
    Sliders or other armor?
  9. Apr 10, 2016 at 10:57 AM
    KILLINTIME
    Nothing right now. Maybe one day.
  10. Apr 10, 2016 at 11:09 AM
    DrFunker
    I would go with what Rick said above. Am interested to see what Oz has to say.
  11. Apr 10, 2016 at 11:37 AM
    Simple Man
    Simple Man Well-Known Member
    Puget Sound
    2022 Tacoma TRD Off-Road Access Cab
    A winch with synthetic line isn't going to make any real difference in your springs vs steel cable weight. Don't rely on that as a reason for being able to get by with 885's.
  12. Apr 10, 2016 at 12:14 PM
    KILLINTIME
    A winch with a steel cable will be around 80 lbs. seems a bit heavy to me vs. 45 lbs but I'll take your word for it.
    I want to keep factory uca, I thought 886 gave too much lift for that.
  13. Apr 10, 2016 at 5:23 PM
    KILLINTIME
    Looking to get around 1.75-2" of lift after coil has settled if that's any help. I know somebody knows or has this setup
  14. Apr 10, 2016 at 6:27 PM
    Simple Man
    Puget Sound
    My point is 885's are not designed to hold up the extra weight of a bumper and winch, regardless of steel cable or synthetic line. It MIGHT sit where you want on that set up with 885's when your truck is parked, but that is static weight. Once you start driving it, cornering and braking is where the weight becomes a dynamic force on the springs and is when the 886's will be what you wish you had. If you get a steel bumper and synthetic line winch for a combined weight of 125lbs (and that is light for both) that is still 125lbs more than what 885's are designed for. Don't forget you will have other weight associated with it as well with either dual batteries or a bigger single battery for the winch. It all ads up.
    I wish you luck with your decision.
    Unchained 5150 likes this.
  15. Apr 10, 2016 at 6:38 PM
    KILLINTIME
    I get What your saying now. But I'm also concerned about the amout of lift too. I'm trying to stay 2" or less. Is that something the 886 will settle to?
  16. Apr 10, 2016 at 7:39 PM
    KILLINTIME
    what do y'all think about the eibach 620lb Springs for the arb? Not much less weight than the 886. Since I already have 5100's on the truck maybe the eibachs will be a better match??
  17. Apr 10, 2016 at 7:43 PM
    Ae7mj
    Ae7mj Member
    Alex
    Washington - the dry side
    2013 DCSB TRD OR BRM
    If the 886's gave too much height, couldn't the Billy's be dropped to the .86? That way you'd get the additional capacity and retain the height you want. Stronger spring and adjustable seat.
    FWIW, I have no experience with any of this, just thinking about the previous posts.
  18. Apr 10, 2016 at 7:52 PM
    Jakers83
    Jakers83 Well-Known Member
    Jake
    Denver
    2.7 base.
    OME lift. Tires and wanting more
    I have 886 coils and it rides like a truck lol.
  19. Apr 10, 2016 at 7:54 PM
    Jakers83
    Jake
    Denver
    2.7 base.
    But the 887 sounds like they might be the best for you if you want to keep 2" or a little less and a soft ride
