ARB Bumper, need advice for installation.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mvega1969, Aug 16, 2013.
  1. Aug 16, 2013 at 9:58 AM
    mvega1969
    mvega1969 [OP] Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    Ok,
    This is going to be my truck's weekend, I'm planning to install by my self the ARB bumper I just got.
    I'm asking for advise for anyone of you guys who already performed this installation or help to, tips of what not to do, but my MAIN concerns are:
    1.- Avoid inclined installation of bumper, I like to have the recommended gap between the fender and the bumper, but I will like to see it straight.
    2.- Electrical installation of ARB fog lights to my truck OEM installed fog lights. (This shouldn't be a problem - plug-and-play-, right?
    Please help with your positive tips, once I finish I'll post some pictures.
    Regards.
    NOTE: any other advice will be welcomed.
  2. Aug 16, 2013 at 10:09 AM
    Manwithoutaplan
    ID
    Putting one of these bumper on i would recommend having a least 2 buddies so you can adjust it easier.
  3. Aug 16, 2013 at 10:19 AM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    It just takes some time but not that hard to install . I installed mine a few months back by my self in one evening . Just read the instructions and follow them step by step. If you lived close by I would help you do it . The wire colors that you need to tap into is the green for the turn signal and the red is for the parking light and just look for a good ground . Good luck !
  4. Aug 16, 2013 at 10:20 AM
    Manwithoutaplan
    ID
  5. Aug 16, 2013 at 11:00 AM
    mvega1969
    Laredo
    Thanks Guys, I have my Son for the hard part of lifting and putting bumper in place, but advice and tips always make in this case installation easier and also let you avoid
    "undo" things.
  6. Aug 16, 2013 at 11:21 AM
    Manwithoutaplan
    ID
    Just Fyi There are a ton of clips and bolt holding the front bumper on.
  7. Aug 16, 2013 at 11:27 AM
    mvega1969
    Laredo
    I can imagine it is going to be laborious to remove them all, but once you start there is now way going back. I have all weekend.
  8. Aug 16, 2013 at 12:11 PM
    Sigi
    Sigi
    Sfv ca
    My heart is always yours <3 <3 grrrrr! ;)
  9. Aug 16, 2013 at 1:01 PM
    Manwithoutaplan
    ID
    It should take you like 2-3 hours with install mostly trying to find all the clips.
  10. Aug 16, 2013 at 1:10 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    If all possible, at least have someone help you lift it in place. That's the hardest part and only takes about 5 minutes.
  11. Aug 16, 2013 at 1:22 PM
    mvega1969
    Laredo
    Understood, I've seen pictures where several people removed the grill, is it really need to do it?
  12. Aug 16, 2013 at 1:57 PM
    Manwithoutaplan
    ID
    Yea i would remove it. Plus it is not that hard to do, 2 bolts and 2 clips.
  13. Aug 16, 2013 at 2:01 PM
    mvega1969
    Laredo
    Ok, I will then.
  14. Aug 16, 2013 at 2:01 PM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    The grill clips into the bumper on the 2012+, not sure about the older style. Without installing a winch (I still don't have one) it took me maybe 3 hours. I didn't cut my stock bumper because the gap doesn't bother me one bit and it seems to be a waste.
    In hindsight I probably should have gotten a winch first but I drive through freaking white-tail alley every morning around 4AM.. need protection man.
  15. Aug 16, 2013 at 2:07 PM
    mvega1969
    Laredo
    I know what you said, it is better to have it and use it than not have it and need it... applies better to guns and deer.
  16. Aug 16, 2013 at 2:11 PM
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    You can do it!:D
    Once the bumper is hanging on the bracket, I used wood shims to get the clearances I needed/wanted!
    Take your time, the destructions are pretty good!
  17. Aug 16, 2013 at 2:12 PM
    mvega1969
    Laredo
    Yes, so you are the one who used the wood shims, I knew I've read it somewhere, this is one of the best tips to apply.
  18. Aug 16, 2013 at 2:26 PM
    udy2554
    Naples, NY
    I had some pics in my build thread, but when Kodak Gallery shut down, they all dissapoeared:(
    I did mine alone. First night I put the winch and bumper together, day 2 installed it.
    All went well for me.
    Having that second guy would have been nice lifting it in place, but even with the winch installed, I got it!:D
  19. Aug 16, 2013 at 2:35 PM
    mvega1969
    Laredo
    That gives me a bunch of confidence to finish it tomorrow, I will start early before heat gets above the 100's... and light the night up with my new bumper installed.
    Thanks,
    What did you end doing with the under the fender covers? it seems that they need to be trimmed once the ARB bumper is on.
  20. Aug 16, 2013 at 2:42 PM
    udy2554
    Naples, NY
    I did trim mine, but the instructions say to zip tie them up out of the way. If you do it ARB's way, the inner fender wells will still offer some protection to the engine compartment. I was too lazy to do it their way!:eek:
