ARB Bumper / No clearance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by colton1219, May 18, 2011.
  1. May 18, 2011 at 3:46 PM
    colton1219
    colton1219 [OP] Active Member
    Arizona
    SR5
    4.88 gears, ArB Bumper, ARB lockers front and rear
    I have an ARB on a 2006 Tacoma 2.5 inches of lift and 285 70 17 tires with 4.5 backspacing ,and no sway bars. I am rubbing the bumper pretty bad at full flex any body else had this issue?
  2. May 18, 2011 at 3:49 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Everyone with an ARB front has that problem. Most end up trimming the ARB bumper...
  3. May 18, 2011 at 6:18 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Well that sucks.
  4. May 18, 2011 at 6:28 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    I had a small amount of rubbing with my 285s. Cut it back for 315s. Just cut it with a cut off wheel and touch up with a flap disc.
  5. May 19, 2011 at 4:23 AM
    colton1219
    Arizona
    SR5
    I was afraid of that, does AllPro have that issue? What else is out there ?
  6. May 19, 2011 at 4:30 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    No they don't, but they have tons of other issues, like weakness.
    Go with Relentless Fab if you need something now, or wait for the new Armor Tech Offroad front to show up in the next month or two.
  7. May 19, 2011 at 6:41 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    Afraid to spend 30 minutes to do a simple cut on both sides? You'd rather go spend another $1K and get a new bumper?!
  8. May 20, 2011 at 5:32 AM
    colton1219
    Arizona
    SR5
    Not so afraid of anything , I like some bumpers better but dont care to ruin the powder coat on the bumper by fabbin it up ,shouldnt have to on a 1000.00 bumper anyway. Hows that for a reply to your smart ass answer?
  9. May 20, 2011 at 6:30 AM
    Wicked 2007
    Bay Area, CA
    Actually, it was a real question - not being smart ass. You must have taken it the wrong way by me asking the obvious.
    But since you want to be a smart ass - I guess I have another question for you. Do you even wheel your truck?
    Sounds like you should be in the my vagina hurts forum because you are worried about the powder coat on a bumper that is used for jacking, winching and sliding. :quickdraw: The ARB bumper was meant for our truck with the stock tire size. When you change stuff (go with bigger rims/tires) you have to make it work.
  10. May 20, 2011 at 6:58 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
  11. May 20, 2011 at 7:01 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    ^^ Agree^^
  12. May 20, 2011 at 7:01 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    :duel:
  13. May 20, 2011 at 7:02 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    and this! :cool:
  14. May 20, 2011 at 7:09 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    I agree you should not -have- to cut. But when it comes down to it and your choices are to tape off a small section and cut it off, or spend another thousand dollars on a bumper, you better be damn rich to make the second choice.
  15. May 20, 2011 at 7:18 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Welcome to TW!
  16. May 20, 2011 at 7:31 AM
    Wicked 2007
    Bay Area, CA
    That was my point exactly! And I dont think its being a smart ass to state the obvious.
    If he was on a stock truck with stock tires (what the ARB was DESIGNED for) then yes you should not have to cut. Fact of the matter is he is running a larger rim/tire combo and who knows what lift. So he needs to make his decision to go to a larger tire work - so he either cuts or drops a G on a new bumper that may or may not rub.
  17. May 20, 2011 at 9:40 AM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    ARB wasn't meant to run 285s. You want to run 285s cut the damn thing, get rid of it, or live with the rubbing. You won't ruin the powdercoat cutting it. I just took a flap wheel, cleaned up the cut, take a file as well maybe, tape off the edge and hit it with some semi gloss to match.
    Don't be so hostile here and you'll have a better time.
  18. May 20, 2011 at 9:49 AM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    Luckily I haven't had any rubbing on my ARB yet, just on the inside of the wheel well. I think a cab mount chop is in my future. If I take my swaybar off and I have rubbing I won't hesitate to make a little cut. There's no way I would go buy another bumper when I can fix the problem myself.
  19. May 20, 2011 at 10:01 AM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    I cut mine for 35's and I looks fine. If you take some care while cutting it should look factory
  20. May 20, 2011 at 11:08 AM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    Pics of the cut?
