arb bumper suspension review
Discussion in '1st Gen. Tacomas (1995-2004)' started by camt10, Apr 16, 2013.
  1. Apr 16, 2013 at 7:02 PM
    camt10
    camt10 [OP] Well-Known Member
    03 ext cab sr5 trd 4x4
    My truck was recently hit in front,going to change was thinking arb,not putting a winch. I've heard the weight is too much for stock suspensions I have stock height and heavy duty bilsteins ,so looking for reviews people who have tried ,with stock setups/ results.
  2. Apr 16, 2013 at 7:23 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Heavy duty bilsteins?
  3. Apr 16, 2013 at 7:38 PM
    camt10
    Heavy duty for stock height,bigger than OEM billsteins
  4. Apr 16, 2013 at 7:44 PM
    Gimmick
    Gimmick Well-Known Member
    Anthony
    Canada
    2017 TRD Offroad DCSB
    5100s??
  5. Apr 16, 2013 at 7:46 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    I recommend Old Man Emu 882's with OME Nitrochargers
    Wheelers Off-Road and Downsouth Motorsports both sell them.
  6. Apr 16, 2013 at 7:50 PM
    camt10
    No 5100s for lifted trucks,mine stock height,yeah have read about the heavy duty springs,trying to see if its worth putting on arb,maybe,ill go another brand,lighter.
  7. Apr 16, 2013 at 7:51 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    TRD OR stock bilsteins are of the "HD" series
    OP it's more the coils you'd have to worry about, since they hold the weight of the truck. Stock coils are very light and sag even without weight; adding an ARB might not be the best idea.
    on top of the fact that you have a first gen, which probably has some sag in it already
  8. Apr 16, 2013 at 7:57 PM
    camt10
    The stock bills were definately smaller.I was just trying to get an idea without putting in diff springs with diff spring rate.I just liked the look of arb not going off road I'm close to nyc so other than climbing some taxis.not much here locally.
  9. Apr 17, 2013 at 11:21 AM
    David411
    David411 Well-Known Member
    I've got King 700LB springs on mine, wouldn't run anything else.
  10. Apr 17, 2013 at 3:16 PM
    camt10
    Are those for stock height
  11. Apr 17, 2013 at 3:17 PM
    Large
    Large Red
    He probably don't realize you are a first gen, you rarely see 1st gens run 700 pounders.
  12. Apr 17, 2013 at 3:47 PM
    David411
    No I am running a first gen.
    Why do I love them?
    I got a full 3" of lift with 3/4" of preload.
    Didn't have to preload the hell out of my coil springs in comparison with 650Lb and 600Lb springs.
  13. Apr 17, 2013 at 3:53 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    If for some reason you want to remain at stock height (and simply want to avoid going lower than stock), you can try springs from a 2nd gen, preferably the progressive-rate ones from TRD Off Road.
  14. Apr 17, 2013 at 4:07 PM
    camt10
    Only reason wanting to stay stock height,I just replaced shocks for stock height before accident,can't see changing them
  15. Apr 18, 2013 at 2:25 PM
    tperkins
    tperkins Active Member
    Travis
    Slave Lake Alberta
    2004 Toyota Tacoma
    3'' revtec lift, 285 75 r16 Toyo Open Country MT's, cheap black rims, Tonneau Cover, Paint matched front grill
    Question regarding putting on an ARB bumper on 1st generation Tacoma:
    Recently, my friend was hit by a picker truck that backed into him, it bent his bumper a little bit. Luckily for both of us, he is getting a new bumper and I am getting his old bumper.
    At this time, I have stock springs, shitty Monroe struts with the 3" revtek lift kit.
    I would like to get a little more lift as my front end sits a bit low, and putting on a 90lb bumper will not assist with that. What are my options?
    I was thinking Bilsteins 5100's with OME 882 springs. Would this still achieve the same lift as the revtek with the ARB bumper?
    Thank you in advance for your time.
    OP, what did you end up deciding*? (I know you are still stock ride height)
  16. Apr 18, 2013 at 2:43 PM
    camt10
    I'm still waiting for ins check,lol I'm probably going to pull my 1 month old hd bilsteins sell them and put 5100s and IME springs and rear leads,I like the look of the arb,relentless looks good too but I don't wana wait 4 months if someone made a bumper that looked like those and didn't weigh 100# is go for that don't wana go back to stock.
  17. Apr 18, 2013 at 3:39 PM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    I was in the same situation... my truck a TRD Limited 4wd was hit... I choose (due to timing) to get an ARB.
    When it was mounted... my truck was serverly drooping downwards.
    It was that way, until i replaced them with Donahoe (ICON predecessors).
    and adjusted them to get them close to level.
    So what to do, if you want ARBs, get the ICON/FOX/etc or OME 882 or 883.
  18. Apr 18, 2013 at 4:40 PM
    camt10
    Has anyone tried using ome 883 springs with bilstein hd's
