ARB bumper suspension sag with my lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoMan709, Mar 31, 2010.
  1. Mar 31, 2010 at 6:55 AM
    TacoMan709
    TacoMan709 [OP] Well-Known Member
    Newfoundland (the Rock)
    03 Tacoma Xtra cab 4x4
    285 km2s, 2.5" lift, mashed pinch weld, Flowmaster, wicked piss
    Hi guys,
    I've been searching around for an answer to my question and haven't turned up with anything yet, so I figured I'd shoot it fresh in a new thread. And thoughts would be greatly appreciated :).
    I have an '03 4x4 Access Cab with a 2.5" lift. The lift includes a 2.5" coil spacer up front (on my stock springs) and a 1.5" add-a-leaf in the rear.
    My question is: if I put an ARB front bumper on, will it be too heavy for my stock front springs? Are there any issues that anyone can forsee with this setup?
    Also, should I get stiffer front coils, and if I do, will that cause a slight "bro-lean"?
    I'm a noob...apologies for any frig-ups here...
    Cheers.
  2. Mar 31, 2010 at 7:03 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    the arb will definately make the front sag a bit. ..you won't know how much until you try it.
    i would suggest gettting adjustable coilovers with a 650 to 700# spring. that way you can compensate for the sag.
  3. Mar 31, 2010 at 7:39 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Do you have TRD progressive rated springs or non TRD?
  4. Mar 31, 2010 at 7:42 AM
    TacoMan709
    Non-TRD.
    And Space Wrangler, do you think I should upgrade to the coilover setup before putting the bumper on?
  5. Mar 31, 2010 at 7:44 AM
    sirsaechao
    Tim
    CA
    I would put the bumper on and then see how much of a sag it is. Then decide if you wanna get coilovers or not.
  6. Mar 31, 2010 at 7:51 AM
    TacoMan709
    Right on, thanks for the advice. I was thinking the same, but I don't want to get the bumper on there, have a ton of sag, and then have to wait to get my coilovers.
    I suppose swapping the old bumper back on until I get my coilovers is always an option...plus, it gives me an excuse to spend the whole day drinking beers in the garage!
  7. Mar 31, 2010 at 8:02 AM
    V-TRAIN
    V-TRAIN Well-Known Member
    N. CACKALACKY
    08 TRD SPORT LONG BED
    DEMELLO ROCK CRUSHER SLIDERS, PIAA LIGHTS, TSB 4 LEAF PACK, CBI OFFROAD REAR BUMPER LINEXED, CBI OFFROAD FRONT BUMPER LINEXED, REAR 5100's, 1.5" TSB AAL, ICON EXTENDED TRAVEL COILOVERS @ 3", TOTAL CHAOS UCA's, HELLA MICRO DRIVING LIGHTS, IPOD INTERFACE, THULE ROOF RACK, UWS SLIM LINE BLACK TOOL BOX, 17" BBS RD TRUCK WHEELS, GOODYEAR WRANGLER DURATRAC IN 285/70/17
    if you have the bumper, you don't have to install it to see how much it will drop you. just take some measurements, then put some blankets on your hood and set the bumper on it. an easier way would be to wratchet strap it to the front so it hangs off the ground. then measure, this will give you a rough idea of what you are dealing with. it will be less, because your factory bumper will be on there.
  8. Mar 31, 2010 at 11:33 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Do you plan to put a winch in that bumper too? You can probably count on doubling the added weight if you do.
    I had a TJM bumper (very similar to the ARB) on my 98 non-TRD with a similar spacer setup to yours with no winch. The TJM did not cause the front to lower very much at all. At most, I lost about a half inch in height.
  9. Mar 31, 2010 at 1:25 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    when i first put my ARB on i had shitty rancho shocks, non-trd coils, and a top plate spacer...i had no sag whatsoever
  10. Mar 31, 2010 at 2:03 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    I put mine on with billy's at 2.5 on stock springs and i lost alittle lift. I ended up putting 886 coils on because I was adding a winch and skids.
    The guy I bought it from had a stock truck and said he had no issues:rolleyes:
  11. Mar 31, 2010 at 2:50 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    the spacers must help. one of my friends had his ARB put on his 04 a couple weeks before he got his lift and it sagged like crazy
  12. Mar 31, 2010 at 6:49 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    You shouldn't get much sag with just the ARB, as it is relatively light (I could pick up mine alone when I was installing it). If you add a winch though, then you will see sag.
  13. Apr 1, 2010 at 4:17 AM
    JimBeam
    JB
    2015 Tundra
    agreed
    the 1st gen ARB is only like 80lbs or so...i was able to install mine by myself
  14. Apr 1, 2010 at 5:09 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    the sag isn't going to be noticeable immediately. ..well, not much anyway. what you will notice is that it will get worse over time. the repeated cycling of the springs with the added weight will exacerbate the sagging.
    i say put whatever bumper you want on the truck and wheel it. ..when the front starts to sag more than you like, buy some adjustable coilovers. ..problem solved.
  15. Apr 18, 2010 at 12:43 AM
    1989toyotapickup
    1989toyotapickup Member
    Aaron
    I put an ARB front bumper on my truck bout a month ago. To account for the weight and sag I put on 2 inch spacers. No sag to really speak of now.
