ARB bumper vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by achirdo, May 23, 2012.
  1. May 23, 2012 at 8:49 AM
    achirdo
    achirdo [OP] I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    I Recently installed and ARB bumper on my trucck and I've noticed while driving that the bumper vibrates and shakes no matter how much I tighten the damn thing down. Another Guy I know with one is having the same issue. Any body else have this problem and how did you fix it? I'm thinking about tack welding it in place and see if that helps at all.
  2. May 23, 2012 at 8:52 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Maybe due to the spacer lift :notsure: Get some stout springs on that rig.
  3. May 23, 2012 at 8:53 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Mine shakes just a little but doesn't vibrate.
  4. May 23, 2012 at 8:56 AM
    achirdo
    Adam
    North DFW
    Maybe I haven't updated my info but I have ome 885s and Billy 5100s in the front
  5. May 23, 2012 at 8:57 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    Both of mine have a little shake, nothing to worry much about.
    On my 1st gen Tacoma, the ARB is a little smaller and the shake is barely noticeable. On my 4th gen 4Runner, the bumper sits farther out and ia a bit larger like the 2nd gen Taco's. It has a bit more vibration. Both are torqued down tight.
  6. May 23, 2012 at 8:57 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    No vibs here.
  7. May 23, 2012 at 8:58 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    mine is solid as rock man i'm actually scratching my head how it even could vibrate :/
    mine has a warn m8000 and had steel line in it for months i have winched off of it a few times now and since changed over to synthetic line and never one vibration. i would re torque everything according to the instructions maybe a few things are loose :confused:
  8. May 23, 2012 at 8:59 AM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    It may not be the actual bumper vibrating, but the front end of the vehicles moving due to the suspension.
    On mine there is no play in the actual bumpers. you can hang off of them and jump on them and they are solidly connected to the frame.
  9. May 23, 2012 at 9:00 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  10. May 23, 2012 at 9:01 AM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    On my 1st gen mine hit the fender and made noise I put a chunk of mud flap in between.
  11. May 23, 2012 at 9:02 AM
    XXXX
    sKiP
    05 Prius
    his bumper isn't vibrating separately then the frame - it's the vibration difference from the cab to the bumper I would assume due to them having rubber separating them. totally normal NO MATTER WHAT BUMPER you have.
    IMO if your bumper isn't vibrating your not beating it enough
  12. May 23, 2012 at 9:03 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    this^
    this is also the reason you need to leave clearance between your bumper and your actual truck when installing them to allow for flexing.
    the bumper is solidly on there if everything is torqued down properly its actually the truck flexing if this makes sense op.
  13. May 23, 2012 at 9:03 AM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    ^This a little too late
    meant ...this
    __________________
  14. May 23, 2012 at 9:05 AM
    achirdo
    Adam
    North DFW
    Can you
    see the top of it when you are driving?
    You see that's what I was thinking. It feels solid as a rock. But shouldn't I feel the rest of the truck vibrating along with the bumper then? it seems like its just the bumper doing it.
  15. May 23, 2012 at 9:12 AM
    achirdo
    Adam
    North DFW
  16. May 23, 2012 at 9:12 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Yup yup.
  17. May 23, 2012 at 9:15 AM
    XXXX
    sKiP
    05 Prius
    This "vibration" is why EVERYONE needs to insure you have 1/2" - 3/4" clearance between your bumper and fenders when they go aftermarket. This includes rear bumpers and sliders.
    Unless of course you have solid motor mounts, tranny mounts, and cab mounts in which case you'll need a kidney belt
  18. May 23, 2012 at 9:17 AM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    I can't even see mind:notsure:
  19. May 23, 2012 at 9:19 AM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    absolutely i didn't realize how much it actually would flex loli'm glad you helped me or i probably would have mounted it to close to the truck and broke something :laugh:
  20. May 23, 2012 at 9:35 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Wut??
