ARB carrier bearing shims, yes or no?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 99superduty, Dec 21, 2016.
  1. Dec 21, 2016 at 5:54 AM
    99superduty
    99superduty [OP] Well-Known Member
    2016 DCSB OR 4x4 OME LIFT W/886 and DAKARS 265/75/16 Duratracs C4 lo pro bumper
    Did my OME lift and this came with the kit. Anybody put this on and does it make any difference?
  2. Dec 21, 2016 at 6:05 AM
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    You most likely will need them. Easy way to check is use an angle finder (the IPhone has one) and check the angles of the two portions of the driveshaft. I replaced the bolts with longer ones and used washers to get a more precise alignment.
    99superduty[OP] likes this.
  3. Dec 21, 2016 at 5:00 PM
    99superduty
    well the OME kit came with the lift so I guess I need to stop being lazy and put it on....
  4. Dec 21, 2016 at 5:09 PM
    EasyLivin
    Jeff
    Euless, TX
    Good swag math is 1/4" of carrier bearing drop per 1" of lift. It's a good place to start and go from there. When I get back home from travelling tomorrow I will take a picture of my setup. I used washers and stepped them up until I got the optimal feel. For me, I lifted 3" in the rear and only used 1/4" worth of washers so go figure.....:thumbsup:
