ARB ckma12 max perf on board air compressor
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by SoCaltaco65, Jun 4, 2013.
Thread Status:
Not open for further replies.
  1. Jun 4, 2013 at 5:41 PM
    SoCaltaco65
    SoCaltaco65 [OP] Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    #SOLD#
    Selling a new, never used ARB twin air compressor, was going to have on board air but went 2x co2 bottles, never installed or powered, paid $495.00 plus tax
    $425.00, Firm, SoCal only, no shipping
    Providing optimum power, the twin motor design will deliver superior air flow for fast inflation purposes and comes with all the necessary hardware required. Constructed of lightweight, high strength engineering grade materials, it incorporates quality components for quiet operation and extended durability. Features:
    • High flow, twin motor, dual cylinder, 12V DC air compressor
    • Designed for inflating tyres and air locker activation when used in conjunction with optional accessories
    • Suitable for many air tools when used in conjunction with optional air tank kit
    • 100% duty cycle
    • Sealed for moisture and dust resistance
    • Hard anodised cylinder bores for reduced friction
    • Teflon impregnated carbon fibre piston seals for maximum trouble free life
    • Anodised mounting bracket dissipates heat
    • Integrated pressure switch, relays and IP55 (waterproof/dustproof) brushless fan cools electronics, motors and cylinder heads
    • Quality components for quiet operation and extra long life
    • Constructed of lightweight, high strength engineering grade materials
    • Over-pressure safety valve equipped
    • Motors are internally thermal protected against extreme heat damage
    • Full wiring loom included for simplified installation and plug-in connectivity to Air Locker control solenoids
    • Heavy duty in-line maxi fuse for each motor provides professional circuit protection
  2. Jun 4, 2013 at 5:46 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Mmm, mmm, mm.
  3. Jun 4, 2013 at 5:50 PM
    SoCaltaco65
    I hate to sell it, but I got lazy with 2x on board bottles.
  4. Jun 6, 2013 at 7:28 AM
    SoCaltaco65
  5. Jun 7, 2013 at 6:40 AM
    SoCaltaco65
  6. Jun 11, 2013 at 6:50 AM
    SoCaltaco65
  7. Jun 15, 2013 at 12:04 PM
    SoCaltaco65
  8. Jun 15, 2013 at 12:07 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Does this fit nicely in the engine bay anywhere?
  9. Jun 15, 2013 at 6:13 PM
    SoCaltaco65
    good heavens no, its big, its 2 comps hooked in tandem.
    it ways about 40-50 LBS. This would be something you tuck in between the bedside and bed wall, Like what Chris did. Or make a box for it to tote around with jumpers hooked into for portable use.
  10. Jun 15, 2013 at 8:17 PM
    VolcomTacoma
    Jeff
    NorCal
    Ohhhhhhhhh ok. Well, free bump, hopefully someone takes this
  11. Jun 15, 2013 at 8:20 PM
    SoCaltaco65
    thanks Jeff, ya its a big one.
  12. Jun 15, 2013 at 8:24 PM
    VolcomTacoma
    Jeff
    NorCal
    My current plan is a camper shell and probably a carpet kit so I've got something to pass out in out in the desert. Going to try to get some benches made the length of the bed the height of the wheel wells with underseat storage for tools/recovery since I'll have to lose the tool box...LT somewhere down the road when I've got the cash to spend.
    Anyways, life story over, this would be awesome for me if I had somewhere good to put it...I'm gettin super tired of taking an hour to air up with my B&D air compressor/battery jumper thing...
    SOMEONE BUY THIS.
  13. Jun 16, 2013 at 2:42 PM
    SoCaltaco65
    Price reduced again.
  14. Jun 19, 2013 at 5:30 AM
    SoCaltaco65
  15. Jun 20, 2013 at 6:36 AM
    SoCaltaco65
  16. Jun 20, 2013 at 11:20 AM
    VolcomTacoma
    Jeff
    NorCal
    Why isn't this sold yet! Someone buy this!
  17. Jun 20, 2013 at 11:30 AM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    I have the same compressor. Absolutely awesome piece of gear. Fills up my 35's in 2 mins. Mine is fitted behind my rear seats on the drivers side.
    Bump for you.
  18. Jun 20, 2013 at 1:27 PM
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    4.88, Radflo 2.5" Resi,ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack+2,front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    +1 bump wish I could have paid that.. this is a 100% duty rated compressor(s) without the amp requirement of the extreme compressors, mine is mounted under the bed between the cab and spare, and the air inlets routed into the bed comparement to prevent dust being sucked in and water. I use two 1 gallon tanks mounted to my CBI bumper in the fenders to power air tools.. it's AWESOME!!! Someone needs to buy this.. we aired up 2 trucks with larger tires than it took a normal compressor to do one
    truck tied off the battery.
    Huge thanks to www.sierraexpeditions.com for the kick ass install!
  19. Jun 20, 2013 at 2:00 PM
    VolcomTacoma
    Jeff
    NorCal
    Well now (rub chin) I never thought about an under the bed situation...How did you mount it like that? To the cross member? or just through the bed...Does it come with a mounting plate of some sort or did you just drill through?
  20. Jun 20, 2013 at 2:20 PM
    SoCaltaco65
    Also the filters can be remotely mounted to help keep dirt out of it.
Thread Status:
