ARB CKMTA12 & BlueSea 5026
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mik4stlcards, Mar 28, 2015.
  1. Mar 28, 2015 at 9:14 AM
    mik4stlcards
    mik4stlcards [OP] Well-Known Member
    St George Utah
    07 TRD
    So I just wanted to do a quick update of my latest project. Not a very thorough step by step guide here, nonetheless all of your threads and photos have inspired me to share this information.
    So I set out to make 2 brackets so that I could mount the OBA ARB CKMTA12 compressor under the hood as well as the Blue Sea 5026 circuit panel.
    I am not finished with the project yet as I still have to mount the switches and tidy up the wiring under the dash----lets call the project 90%.
    So to start I made a cardboard template and then drew up dimensions in google sketchup
    bracket for panel 1 - power circuit panel​
    bracket for panel 2 - OBA ARB air compressor​
    After I felt very confident that this would be exactly what I wanted, I took the drawings over to an acquaintance/friend who has a fabricating shop for build. His shop specialty really is powdercoating not fabricating. Anyway so here are the brackets installed.
    Hoping to get the rest of the electrical tied up today. Then I'll test out my new OBA by going out in the sand, let the air down and air back up. Can't wait!!
    amora9912 and V5ioV like this.
  2. Mar 28, 2015 at 9:32 AM
    Pigpen
    Dan
    Northwest Montana
    Nice, super clean work!
  3. Mar 28, 2015 at 10:11 AM
    bicyclist
    bicyclist Well-Known Member
    Nice. Like the red powdercoat.
  4. Mar 28, 2015 at 6:31 PM
    mlbdriver
    mlbdriver Well-Known Member
    Ben
    Santa Rosa
    2020 TRD Off-Road
    Go Fast Camper ARB Dual Air-Compressor Pro-Comp 7089 17x8 BFG AT KO2 265x70x17
    Can you air up your tires directly from compressor or do you need an air tank with that model compressor?
  5. Mar 28, 2015 at 6:47 PM
    mik4stlcards
    St George Utah
    07 TRD
    Mlbdriver. You have to purchase the air up kit which is #171302 (I think). And yes you can air up directly from the compressor.
  6. Mar 28, 2015 at 6:53 PM
    mlbdriver
    Ben
    Santa Rosa
    2020 TRD Off-Road
    Cool thanks for the reply
  7. Mar 29, 2015 at 8:44 PM
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    Nice design. Looks familiar
  8. Mar 29, 2015 at 8:51 PM
    mik4stlcards
    St George Utah
    07 TRD
    Familiar yes, but not CNC like your design. I want to build a CNC table to make custom parts like you. Unfortunately this is what I will have to settle for based on my time available currently with work, family and life in general!
    I haven't seen any brackets for the compressor under the hood for gen 2 like I did. Not saying it hasn't been done, just haven't been a member long enough or seen enough posts about OBA I guess.
    Fav part about the whole thing is that it is under the hood and clean---almost looks factory.
  9. Apr 29, 2015 at 11:55 PM
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    OP, install looks super clean!
    I'm curious on what are you planning on doing next! Are you planning on using the fill up kit directly from the compressor or through a ARB manufold? looks like the compressor sits very close to the hood when the hood it's close... if you are using the ARB manifold, where are you planning on mounting it to?
  10. Apr 30, 2015 at 12:03 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    super clean.
  11. Jul 19, 2015 at 8:02 PM
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    Looks like factory install, did you power to the Blue Sea fuse block and what size fuse did you use? Can you post more pics of the wiring?
  12. Jul 23, 2015 at 6:26 AM
    mik4stlcards
    St George Utah
    07 TRD
    The blue sea fuse block is powered from the terminal I have my finger via the 100amp circuit breaker pictured here
    My only circuits currently wired into the blue sea fuse block is my OBA system.
    Also I am thinking about adding a small tank so that I can air up faster. Removing the quick connect air hose fitting here
    And installing tubing to a tank I can accomplish adding an air tank remotely somewhere else as I can't fit it under the hood.
    In all I have used my OBA to air up my tires after airing down at the dunes and filling up bike tires for my kids when we have gone camping. One of the better investments IMO.
  13. Jul 24, 2015 at 7:42 PM
    2chains
    Calgary, Alberta
    Thanks for the pics, great looking install!
    mik4stlcards[OP] likes this.
  14. Jul 24, 2015 at 7:49 PM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    That is some OCD quality work right there. No offense since I am an OCD mod kind of guy as well. Nicely done.
  15. Aug 12, 2015 at 9:06 AM
    raginrougarou
    raginrougarou Well-Known Member
    Forrest
    2015 Gray Tacoma TRD Sport
    Do you remember what size screws you used to attach the plate that holds the blue sea panel to the truck?
  16. Aug 12, 2015 at 10:12 AM
    Pcyc
    Fritz
    Concord, CA
    M8 or M10 I think. I got my bolts at Ace hard wear.
  17. Aug 15, 2015 at 11:24 AM
    2chains
    Calgary, Alberta
    I noticed the 40amp fuse in the fuse block, my Blue Sea fuse block(5026) has rated max circuit of 30amps. Is that a special Blue Sea kit one can buy?
  18. Aug 15, 2015 at 11:11 PM
    mik4stlcards
    St George Utah
    07 TRD
    @2chains. No this is the 30A block. It can handle higher amperage. Especially with limited use you shouldn't ever have an issue.
  19. Sep 3, 2015 at 2:55 PM
    Loganc08
    Loganc08 Well-Known Member
    Logan
    Charlottesville, VA
    2009 Black Tacoma AC TRD OR
    OME front and rear with 886s
    Thanks for the write up!! Couple questions...
    - Since you linked into the bluesea did you get rid of the 2 inline fuses supplied by ARB?
    - Where did connect the red-yellow ignition wire and blue-white dash illumination wires?
    Never really wired anything before so sorry if those are obvious questions:confused:
  20. Sep 7, 2015 at 4:50 PM
    Dirtboyz
    Dirtboyz Well-Known Member
    Spanaway, WA
    DCSB trd sport 4x4
    Front bilstein 5100 with OME 884 w/trim pack, 17" fuel trophy wheels wrapped with 32" toyot open country m/t, bakflip fibermax tonneau cover, Avec 30" led light bar behind lower grille, marathon seat covers in max 5 camo pattern, trimmed front and rear mud flaps, more to come.
    How did you mount to the truck. Did you use the pre-existing holes there already? If so how did you get to them. Last question, what material and what gauge did you use for the bracket? Thanks and awesome work by the way. I'm planning on getting the smaller 6 point box and stumbled across this and really like your work!
