ARB compressor installation options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiwiyyc, Aug 22, 2021.
  1. Mar 10, 2023 at 6:42 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    That is a good question, ha. I do remember that I removed the airbox. That gives a ton of extra working space. With that out, you can go under the mount. I think that is what I did.
    Asc_0989[QUOTED] likes this.
  2. Mar 10, 2023 at 7:09 AM
    MGMoverland
    MGMoverland Well-Known Member
    Brad
    Golden, CO
    22 Tacoma TRD 4x4 Offroad
    Full RCI Armor/Sliders, Bilstein 6110/5160 w/Deaver stage 3 leaf pack, Method 703 titanium wheels, BFgoodrich KM3 265/70/16, BD Sport Amber fogs, OEM LED HL, Meso 1st stage Tail conversion, Anytime front camera, EE accessory dash mount, Alu-Cab Contour canopy, Alu-cab ammo box slide, Alu-cab fridge slide, Alu-cab large cupboard, Alu-cab gen 3 tent, Goose gear deck plate, ARB twin compressor w/DDI under seat mount, Yaesu FTM 400XDR ham radio, Snomaster 72 classic fridge freezer, Battleborn 100AH lithium house battery, Front Runner 17.7 gallon onboard water.
  3. Mar 10, 2023 at 7:31 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
  4. Mar 10, 2023 at 12:01 PM
    MGMoverland
    Brad
    Golden, CO
    Some tips on install, make sure you route the seat harness like I did. In fact, study the image of my seat harness you will see I routed the vehicle side of the harness back behind the seat frame and then brought it forward. Reason for this is to make sure you do not pinch the harness at the front when moving the seat. It limits your forward and rear seat movement by a little bit but not bad overall.
    Make sure you use thread tape on the brass fittings. The sealant on them does not seal it at all. I scrubbed off the sealant (as best possible) and applied thread tape. There is still a very small amount of air escaping but not enough to make a difference.
    Much like Chloe Kuo I ran the wires under the carpet to the side of the vehicle then routed the ARB fuse holders up under the carpet at the bottom of the A pillar on the passenger side. I then routed the power cables over the trans hump under the carpet to the base of the driver's side A pillar and out to the engine bay through the main grommet and attached to the battery. I also used the add a fuse with the mini fuses to tap into ignition and illumination power at the fuse box. I used a couple medium zip ties to secure all the extra wiring to the DDI bracket behind the compressor to keep things tidy. I had to tuck the locker solenoid wiring under the compressor filter under the tunnel side.
    Make sure to test everything while the seat is out. If you are worried about the airbag light triggering, then plug the seat back in and test it. I used some soapy water and sprayed the fittings to see if they were sealed.
    Putting the seat on top of the seat jackers is a huge PITA as the rear ones move quite a bit when trying to set the seat over the compressor and the bracket. Having 2 people (one in the front seat area and one in the rear) would definitely help.
    I ran it long enough to air up 4 tires and put my hand on top of the brackets and cooling fins on each pump and felt the temperature reaching the wiring and seat bracket was negligible.
    mquibble[QUOTED] likes this.
  5. Mar 10, 2023 at 12:51 PM
    dave5623
    dave5623 Well-Known Member
    2020 TRD Pro
    Has anyone installed the Runnin4Tacos mount yet?
  6. Mar 10, 2023 at 1:48 PM
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
  7. Mar 10, 2023 at 1:52 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
  8. Mar 11, 2023 at 4:33 AM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
  9. Mar 11, 2023 at 8:03 AM
    MGMoverland
    Brad
    Golden, CO
    I looked at the R4T mount but the thought of blocking any radiators seemed a little risky. I tend to off-road in the desert a lot, and airflow for cooling is imperative.
  10. Mar 11, 2023 at 11:00 AM
    geobontaco
    geobontaco Member
    Oregon
    2020 TRD OR Quicksand MT
    Method 704 K02 2857017 OME BP-51 OME UCA Caliraised sliders & bed rack RCI skids ARB single in the bed Baja Designs S8
    I used the expedition essentials mount and extension cable on the passenger side and was able to leave the outlet in place, but removing the storage cubby. The storage door hides the compressor when not in use.
    I ran it to the drivers side following zip-tying to other cables along the back of the bed/tailgate side; I didn't want to cross the prop shaft. I had to extend the extension cable a few feet to connect power to the battery. The extension cable is only long enough to run from a driver sided mount.
    The air hose and accessories are behind the back seats.
    [/URL]
    tehkei90 likes this.
  11. Mar 12, 2023 at 7:58 AM
    Breakdown
    Breakdown Well-Known Member
    Does that area stay clean when off roading?
  12. Apr 24, 2023 at 8:45 AM
    GoldenTaco27
    GoldenTaco27 Well-Known Member
    Blake
    Long Beach Ca
    2017 Tacoma DCSB TRD Off Road
    @hungoverland on IG, King 2.5" EXT Travel w/ Archive Garage shock relocation, Icon RXT leafpack, 285 Nitto M/T's, bronze Raceline Defender wheels, TJM front/rear bumpers, TJM Sliders, Prinsu Cabrac, Katzkin leather, RSI Smartcap EVO topper, OV Tuned, MESO everything, Spyder headlights and tail lights, center mounted infant restraining system (CMIRS) \m/
  13. Apr 24, 2023 at 9:37 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
  14. Apr 24, 2023 at 9:46 AM
    GoldenTaco27
    Blake
    Long Beach Ca
    Im surprised it fits back there... any photos by chance? Also, did you mount your compressor back there too or under the hood like most?
  15. Apr 24, 2023 at 10:20 AM
    #35
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
  16. Apr 24, 2023 at 10:27 AM
    #36
    GoldenTaco27
    Blake
    Long Beach Ca
  17. Apr 24, 2023 at 11:08 AM
    #37
    danojeno
    Inland Empire, CA
    No tank. For inflating tires, unless you have a giant tank, there's no use for it. Horns or other on demand items would need a tank.
  18. Apr 24, 2023 at 11:36 AM
    #38
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    I'll try to snag a pic after work. Compressor is mounted in the engine bay.
    I wanted the tank mounted vertically so I can drain the condensation that builds up.
    GoldenTaco27[QUOTED] likes this.
  19. Apr 24, 2023 at 11:46 AM
    #39
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I made a mount for the engine bay for my VIAIR compressor. Easy and didn't take long at all. Beats paying the outrageous price they charge for a mount!!
    NickAdams2112 and Kwikvette like this.
  20. Apr 24, 2023 at 11:48 AM
    #40
    Kwikvette
    Fresno County
    4 run, 2 don't
    Made one for a good friend of mine as well
    You can do it all with an angle grinder, just make sure to use those safety squints
    Technique[QUOTED] likes this.
